    MMM-FHEM no Fhem statusdisplay
    11 Posts 5 Posters 8.8k Views 5 Watching
    • W Offline
      Woody
      hi folks,
      I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running. It doesn’t matter if I use Http or Https, I tried also differed Devices and Readings but no luck. This is my config and maybe someone can point me out something wrong or give me any idea in debugging this.
          			module: 'MMM-FHEM',
         			 position: 'bottom_bar',
            			host: '192.168.0.50',
            			port: '8083',
            			https: 'true',
            			devices: [
                        			{ deviceName: 'Lichtfenster',
                          			  deviceReadings: [
                                            			{ name: 'state', suffix: 'test1' },
      any help will be appreciated. Thx in advance… Woody
      • N Offline
        Nonamexp
        Hello, you have deactivate The Passwort in fhem?!
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Woody
          @Woody I don’t have experience with this specific module, but I can tell you the way you defined the boolean https was always true.
          In Javascript a string is always true no matter what the content is "hello" -> true, "true" -> true, "false" -> true.
          If you remove the quotes and try again https: false, then you will really use http instead of https.
          • W Offline
            Woody
            Thanks Folks,
            it seem I was completely stumped. Sometimes I overlook the simplest things.
            The password was the problem but, at least I think this is not a good solution to access Fhem without authorization. Anyway, problem solved - thanks a lot.
            Rgs. Woody
              dominic @Woody
              @Woody said in MMM-FHEM no Fhem statusdisplay:
              Thanks Folks,
              Rgs. Woody
              Hi Woody,
              how can i deactivate the passwort? I think my problem is the same.
              • W Offline
                Woody
                in fhem you have to disable “basicAuth” in fhem.cfg like this…
                #attr allowed_WEB basicAuth shjedIOhbn6BHFJjGH
                  dominic @Woody
                  Hi Woody, thanky you for your answer. Can you explain it?
                  I have defined WEB and than ? Sorry i am very new in FHEM what means " shjedIOhbn6BHFJjGH"?
                    dominic @Woody
                    @Woody
                    So i now there is this entrie in the config.cfg “define allowed_WEB allowed
                    #attr allowed_WEB basicAuth xxxxxxxxxxxxxxx
                    #attr allowed_WEB validFor WEB”
                    and my config.js looks like this
                        module: 'MMM-FHEM',
                        position: 'top_right',
                          host: 'localhost',
                          port: '8083',
                          https: false,
                    	        devices: [
                                      { deviceName: 'ESPEasy_ESP_Test_DHT',
                                        deviceReadings: [
                                                          { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
                                                          { name: 'Humidity', icon: 'wi wi-humidity', suffix: '%' },
                                      { deviceName: '',
                                        deviceReadings: [
                                                          { name: 'Humidity', icon: 'fa fa-battery-half', suffix: '' },
                    And this is in FHEM…
                    where is the mistake?
                    • W Offline
                      Woody
                      @dominic said in MMM-FHEM no Fhem statusdisplay:
                      shjedIOhbn6BHFJjGH is your base64 encoded string of user:password in your fhem.cfg.
                      In your forelast post it seems to be out commented with a # as i recommended in my last post. For me this means that you’ve no authentication in place and your original problem seems not to be an authorization issue.
                        dominic @Woody
                        @Woody Thank you, yes i think my originlproblem is not the authorization.
                        Do you have any idea., what it could be ?
                        • H Offline
                          Hotstepper
                          it seems to be a problem with fhem’s security mechanism “csrfToken”.
                          You can define a new Web in fhem with a different port and set this up as follws:
                          fhem.cfg:
                          define MagicM FHEMWEB 8086 global
                          attr MagicM allowfrom 192.168.1.14
                          attr MagicM csrfToken none
                          Explanation:
                          • This define’s a new listening port at your fhem server on port 8086
                          • The only allowed ip is 192.168.1.14 This is the ip of your MagicMirror Device. Choose your ip.
                          • Disable the use of csrfToken. https://fhem.de/commandref.html or https://wiki.fhem.de/wiki/CsrfToken-HowTo
                          After fhem restart your readings will be shown at your MagicMirror.
                          Hope it helps.
                          Greetz, Hotstepper.
