    MMM-Scenes
    12 Posts 5 Posters 6.0k Views 5 Watching
      MMRIZE
      MMM-Scenes
      “Life is a theatre set in which there are but few practicable entrances.”
      ― Victor Hugo, Les Misérables
      MagicMirror module to change screen scenes by time and order with ANIMATION EFFECT.
      Demo
      MMM-Scenes Demo
      Click To Play
      Concept
      The scenario of the MM screen is made up of a series of scenes. Each module has its role in its appearance scenes to enter and exit by design.
      When a scene begins, all modules whose roles end, will be expelled, and all modules that have the parts in that scene will be admitted.
      As described in the scenario, your MM screen will play a drama with modules.
      Features
      • control show/hide modules by assigning scene names into the module’s class
      • custom animations for modules expel/admit
      • control scenes by notification and WebURL endpoints.
      • Loop control
      • custom indicators
      Warning
      Old/weak SBCs (e.g. RPI 3 or older) may not have enough power to handle severe animations.
      More Details
      https://github.com/MMRIZE/MMM-Scenes
      MZ-BERM M 2 Replies Last reply Reply Quote 5
      • MZ-BERM Offline
        MZ-BER @MMRIZE
        @mmrize That is amazing! Thanks for sharing your module. Really good documentation.
        • doctorwhenD Offline
          doctorwhen
          Very cool. Thanks for the excellent module, i’m integrating it into my mirror without much difficulty. The only problem I’ve run into thus far is with the example config which I had to modify slightly to get it working on my setup.
          All I changed was the weather apikey but that didn’t work (blank screen, electron exits). I then changed the declaration of config from const to var and the example config works:
          const config = {
          to
          var config = {
          Otherwise, wow!
            MMRIZE @MMRIZE
            UPDATED
            1.1.0 (2021-11-01)
            • ADDED : MMM-TelegramBot commandable. (Thanks to @doctorfree)
            • N Offline
              Norder
              Hello! Thank you for the amazing work you’ve done. The scenes module was exactly what I needed to pop my MM up a notch. I do have some questions, however.
              How do you apply an expel/admit animation to specific modules only and not the whole scene?
              Can you do this for transitions between specific scenes? i.e. pageDown animation if arriving from scene 2, pageUp if arriving from scene 3?
              I’m wondering if there is a simple way to accomplish this, like an extra class tag within a module itself to call the animation type? My end goal is to have swipe gestures change scenes and have the animations change based upon the previous scene.
              Thanks again!
              M 3 Replies Last reply Reply Quote 0
                MMRIZE @Norder
                @Norder Thanks for your interesting. I’m on the holidays so cannot look inside deeply.
                After return, I’ll reply you sorry.
                  MMRIZE @Norder
                  @Norder
                  You can do it with “custom animation function” https://github.com/MMRIZE/MMM-Scenes#--custom-animation-function
                  You can define specific animation and module which you want to apply, then describe it in the “scenario”. Ideally it’s all, but real-world sample i will show you in a week (after my return)
                    MMRIZE @Norder
                    @Norder
                    To assign specific animation to the specific module, you can use “custom animation function” in your “scenario”.
                    To specify the module, you can use module property in animation function. For example, you can use module.name , module.data.classes or module.data.position (or whatever you want) (https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties)
                      scenario: [
                          expelAnimation: ({ module, moduleWrapper, duration }) => {
                            if (module.name === 'clock') {
                              return new Promise((resolve, reject) => {
                                moduleWrapper.animate([
                                  { transform: 'scale(1,1)', opacity: 1 },
                                  { transform: 'scale(10, 10)', opacity: 0 }
                                ], { duration }).onfinish = resolve
                            } else {
                                  { transform: 'scale(1, 1)', opacity: 1 },
                                  { transform: 'rotate(-360deg) scale(0, 0)', opacity: 0 }
                    Well, this example looks not so simple, I hope you can follow it.
                    S N 2 Replies Last reply Reply Quote 0
                      sdetweil @MMRIZE
                      @MMRIZE said in MMM-Scenes:
                      javascript programming question
                      why do you use {} around the function parms? usually this creates an object, which same labeled properties
                      but you don’t use them like properties of an object in the function
                      what extra value did u get from the braces?
                        MMRIZE @sdetweil
                        let x = {
                          foo: 123,
                          bar: 456,
                          baz: "please don't touch me"
                        function A (obj) {
                          console.log(obj.foo)
                          console.log(obj.bar)
                          // obj.baz = 'oops I did it again"
                        function B (Foo, Bar) {
                          console.log(Foo)
                          console.log(Bar)
                          // safe for .baz or object itself
                          // However, you must keep the order and number of parameters.
                        function C ({bar, foo}) {
                          console.log(foo)
                          console.log(bar)
                          // You don't need to keep the order and number of parameters.
                        function C2 (obj) {
                          let {bar, foo} = obj
                          console.log(foo)
                          console.log(bar)
                          // obj.baz = 'oops I did it again'
                        A(x)
                        B(x.foo, x.bar)
                        C(x)
                        C2(x)
                          sdetweil @MMRIZE
                          @MMRIZE thanks, I had not seen anonymous object before., or the hidden object property
                          • N Offline
                            Norder @MMRIZE
                            @MMRIZE
                            Thank you for your quick reply!
                            I really appreciate you taking the time to provide an example for me to work with. Most of this makes sense, despite my lack of programming skills.
                            Can I use the predefined PageDown animation within the custom definition? I’d like to avoid having to remake animations you’ve already provided.
                            My other question is how do I set temporary identifiers to the modules so the correct animation gets pulled? I don’t think module name or classes alone will work since I need the identifier to change based upon scene selection. Nor do I want to load multiple instances of the modules as I’m already pushing the heat up a bit. Please forgive my ignorance here, I’m sure it’s already well documented, I just don’t know where to begin.
