    MMM-RTSPStream broke after update 2.17.1
    19 Posts 4 Posters 5.8k Views 3 Watching
    • JerryPJ Offline
      JerryP
      After a clean and fresh install mirror crasht whit a black screen.
      pm2 log output
      0|MagicMir |     at require (internal/modules/cjs/helpers.js:88:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:11:15)
      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
      0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
      0|MagicMir |   code: 'MODULE_NOT_FOUND',
      0|MagicMir |   requireStack: [
      0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
      0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|MagicMir |     undefined
      0|MagicMir |   ]
      0|MagicMir | }
      0|MagicMir | [17.10.2021 21:04.27.536] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      Help please.
      This is the config part
      module: "MMM-RTSPStream",
      disabled: false, //false, true
      position: "upper_third",  // "middle_center" "upper_third"
      zoom: -0.6,
      			autoStart: true,
      			rotateStreams: false,
      			rotateStreamTimeout: 20,
      			moduleWidth: 720,
      			moduleHeight: 320,
      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
      			remotePlayer: 'none',
      			showSnapWhenPaused: false,
      			remoteSnaps: false,
      			  stream1: {
      			  name: 'Garage Botter Acker',
      			  url: 'rtsp://User:Pass***@192.168.**.**:554/cam/realmonitor?channel=1&subtype=1',
      			  protocol: "tcp",
      			  frameRate: 25,
      			  muted: true,
      Pm2 -v
      5.1.2
      nam -v
      6.14.15
      node -v
      v14.18.1
        sdetweil @JerryP
        @jerryp a little farther up the log says what module was not found, probably request
        in the module folder, do
        npm install request
        • JerryPJ Offline
          JerryP
          Thanks but this is not working
          This is the log
          pi@raspberrypi:~/MagicMirror/modules/MMM-RTSPStream
          $ npm install request
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          + request@2.88.2
          added 43 packages from 50 contributors and audited 244 packages in 26.473s
          11 packages are looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          • JerryPJ Offline
            JerryP
            $ npm fund
            mmm-rtspstream@2.0.2-dev
            ├─┬ https://github.com/sponsors/ljharb
            │ └── resolve@1.20.0, is-core-module@2.8.0
            ├─┬ https://github.com/sponsors/RubenVerborgh
            │ └── follow-redirects@1.14.4
            ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
            │ └── ansi-styles@4.3.0
            ├─┬ https://github.com/sponsors/jonschlinkert
            │ └── picomatch@2.3.0
            ├─┬ https://github.com/sponsors/feross
            │ └── safe-buffer@5.2.1, run-series@1.1.9
            ├─┬ https://www.patreon.com/feross
            ├─┬ https://feross.org/support
            ├─┬ https://github.com/sponsors/sindresorhus
            │ └── escape-string-regexp@4.0.0
            ├─┬ https://www.buymeacoffee.com/systeminfo
            │ └── systeminformation@5.9.7
            ├─┬ https://github.com/sponsors/isaacs
            │ └── glob@7.2.0
            └─┬ https://github.com/sponsors/epoberezkin
            └── ajv@6.12.6
              sdetweil @JerryP
              @jerryp and the mm start msgs?
              JerryPJ 1 Reply Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @sdetweil
                sorry
                0|MagicMirror  | Launching application.
                0|MagicMirror  | [18.10.2021 17:14.57.392] [ERROR]
                0|MagicMirror  | Whoops! There was an uncaught exception...
                0|MagicMirror  | [18.10.2021 17:14.57.412] [ERROR]
                0|MagicMirror  | TypeError: Cannot convert undefined or null to object
                0|MagicMirror  |     at Function.keys (<anonymous>)
                0|MagicMirror  |     at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
                0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:627:19
                0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                0|MagicMirror  |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                0|MagicMirror  |     at Parser.emit (events.js:315:20)
                0|MagicMirror  |     at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                0|MagicMirror  |     at writeOrBuffer (internal/streams/writable.js:358:12)
                0|MagicMirror  |     at Parser.Writable.write (internal/streams/writable.js:303:10)
                0|MagicMirror  | [18.10.2021 17:14.57.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|MagicMirror  | [18.10.2021 17:14.57.416] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                But the mirror is running. on a PI3B and now I’m out off RAM so lets order a 4B8GB hihihi
                  sdetweil @JerryP
                  @jerryp so there was an error and the module didn’t handle it.
                  swvalentiS 1 Reply Last reply Reply Quote 0
                  • swvalentiS Offline
                    swvalenti Project Sponsor @sdetweil
                    pm2 start omx_stream1
                      sdetweil @swvalenti
                      @swvalenti then
                      pm2 save
                      so it will restart on next boot
                        @sdetweil my guess is the omx stream was not started by pm2 after the update
                        • JerryPJ Offline
                          JerryP @swvalenti
                          @swvalenti
                          No the module was not booting totally. after i make the npm install request. the module is starting only the fault stil is in the log every time I reboot the mirror.
                            sdetweil @JerryP
                            @jerryp this module needs another process to be running IN ADDITION to MM…
                            • JerryPJ Offline
                              JerryP @sdetweil
                              @sdetweil ok. But what’s the solution? off is there no solution for this problem?
                                sdetweil @JerryP
                                @jerryp u were advised to start the other process manually
                                https://forum.magicmirror.builders/topic/15753/mmm-rtspstream-broke-after-update-2-17-1/8?_=1634583021814
                                • JerryPJ Offline
                                  JerryP @sdetweil
                                  @sdetweil Why… the module is running fine after I did what you told me to do. Only the error in the log is there now. but the module is running fine. What will by the use of starting the stream Manuel…
                                    sdetweil @JerryP
                                    @jerryp said in MMM-RTSPStream broke after update 2.17.1:
                                    ok, you didn’t say it was working
                                    what error in the log?
                                    did u do pm2 flush to throw away the old messages?
                                    • JerryPJ Offline
                                      JerryP @sdetweil
                                      O Yes it’s running only I’m using for testing a PI3B so this is running out of Ram memory.
                                      I also did the flus and still is er a issue when it’s booting pm2 start MagicMirror.
                                      0|MagicMirror  | [18.10.2021 21:18.12.312] [ERROR]
                                      0|MagicMirror  | [18.10.2021 21:18.12.452] [ERROR]
                                      0|MagicMirror  | [18.10.2021 21:18.12.466] [ERROR]
                                      0|MagicMirror  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMirror  | [18.10.2021 21:18.12.473] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        sdetweil @JerryP
                                        469
                                        the code seems to be trying to connect to the pm2 task for omx stream
                                        looking for the name
                                        which appears to be in this area of the config
                                            stream1: {
                                                    name: 'BigBuckBunny Test',   <--- I guess this needs to be the name of the pm2 process..
                                        • BKeyportB Offline
                                          @sdetweil I seem to recall that’s how it worked.
                                          Bottom line is that it’s breaking more and more, and should likely be put in the “yeah, it’s unsupported” pile of past modules.
                                          FWIW, I use my MMM-Block module to slide modules out of the way, and just run the OMX stream directly for now. (Looking for a solution for H.265 streams)
