    updatenotification seems not to work
    9 Posts 3 Posters 1.9k Views 3 Watching
    • B
      bdream
      Hello!
      I have a problem with default module updatenotification and need your help.
                              module: "updatenotification",
                              position: "top_bar",
                              ignoreModules: ["MMM-NewPIR"]
      With this configuration I assume not to get update notification for the module MMM-NewPIR anymore.
      But this happen since yesterday evening :angry_face:
      Thanks for your help!
      cheers, bdream
      bugsounetB S 2 Replies Last reply
      • bugsounetB
        bugsounet Banned @bdream
        Hi, it’s not related to updatenotification
        just update the module
          sdetweil @bdream
          @bdream as u can see, he provides his own update notification function
          bugsounetB 1 Reply Last reply
          • bugsounetB
            bugsounet Banned @sdetweil
            @sdetweil with a bug lol :)
            • B
              bdream
              The problem is, I Love the Module :beaming_face_with_smiling_eyes:
              But wach time I have to Update I Run in Problems I have to rebuild the MM.
              I wanted only geht rid of These Messages and stay withbthe Version of NewPIR euch Run perfectly in NY Environment.
              @bugsounet I had already an post in your community where you stated I should not use your module what is not the best option to me
              cheers, bdream
              • B
                bdream @bdream
                Is there a option to hide notifications regarding the NewPIR module?
                Or do I mistakes using the updatenotification module?
                cheers, bdream
                  sdetweil @bdream
                  @bdream the built in updatenotification module provides a modulename filter…
                  however HIS module is the one issuing the message and there appears to be NO mechanism to turn off the update notice
                  • B
                    bdream
                    Thanks @sdetweil for clarification!
                    I’m back to start now and search a module working with PIR to shut monitor off and on. After a time I got NewPIR running and I was quite happy. Now I’m unhappy about the way of this module running outside the normal way modules working for MM.
                    Any idea?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream said in updatenotification seems not to work:
                      see how he does it in his screen module and copy those commands to some other pir module…
                      https://forum.magicmirror.builders/topic/15288/face-recognizes-display-on-off/7?_=1635974008253
