    Bullseye
    45 Posts 8 Posters 21.6k Views 9 Watching
      bert269
      I am the only crazy person that wants to get MagicMirror working under Bullseye? It was working fine under Buster - but oh my, upgrading to Bullseye is a mess. Halfway through the upgrade, everything just freezes.
      Ok - re-image the SD-card and run the installation scripts (which all used to work fine under Buster) after Bullseye have been installed and "apt upgrad"ed…Magic mirror seems to initializes, but nothing displays on the screen. No config errors.
      Could it be because the change from dtoverlay=vc4-fkms-v3d to dtoverlay=vc4-kms-v3d ??
      Any suggestions would be helpful. I tried to search on here, but could not find anything about Bullseye in this forum.
        sdetweil @bert269
        @bert269 this is the second report… I have not had a chance to look at it yet… have and sd card flashed…
        https://github.com/sdetweil/MagicMirror_scripts/issues/36
        I asked the other user to post the ~/install.log for me to look at , can u add to the issue with the log file
          bert269
          Interesting - no ~/install.log file after the npm install. Not in the MagicMirror directory either. Ideas?
            bert269
            ~ dir layout:
            pi@piMirror:~ $ ls -al
            total 116
            pi 4096 Nov 12 11:16 .
            root 4096 Oct 30 05:12 …
            pi 132 Nov 12 10:49 .bash_history
            pi 220 Oct 30 05:12 .bash_logout
            pi 3523 Oct 30 05:12 .bashrc
            pi 4096 Oct 30 05:21 Bookshelf
            pi 4096 Nov 12 11:16 .cache
            pi 4096 Nov 12 11:16 .config
            pi 4096 Oct 30 05:53 Desktop
            pi 4096 Nov 12 10:35 Documents
            pi 4096 Oct 30 05:53 Downloads
            pi 4096 Oct 30 05:21 .local
            pi 4096 Nov 12 11:16 MagicMirror
            pi 4096 Oct 30 05:53 Music
            pi 0 Nov 1 22:55 NAS6604T
            pi 4096 Nov 12 11:04 .npm
            pi 4096 Oct 30 05:53 Pictures
            pi 12974 Nov 12 10:59 piMirror.sh
            pi 4096 Nov 12 11:02 .pki
            pi 807 Oct 30 05:12 .profile
            pi 4096 Oct 30 05:53 Public
            pi 4096 Oct 30 05:53 Templates
            pi 4096 Oct 30 05:53 Videos
            pi 4096 Nov 12 10:35 .vnc
            pi 53 Nov 12 10:49 .Xauthority
            pi 2361 Nov 12 10:49 .xsession-errors
            pi 2361 Nov 12 10:39 .xsession-errors.old
            pi@piMirror:~ $
            MagicMirror dir layout:
            pi 4096 Nov 12 11:16 …
            pi 57014 Nov 12 11:16 CHANGELOG.md
            pi 4096 Nov 12 11:16 clientonly
            pi 4096 Nov 12 11:16 config
            pi 4096 Nov 12 11:16 css
            pi 238 Nov 12 11:16 .editorconfig
            pi 34 Nov 12 11:16 .eslintignore
            pi 610 Nov 12 11:16 .eslintrc.json
            pi 4096 Nov 12 11:17 fonts
            pi 4096 Nov 12 11:17 .git
            pi 4096 Nov 12 11:16 .github
            pi 1094 Nov 12 11:16 .gitignore
            pi 4096 Nov 12 11:17 .husky
            pi 2858 Nov 12 11:16 index.html
            pi 4096 Nov 12 11:16 installers
            pi@piMirror:~/MagicMirror $
              sdetweil @bert269
              @bert269 u didn’t use my script… now idea
              see https://github.com/sdetweil/MagicMirror_scripts
              booting up on pi4 now
                bert269
                Apologies, sorry - no I did not used:
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                I only used npm install. Let me try and will let you know.
                  sdetweil @bert269
                  @bert269 we need node 14 for MM… the bullseye is only node 12
                  S bugsounetB 2 Replies Last reply Reply Quote 0
                    looks like trouble
                    /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb
                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                    node version is node: error while loading shared libraries: libnode.so.72: cannot open shared object file: No such file or directory
                    can’t install node 14…
                      bert269
                      Ok, run your install script. This time it worked. The screensaver interfered - but I can fix that. This is what I saw during install
                      Check current Node installation …
                      Node currently installed. Checking version number.
                      Minimum Node version: v14.0.0
                      Installed Node version: v17.1.0
                      No Node.js upgrade necessary.
                      Check current NPM installation …
                      NPM currently installed. Checking version number.
                      Minimum npm version: V6.0.0
                      Installed npm version: V8.1.2
                      No npm upgrade necessary.
                      Cloning MagicMirror …
                      Cloning into ‘MagicMirror’…
                      remote: Enumerating objects: 325, done.
                      remote: Counting objects: 100% (325/325), done.
                      remote: Compressing objects: 100% (290/290), done.
                      remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
                      Receiving objects: 100% (325/325), 477.94 KiB | 330.00 KiB/s, done.
                      Resolving deltas: 100% (53/53), done.
                      Cloning MagicMirror Done!
                      touch: cannot touch ‘/etc/chromium-browser/customizations/01-disable-update-check’: No such file or directory
                      tee: /etc/chromium-browser/customizations/01-disable-update-check: No such file or directory
                      Installing dependencies …
                      npm WARN EBADENGINE Unsupported engine {
                      npm WARN EBADENGINE package: ‘eslint-plugin-jsdoc@36.1.1’,
                      npm WARN EBADENGINE required: { node: ‘^12 || ^14 || ^16’ },
                      npm WARN EBADENGINE current: { node: ‘v17.1.0’, npm: ‘8.1.2’ }
                      npm WARN EBADENGINE }
                      npm WARN EBADENGINE package: ‘@es-joy/jsdoccomment@0.10.8’,
                      Dependencies installation Done!
                      Check plymouth installation …
                      Splashscreen: Checking themes directory.
                      Splashscreen: Create theme directory if not exists.
                      Splashscreen: Changed theme to MagicMirror successfully.
                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                      install and setup pm2
                      Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                      [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                      [PM2] PM2 Successfully daemonized
                      [PM2][WARN] Applications MagicMirror not running, starting…
                      [PM2] App [MagicMirror] launched (1 instances)
                      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                      │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4352 │ 0s │ 0 │ online │ 0% │ 2.7mb │ pi │ enabled │
                      [PM2] Saving current process list…
                      [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                      Do you want to disable the screen saver? (y/N)?y
                      xscreensaver running
                      grep: /home/pi/.xscreensaver: No such file or directory
                      bash: line 587: [: !=: unary operator expected
                      We’re ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                      pi@piMirror:~ $ cd MagicMirror/
                      pi@piMirror:~/MagicMirror $ pm2 start MagicMirror
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                      [PM2] MagicMirror ✓
                      [PM2] Process successfully started
                      │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4551 │ 0s │ 1 │ online │ 0% │ 2.7mb │ pi │ disabled │
                        sdetweil @bert269
                        @bert269 said in Bullseye:
                        no worky on node 17
                        • 1 / 5
