    Clock format
    41 Posts 2 Posters 17.4k Views 2 Watching
    • L Offline
      louise @sdetweil
      @sdetweil OH, that’s what you meant by block.
      But as far as changing anything in the code I didn’t, except the 12 and imperial
      L S 2 Replies Last reply Reply Quote 0
      • L Offline
        louise @louise
        @louise
        deleted  sam
          sdetweil @louise
          @louise said in Clock format:
          then u changed something
          NEVER edit the source files… ALL changes go thru config.js
          the design is that things u specify in config.js override thing in the source code… so you NEVER have to touch the source file.
          if you DON’T specify something, then the module default setting will be used…
          (each module should document what that is… )
            sdetweil @louise
            @louise again you are pasting the source code… and missed a step,
            after the paste into the message here, SELECT the text AGAIN, and then push the code button
            we want to see what settings are in config.js for clock, not clock.js
            • L Offline
              louise @sdetweil
              aaaaa
              • L Offline
                louise @louise
                @louise I forgot to take out private stuff again
                  sdetweil @louise
                  @louise nope, still don’t want to see the code
                  edit your ~/MagicMirror/config/config.js
                  find the section that says
                     module:"clock"
                  and copy from the line above that is
                  to the macthing line below
                  that is
                  and paste THAT, and then select it all (ctrl a)
                  and then it the button
                  please read the two topics below in my signature…
                  • L Offline
                    louise @sdetweil
                    @sdetweil This?
                    		module: "clock",
                    		position: "top_left"
                    code_text
                    			module: "clock",
                    code_text
                      sdetweil @louise
                      @louise hmm… still not sure what the problem is
                      select/copy from config.js
                      replay to message here
                      paste text
                      ctrl-a (select all)
                      (it will have my userid in the select of the reply )
                      press code block button
                      I just did this and got
                      @louise
                      			module: "clock",
                      L 2 Replies Last reply Reply Quote 0
                      • L Offline
                        louise @sdetweil
                        @sdetweil Would it be easier if I just started over?
                        • 2 / 5
