    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 66.1k Views 4 Watching
      sdetweil @pastormingle
      @pastormingle
           module:   'MMM-Carousel',
           position: 'bottom_bar',
              whatever config for this module
      • P Offline
        pastormingle @sdetweil
        @sdetweil ```
        So now is gets an Undefined displayed at the bottom of the display..
                        transitionInterval: 10000,
                        ignoreModules: [],
                        mode: 'global'
        ![45d7e7ab-536a-4ba1-b849-c0ba73a9344f-image.png](/assets/uploads/files/1638977941062-45d7e7ab-536a-4ba1-b849-c0ba73a9344f-image.png)
        • P Offline
          pastormingle @pastormingle
          @pastormingle getting the following error in the dev windows now.
          TypeError: Failed to execute ‘appendChild’ on ‘Node’: parameter 1 is not of type ‘Node’.
          at updateModuleContent (main.js:215)
          at main.js:142
          at new Promise ()
          at updateDomWithContent (main.js:140)
          at main.js:122
            @pastormingle this is my config
                        position: "bottom_bar",
                            ignoreModules: ['clock', 'alert'],
                            mode: 'slides',
                            slides: [
                                ['calendar', 'compliments', 'weather'],
                                ['newsfeed'],
            but you wanted slides mode… why are u set to global?
              @pastormingle
              I changed ‘slides’ to ‘global’ and it worked too
              you are using this version
              https://github.com/shbatm/MMM-Carousel.git
              in the MMM-Carousel folder do
              git remote -v
              • P Offline
                pastormingle
                @sdetweil said in MMM-Carousel not displaying:
                git remote -v
                same.
                • mumblebajM Offline
                  mumblebaj Module Developer @pastormingle
                  @pastormingle So, what @sdetweil meant was that in the terminal window in the ~/MagicMirror/modules/MMM-Carousel/ folder you should run the command git remote -v and post the output of that.
                  For me it is:
                  origin  https://github.com/barnabycolby/MMM-Carousel (fetch)
                  origin  https://github.com/barnabycolby/MMM-Carousel (push)
                    sdetweil @mumblebaj
                    @mumblebaj hm… that one also works… (but works without position, but doesn’t have a getDom function)
                    the sabatm version has page indicator buttons u can push too…
                      mumblebaj Module Developer @sdetweil
                      @sdetweil Ah, now I understand the earlier differences. We were looking at different modules. Which one is @pastormingle using?
                        sdetweil @mumblebaj
                        @mumblebaj still waiting for that info
                          @sdetweil Unless there is a 3rd one that we are not aware of…:face_with_monocle:
                            sdetweil @mumblebaj
                            @mumblebaj yeh, I posted a fix to the one I was using, after it stopped working on 2.14
                            https://github.com/shbatm/MMM-Carousel/issues/31
                              @sdetweil And there is this one as well:
                              https://github.com/schramkef/MMM-Carousel
                                sdetweil @mumblebaj
                                @mumblebaj yep, thats the newest… 9months old, shbatm is 3 years, and the barnaby is 5 years old
                                mumblebajM P 2 Replies Last reply Reply Quote 0
                                  @sdetweil Lets see which one he is using. I am off to bed. Been a long day.
                                  • P Offline
                                    pastormingle
                                    • P Offline
                                      @sdetweil so do i need to upgrade my magicmirror ?
                                      • P Offline
                                        pastormingle
                                          @pastormingle you need to get into the MMM-Carousel folder
                                          cd ~/MagicMirror/modules/MMM-Carousel
                                          git remote -v
                                            @pastormingle no, shouldn’t have to
                                            that error is typically from bad position:
                                            • 3 / 5
