Gesture control with APDS-9960
@sean said in Gesture control with APDS-9960:
PAJ7620u2
no idea as well… waiting on my sensor APDS… once received, i’ll test with your module
I’ve the PAJ7620u2 one.
I’m experiencing some stability issue with it (it always stops working after some minutes) but overall it’s great. I will post about the stability issue later on.I’m interested into how you guys are using the sensor in a "beautiful way).
Before buying it, I thought I could cover it with some “speaker fabric” but it’s not working neither…Do you have some smart ideas on your side on how to hide it?
Regards
@bolish i thought about it meantimes i am waiting for delivery… i was thinking to make a kind of slot in one of the wooden frame side, just enough to make so that the wood layer is so thin that i hope it will let pass the gesture but it will be difficult to do as my mirror is already build now and i can’s say for now if it will work. if you come up with another idea… feel free to share
@bolish that’s exactly what i was thinking but thx for the recommendations… i will even not try an attempt then. i wanted smt “beautiful” as you mentioned but without seeing the sensor…
hmm i’ll think about smt or maybe i’ll check another solution as voice command… with jarvis -
Did you ever get the APDS-9960 working with MM? I happen to have one, would keep me from ordering something else.
@wishmaster270 , Sweet! Thanks!!
