    Gesture control with APDS-9960
    18 Posts 8 Posters 13.6k Views 10 Watching
      broberg Project Sponsor
      Well, It doesn’t work through the glass. But it works!
      and it’s somewhat sensitive to get the motions right, maybe that is a software issue and not hardware, BUT it does read side to side and up down. Which is good and opens up to navigate modules easier.
      But it bugs me that I have to build a box for it outside the mirror.
        Okey guys, I’d really need some guidance. My head goes round in circles and I don’t know where to start.
        As mentioned before I’ve gotten the sensor to work with the help of wiringPi and a c library converted for the pi.
        Then I Found this : https://github.com/jiahuang/apds-gesture
        a control driver for node, but that is using a Tessel and I can’t really understand how to replace the tessel line with Raspberry.
        I’m guessing I need an i2c module to let the apds-gesture connect to the raspberrys pins?
          bibi @broberg
          @broberg did you find any suitable solution or stopped your project?
            broberg Project Sponsor @bibi
            @bibi It’s on hold, the big drawback is that I haven’t included space for any sensor in the frame, so any addon would “stick out” and look wonky.
            So maybe I’ll just add some physical buttons and make a tree style menu instead.
              bibi @broberg
              @broberg yea haven’t neither think about room for it while building my one… :smiling_face_with_open_mouth_cold_sweat:
                A Former User
                I’m not sure whether it is compatible with APDS-9960, but I made a module for GroveGesture Sensor(PAJ7620u2 compatible)
                https://github.com/eouia/MMM-GroveGestures
                2.1.0 demo
                  bibi
                  @sean said in Gesture control with APDS-9960:
                  PAJ7620u2
                  no idea as well… waiting on my sensor APDS… once received, i’ll test with your module :thumbs_up_medium-light_skin_tone:
                    bolish
                    I’ve the PAJ7620u2 one.
                    I’m experiencing some stability issue with it (it always stops working after some minutes) but overall it’s great. I will post about the stability issue later on.
                    I’m interested into how you guys are using the sensor in a "beautiful way).
                    Before buying it, I thought I could cover it with some “speaker fabric” but it’s not working neither…
                    Do you have some smart ideas on your side on how to hide it?
                    Regards
                      bibi @bolish
                      @bolish i thought about it meantimes i am waiting for delivery… i was thinking to make a kind of slot in one of the wooden frame side, just enough to make so that the wood layer is so thin that i hope it will let pass the gesture but it will be difficult to do as my mirror is already build now and i can’s say for now if it will work. if you come up with another idea… feel free to share :)
                        bolish
                        @bibi
                        I’ve already made some trials with 1mm thin wood. Forget about it.
                        You will find the product data sheet with some recommandation at the bottom of below page :
                        link text
                        I’ve tried behing 2mm wood, with a hole (3mm diameter), it works fine. Not so ugly…
                        Let’s see.
                        Regards
                          bibi @bolish
                          @bolish that’s exactly what i was thinking but thx for the recommendations… i will even not try an attempt then. i wanted smt “beautiful” as you mentioned but without seeing the sensor…
                          hmm i’ll think about smt or maybe i’ll check another solution as voice command… with jarvis
                          • W Offline
                            wifibum
                            Did you ever get the APDS-9960 working with MM? I happen to have one, would keep me from ordering something else.
                            • wishmaster270W Offline
                              wishmaster270 Module Developer @bibi
                              @bibi I am using an Apds sensor with other sensors on a Arduino connected to the pi via serial interface. I documented it and wrote a universal module to receive messages on the serial interface. You can find my documentation at Examples
                              • W Offline
                                wifibum @wishmaster270
                                @wishmaster270 , Sweet! Thanks!!
