    Gesture control with APDS-9960
    18 Posts 8 Posters 12.7k Views 10 Watching
    • brobergB Offline
      broberg Project Sponsor
      Okey guys, I’d really need some guidance. My head goes round in circles and I don’t know where to start.
      As mentioned before I’ve gotten the sensor to work with the help of wiringPi and a c library converted for the pi.
      Then I Found this : https://github.com/jiahuang/apds-gesture
      a control driver for node, but that is using a Tessel and I can’t really understand how to replace the tessel line with Raspberry.
      I’m guessing I need an i2c module to let the apds-gesture connect to the raspberrys pins?
        bibi @broberg
        @broberg did you find any suitable solution or stopped your project?
        • brobergB Offline
          broberg Project Sponsor @bibi
          @bibi It’s on hold, the big drawback is that I haven’t included space for any sensor in the frame, so any addon would “stick out” and look wonky.
          So maybe I’ll just add some physical buttons and make a tree style menu instead.
            bibi @broberg
            @broberg yea haven’t neither think about room for it while building my one… :smiling_face_with_open_mouth_cold_sweat:
              A Former User
              I’m not sure whether it is compatible with APDS-9960, but I made a module for GroveGesture Sensor(PAJ7620u2 compatible)
              https://github.com/eouia/MMM-GroveGestures
              2.1.0 demo
                bibi
                @sean said in Gesture control with APDS-9960:
                PAJ7620u2
                no idea as well… waiting on my sensor APDS… once received, i’ll test with your module :thumbs_up_medium-light_skin_tone:
                  bolish
                  I’ve the PAJ7620u2 one.
                  I’m experiencing some stability issue with it (it always stops working after some minutes) but overall it’s great. I will post about the stability issue later on.
                  I’m interested into how you guys are using the sensor in a "beautiful way).
                  Before buying it, I thought I could cover it with some “speaker fabric” but it’s not working neither…
                  Do you have some smart ideas on your side on how to hide it?
                  Regards
                    bibi @bolish
                    @bolish i thought about it meantimes i am waiting for delivery… i was thinking to make a kind of slot in one of the wooden frame side, just enough to make so that the wood layer is so thin that i hope it will let pass the gesture but it will be difficult to do as my mirror is already build now and i can’s say for now if it will work. if you come up with another idea… feel free to share :)
                      bolish
                      @bibi
                      I’ve already made some trials with 1mm thin wood. Forget about it.
                      You will find the product data sheet with some recommandation at the bottom of below page :
                      link text
                      I’ve tried behing 2mm wood, with a hole (3mm diameter), it works fine. Not so ugly…
                      Let’s see.
                      Regards
                        bibi @bolish
                        @bolish that’s exactly what i was thinking but thx for the recommendations… i will even not try an attempt then. i wanted smt “beautiful” as you mentioned but without seeing the sensor…
                        hmm i’ll think about smt or maybe i’ll check another solution as voice command… with jarvis
