    Gesture control with APDS-9960
    18 Posts 8 Posters 12.7k Views 10 Watching
      bolish
      @bibi
      I’ve already made some trials with 1mm thin wood. Forget about it.
      You will find the product data sheet with some recommandation at the bottom of below page :
      link text
      I’ve tried behing 2mm wood, with a hole (3mm diameter), it works fine. Not so ugly…
      Let’s see.
      Regards
        bibi @bolish
        @bolish that’s exactly what i was thinking but thx for the recommendations… i will even not try an attempt then. i wanted smt “beautiful” as you mentioned but without seeing the sensor…
        hmm i’ll think about smt or maybe i’ll check another solution as voice command… with jarvis
        • W Offline
          wifibum
          Did you ever get the APDS-9960 working with MM? I happen to have one, would keep me from ordering something else.
          • wishmaster270W Offline
            wishmaster270 Module Developer @bibi
            @bibi I am using an Apds sensor with other sensors on a Arduino connected to the pi via serial interface. I documented it and wrote a universal module to receive messages on the serial interface. You can find my documentation at Examples
            • W Offline
              wifibum @wishmaster270
              @wishmaster270 , Sweet! Thanks!!
