    Gesture control with APDS-9960
    18 Posts 8 Posters 12.4k Views 10 Watching
    • brobergB Offline
      broberg Project Sponsor
      Since my plan of using a touchfoil blew up in my face due to my own stupid assumptions. I have to look in to other means of controlling my mirror. (No, a IR-frame is sadly not an option due to the shape and size of my mirror.)
      Searching here there is one Gesture module (MMM-Swipe) that uses the HC-SR04 ultrasonic sensor,
      It’s a cheap sensor and most of the work is done, so I have ordered one of those too.
      The cons are however that is limited to three inputs, left, right and “push”.
      The APDS-9960 Sensor ( https://www.sparkfun.com/products/12787 ) However has also swipe up/down,
      and it’s a optical sensor, so with a smidge of luck, it might work behind the glass (not counting on it though).
      Bad thing is the range is only 10-20cm above (without anything in it’s way), so basically has to swipe on the mirror itself.
      And, the APDS isn’t MM2 ready, it isn’t really raspberry ready either so it would probably require some long nights tinkering for me. So if the first tests are a success I might need some help getting the sensor to work with the MM2.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @broberg
        @broberg looking forward to your results
        i think this could be also interesting http://www.exp-tech.de/pimoroni-skywriter-hat-3d-gesture-sensor-raspberry-pi
        • brobergB Offline
          broberg Project Sponsor @strawberry 3.141
          @strawberry-3.141 Yeah I saw that one to when I was looking around,
          It works basically on the same principle as the touch foil I have besides me right now, so anything of metal would disrupt it I think, (I’m really hopeful the optical sensor will work through the mirror glass)
          • cowboysdudeC Offline
            cowboysdude Module Developer @broberg
            @broberg Let us all know if it does :)
            • brobergB Offline
              Well, It doesn’t work through the glass. But it works!
              and it’s somewhat sensitive to get the motions right, maybe that is a software issue and not hardware, BUT it does read side to side and up down. Which is good and opens up to navigate modules easier.
              But it bugs me that I have to build a box for it outside the mirror.
              • brobergB Offline
                Okey guys, I’d really need some guidance. My head goes round in circles and I don’t know where to start.
                As mentioned before I’ve gotten the sensor to work with the help of wiringPi and a c library converted for the pi.
                Then I Found this : https://github.com/jiahuang/apds-gesture
                a control driver for node, but that is using a Tessel and I can’t really understand how to replace the tessel line with Raspberry.
                I’m guessing I need an i2c module to let the apds-gesture connect to the raspberrys pins?
                  bibi @broberg
                  @broberg did you find any suitable solution or stopped your project?
                  • brobergB Offline
                    broberg Project Sponsor @bibi
                    @bibi It’s on hold, the big drawback is that I haven’t included space for any sensor in the frame, so any addon would “stick out” and look wonky.
                    So maybe I’ll just add some physical buttons and make a tree style menu instead.
                      bibi @broberg
                      @broberg yea haven’t neither think about room for it while building my one… :smiling_face_with_open_mouth_cold_sweat:
                        A Former User
                        I’m not sure whether it is compatible with APDS-9960, but I made a module for GroveGesture Sensor(PAJ7620u2 compatible)
                        https://github.com/eouia/MMM-GroveGestures
                        2.1.0 demo
