    MMM-PIR-Sensor
    9 Posts 5 Posters 1.7k Views 5 Watching
      Jon4s
      Im having trouble with de MMM-PIR-Sensor module.
      I installed it accordingly the documentation of the MMM-PIR-Sensor module.
      However i get this message, i checked and the file does exist in that map.
      FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
      • FoziF Offline
        Fozi Project Sponsor @Jon4s
        @jon4s Are you running Bulls Eye? If so, then it won’t work (see https://github.com/paviro/MMM-PIR-Sensor/issues/123).
        Obviousl you should stick with Buster.
        J 1 Reply Last reply Reply Quote -1
          Jon4s @Fozi
          @fozi said in MMM-PIR-Sensor:
          Bulls Eye
          I’m not sure if i am running bullseye, How can i check this?
            sdetweil @Jon4s
            @jon4s do
            lsb_ release -a
              Jon4s @sdetweil
              thanks indeed i run buster.
              Im gonna check to downgrade
                sdetweil @Jon4s
                @jon4s buster is ok, bullseye not
                  Jon4s @sdetweil
                  @Fozi @sdetweil and everybody else
                  So i’m running buster now,
                  And after some issues the MM turns on with the PIR sensor connected.
                  However, when the screen turns black and goes into the powersaving mode after the amount of seconds i put in.
                  powerSavingDelay: 30,
                  In the the example after 30 seconds, but i’ve tried 5 and 60 also. The problem remains and the screen doesn’t turn back on.
                  I use the command
                  tvservice -p
                  Via ssh to turn the screen back on again, after that it doesn’t goes into saving again.
                  I tried different pins already and i’m stuck again :(
                  I’m not using a condensator, coz lots of tutorials don’t use those,
                  Any thoughts what i can do to make the sensor work?
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @Jon4s
                    @jon4s try this one instead:
                    MMM-NewPIR
                    This one works great!!! Works on Pi3 and Pi4
                    bugsounetB 1 Reply Last reply Reply Quote 0
                    • bugsounetB Offline
                      bugsounet Banned @cowboysdude
                      @cowboysdude :/ :angry_face:
