    MMM-OralB / Bluetooth equipped toothbrush integration
    68 Posts 13 Posters 41.9k Views 20 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @timodejong95
      @timodejong95 Hi Timo,
      since I really want to have the battery status I am currently trying to use the front end code with noble as backend in node_helper. Your backend code and all the GATT bluez stuff is much too complicated for me.
      Also, I have done some tweaks on the frontend:
      • Hide timer after some time
      • convert time to m:ss
      • also count on beyond 2 minutes (circle is filled after 2 Minutes)
      • make timer bright and circle blue when the brush is running and dim it back again if it is not running.
      Like it very much. Very simple tweaks in the main.js. Let me know if you want to see any of it.
      Also, two brushes work perfectly! :ok_hand:
      Impressive work man!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • T Offline
        timodejong95
        Thanks I really appreciate that! Yeah sure I am willing to refactor it a bit, if needed, and make it a configurable option.
        Again sorry for deleting the repo, I pushed wit the wrong git user (work one). I saw that you starred/forked it.
        Can you show me the changes or make a PR?
        The GATT is a bit bugged I am not sure why but the services are not resolving. I am trying to fix that and I think that after that the battery status should be that hard anymore.
        • T Offline
          timodejong95
          This post is deleted!
          • lavolp3L Offline
            I can’t PR to your new repo, so here’s the code from MMM-BluetoothDevices.js:
            /*jshint esversion: 6 */
            //'use strict';
            Module.register('MMM-BluetoothDevices', {
              // Default module config.
              defaults: {
                mode: 'le',
                hci: 'hci0',
                interfaceName: 'org.bluez.Adapter1',
                services: [
                  { type: 'CurrentTimeService' },
                devices: [],
                layout: {
                  title: {
                    position: 'bottom',
                    key: 'name',
                  data: {
                    position: 'bottom',
                    fields: [
                      { key: 'mode', text: 'mode' },
                hideAfter: 10 * 60,
              getStyles() {
                return ['MMM-BluetoothDevices.css'];
              // Override dom generator.
              getDom() {
                const wrapper = document.createElement('div');
                wrapper.classList.add('toothbrushes');
                if (this.loading) {
                  wrapper.innerHTML = 'Loading...';
                  wrapper.className = 'light small';
                  return wrapper;
                const table = document.createElement('table');
                const row = document.createElement('tr');
                for (const deviceKey in this.devices) {
                  const deviceType = this.devices[deviceKey].device.type;
                  if (deviceType === 'OralBToothbrush') {
                    row.appendChild(this.renderToothbrush(deviceKey));
                  } else {
                    throw new Error(`Unknown device type: ${deviceType}`);
                table.appendChild(row);
                wrapper.appendChild(table);
                return wrapper;
              renderToothbrush(deviceKey) {
                const device = this.devices[deviceKey];
                const deviceTd = document.createElement('td');
                deviceTd.classList.add('toothbrush');
                deviceTd.style.textAlign = "center";
                const deviceCircle = document.createElement('div');
                deviceCircle.classList.add('toothbrush-circle-container');
                deviceCircle.classList.add(`toothbrush-circle-${device.data.state}`);
                const deviceCircleText = document.createElement('div');
                deviceCircleText.classList.add('toothbrush-circle-text');
                const deviceCircleSvg = document.createElementNS('http://www.w3.org/2000/svg', 'svg');
                deviceCircleSvg.classList.add('toothbrush-circle-ring');
                const deviceCircleSvgCircle = document.createElementNS('http://www.w3.org/2000/svg', 'circle');
                deviceCircleSvgCircle.classList.add('toothbrush-circle');
                deviceCircleSvgCircle.setAttribute('stroke-width', 15);
                deviceCircleSvgCircle.setAttribute('fill', 'transparent');
                deviceCircleSvgCircle.setAttribute('r', 52);
                deviceCircleSvgCircle.setAttribute('cx', 60);
                deviceCircleSvgCircle.setAttribute('cy', 60);
                deviceCircleSvg.append(deviceCircleSvgCircle);
                deviceCircle.append(deviceCircleSvg);
                deviceCircle.append(deviceCircleText);
                //const time = device.data.time > 120 ? 120 : device.data.time;
                const time = device.data.time;
                // initial start
                this.updateCircle(deviceCircleSvgCircle, deviceCircleText, time);
                if (device.data.state === 'running') {
                  deviceTd.style.display = 'block';
                  deviceCircleText.classList.add('bright');
                  deviceCircleSvgCircle.setAttribute('stroke', '#0080fe');
                  this.counters[deviceKey] = {
                    time,
                    interval: setInterval(() => {
                      this.counters[deviceKey].time += 1;
                      this.updateCircle(
                        deviceCircleText,
                    }, 1000),
                } else {
                  deviceCircleText.classList.remove("bright");
                  deviceCircleSvgCircle.setAttribute('stroke', '#aaa');
                  setInterval(() => {
                    deviceTd.style.display = "none";
                  }, this.config.hideAfter * 1000);
                const deviceLabel = document.createElement('div');
                deviceLabel.classList.add('title');
                deviceLabel.classList.add('small');
                deviceLabel.innerText = device.device[this.config.layout.title.key];
                const dataContainer = document.createElement('div');
                dataContainer.classList.add('small');
                dataContainer.classList.add('light');
                for (const key in this.config.layout.data.fields) {
                  const data = this.config.layout.data.fields[key];
                  const field = document.createElement('div');
                  field.innerText = `${data.key}: ${device.data[data.key]}`;
                  dataContainer.appendChild(field);
                if (this.config.layout.title.position === 'top') {
                  deviceTd.appendChild(deviceLabel);
                if (this.config.layout.data.position === 'top') {
                  deviceTd.appendChild(dataContainer);
                deviceTd.appendChild(deviceCircle);
                if (this.config.layout.title.position === 'bottom') {
                if (this.config.layout.data.position === 'bottom') {
                return deviceTd;
              updateCircle(deviceCircleSvgCircle, deviceCircleText, time) {
                var secs = time % 60;
                deviceCircleText.innerText = Math.floor(time / 60) + ":" + (secs < 10 ? "0" + secs : secs);
                const radius = parseInt(deviceCircleSvgCircle.getAttribute('r'));
                const circumference = radius * 2 * Math.PI;
                if (time > 120) { time = 120; }
                const percent = (100 / 120) * time;
                const offset = circumference - percent / 100 * circumference;
                deviceCircleSvgCircle.style.strokeDasharray = `${circumference} ${circumference}`;
                deviceCircleSvgCircle.style.strokeDashoffset = offset;
              start() {
                Log.info(`Starting module: ${this.name}`);
                this.devices = {};
                this.counters = {};
                this.loading = true;
                this.sendSocketNotification('FETCH_TOOTHBRUSHES', this.config);
              socketNotificationReceived(notification, payload) {
                if (notification === 'FETCH_TOOTHBRUSHES_RESULTS') {
                  Log.info('MMM-Toothbrush: Got toothbrush results');
                  this.devices = payload;
                  for (const counterKey in this.counters) {
                    const counter = this.counters[counterKey];
                    clearInterval(counter.interval);
                  if (this.loading) {
                    this.loading = false;
                    this.updateDom(1000);
                  } else {
                    this.updateDom(0);
            it’s also in the develop branch of my module
            • T Offline
              timodejong95
              @lavolp3 Thanks, I will have a look at that this weekend.
              Also managed to connect to the services and characteristics. But how did you know the one you needed?
              Because you only connecting to the 3th key in the services array and a hardcoded uuid for the characteristics. I am curious how you find the one you needed.
              • lavolp3L Offline
                @timodejong95 I used this gitlab snippet. Don’t remember how I got there. I guess from the homeassistant forum which is also working on that.
                For more follow-up see my post in this thread
                When I use bluetoothctl on my RasPi I am getting lots of output form the brush recently. I’m not sure why exactly, maybe because my Pi is coupled with the brush.
                Primary Service
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050
                        a0f0ff20-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070
                        a0f0ff2b-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070/desc0072
                        00002901-0000-1000-8000-00805f9b34fb
                        Characteristic User Description
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d
                        a0f0ff2a-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d/desc006f
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a
                        a0f0ff29-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a/desc006c
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067
                        a0f0ff28-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067/desc0069
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064
                        a0f0ff27-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064/desc0066
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061
                        a0f0ff26-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061/desc0063
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e
                        a0f0ff25-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e/desc0060
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b
                        a0f0ff24-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b/desc005d
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058
                        a0f0ff23-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058/desc005a
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055
                        a0f0ff22-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055/desc0057
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051
                        a0f0ff21-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0054
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0053
                        00002902-0000-1000-8000-00805f9b34fb
                        Client Characteristic Configuration
                Primary Service
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e
                        a0f0ff00-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c
                        a0f0ff0d-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004f
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004e
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048
                        a0f0ff0c-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004b
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004a
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044
                        a0f0ff0b-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0047
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0046
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040
                        a0f0ff0a-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0043
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0042
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c
                        a0f0ff09-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003f
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003e
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038
                        a0f0ff08-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003b
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003a
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034
                        a0f0ff07-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0037
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0036
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030
                        a0f0ff06-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0033
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0032
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c
                        a0f0ff05-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002f
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002e
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028
                        a0f0ff04-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002b
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002a
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025
                        a0f0ff03-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025/desc0027
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022
                        a0f0ff02-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022/desc0024
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f
                        a0f0ff01-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f/desc0021
                Primary Service
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010
                        a0f0fff0-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b
                        a0f0fff4-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b/desc001d
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018
                        a0f0fff3-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018/desc001a
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015
                        a0f0fff2-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015/desc0017
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011
                        a0f0fff1-5047-4d53-8208-4f72616c2d42
                        Vendor specific
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0014
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0013
                Primary Service
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c
                        00001801-0000-1000-8000-00805f9b34fb
                        Generic Attribute Profile
                Characteristic
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d
                        00002a05-0000-1000-8000-00805f9b34fb
                        Service Changed
                Descriptor
                        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d/desc000f
                Do we have to look into one of these characteristics/desricptors for the value?
                • lavolp3L Offline
                  lavolp3 Module Developer @lavolp3
                  @lavolp3 Well according to the gitlab code we’re looking for this:
                  Characteristic
                          Vendor specific
                  Descriptor
                  Descriptor
                  The characteristic is the one the referenced noble code is filtering for.
                  Now GO Timo!
                  Make brushing great again!
                  • T Offline
                    timodejong95 @lavolp3
                    @lavolp3
                    Haha thanks man.
                    I have made some big changes, improved connecting devices, GATT service, characteristics and some more. I have also managed to get the battery value, but I have an issue: after around 15-30 seconds after connection successfully to the device the connection drops:
                    {"ServicesResolved":false,"Connected":false}
                    I haven’t figured out why this happens, all the normal data is still received. Only the battery status not, it needs to be connected. I haven’t push anything to the repo yet. First I want to look if I can get it working (fully).
                    Are you experiencing the same with noble or can you get the battery status after 30 seconds or 1 minute plus?
                    I keep you updated.
                    • T Offline
                      timodejong95
                      I have been debugging it and it seems that the devices is ‘just’ being disconnected:
                      HCI Event: Disconn Complete (0x05) plen 4
                          status 0x00 handle 64 reason 0x13
                          Reason: Remote User Terminated Connection
                      I do not know why :/
                      • T Offline
                        timodejong95
                        @lavolp3 Oke I have pushed some changes, see: https://github.com/timodejong95/MMM-BluetoothDevices. Don’t forget npm install.
                        I updated the configuration see docs. You need to add a track key to the device config with the value ‘battery’:
                        example:
                        devices: [
                          { type: 'OralBToothbrush', name: 'oralb', mac: 'xxx', tracks: ['battery'], format: 'formatted' },
                        It’s still a bit buggy let me know what your experience is!
                        lavolp3L 1 Reply Last reply Reply Quote 1
                        • lavolp3L Offline
                          @timodejong95 No luck yet.
                          No Battery status to be seen and this error in the logs
                          0|mm       | [2020-04-20 01:21:08.432] [ERROR]  01:21:08 <error> (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                          0|mm       |     --> starting at object with constructor 'DBusObject'
                          0|mm       |     |     property 'proxy' -> object with constructor 'Object'
                          0|mm       |     |     property 'org.freedesktop.DBus.Introspectable' -> object with constructor 'DBusInterface'
                          0|mm       |     --- property '$parent' closes the circle
                          0|mm       |     at JSON.stringify (<anonymous>)
                          0|mm       |     at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/index.js:24:25
                          0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                          0|mm       | [2020-04-20 01:21:08.435] [ERROR]  01:21:08 <error> (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                          • T Offline
                            @lavolp3 Damm ashame, could you post the logs above the error? If correct there should be 2 more error logs, and just to be sure it still works when you remove the battery track, right?
                            D lavolp3L 2 Replies Last reply Reply Quote 0
                              djerik @timodejong95
                              @timodejong95
                              I have removed the module, installed again and added the extra piece of configuration. The updated UI is working fine, but there is no battery indicator. Is this the log you are looking for?
                              [2020-04-22 19:40:43.278] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:40:43.389] [LOG] MMM-BluetoothDevices trying to connect to: OralB 1/2
                              [2020-04-22 19:40:53.451] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:40:53.673] [LOG] MMM-BluetoothDevices trying to connect to: OralB 2/2
                              [2020-04-22 19:40:59.444] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:41:10.482] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:41:13.767] [ERROR] MMM-BluetoothDevices unhandled exception:
                              [2020-04-22 19:41:13.771] [ERROR] MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded
                              [2020-04-22 19:41:13.774] [ERROR] MMM-BluetoothDevices {“troubleshooting”:“devices#resolve-services”,“extra”:{}}
                              [2020-04-22 19:41:21.451] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:41:32.477] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:41:43.546] [LOG] MMM-BluetoothDevices received device update for OralB
                              [2020-04-22 19:41:54.482] [LOG] MMM-BluetoothDevices received device update for OralB
                              • lavolp3L Offline
                                @timodejong95 there are no logs above that.
                                I get this error before I started the brush
                                [2020-04-23 00:19:17.258] [ERROR]  00:19:17 <error> MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                [2020-04-23 00:19:17.263] [ERROR]  00:19:17 <error> MMM-BluetoothDevices Error: Error: Couldn't connect to BABSIS OralB after 2 tries. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                [2020-04-23 00:19:17.277] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                                [2020-04-23 00:19:17.284] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                                [2020-04-23 00:19:17.289] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:19:17.293] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:19:17.296] [ERROR]  00:19:17 <error> (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:19:17.299] [ERROR]  00:19:17 <error> (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:23:44.731] [LOG]    00:23:44 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:23:47.096] [LOG]    00:23:47 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:23:57.944] [LOG]    00:23:57 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:24:08.935] [LOG]    00:24:08 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:24:19.917] [LOG]    00:24:19 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:24:30.925] [LOG]    00:24:30 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:24:41.961] [LOG]    00:24:41 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:24:52.927] [LOG]    00:24:52 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:25:03.965] [LOG]    00:25:03 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:25:14.860] [LOG]    00:25:14 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:25:25.926] [LOG]    00:25:25 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:25:36.875] [LOG]    00:25:36 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:25:47.877] [LOG]    00:25:47 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                [2020-04-23 00:25:58.907] [LOG]    00:25:58 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                This error vanishes when I deactivate the JSON.stringify function.
                                I have the feeling that everything is working, but the battery is not showing up at all.
                                Also, when closing the mirror (ctrl+c when I started it with npm start dev ) I get these errors:
                                [2020-04-23 00:38:03.482] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
                                    at Dongle.disconnectDevices (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:223:28)
                                    at Dongle.destroy (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:58:17)
                                    at Class.stop (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:46:23)
                                    at App.stop (/home/pi/MagicMirror/js/app.js:252:16)
                                    at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:108:7)
                                    at App.emit (events.js:200:13) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:38:03.486] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
                                [2020-04-23 00:38:03.489] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:38:03.495] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:38:03.503] [ERROR]  00:38:03 <error> (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                [2020-04-23 00:38:03.509] [ERROR]  00:38:03 <error> (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                • lavolp3L Offline
                                  @timodejong95
                                  https://makandracards.com/makandra/28847-dealing-with-typeerror-converting-circular-structure-to-json-on-javascript
                                  • lavolp3L Offline
                                    and more debugging messages, sorry for the spamming:
                                    [2020-04-23 00:51:53.902] [LOG]    00:51:53 <log> MMM-BluetoothDevices starting hub (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:23 Class.startHub)
                                    [2020-04-23 00:51:58.845] [LOG]    00:51:58 <log> MMM-BluetoothDevices unhandled adapter msg: {"serial":1536,"path":"/org/bluez/hci0","interface":"org.freedesktop.DBus.Properties","member":"PropertiesChanged","signature":"sa{sv}as","sender":":1.8","type":4,"flags":1,"body":["org.bluez.Adapter1",[["UUIDs",[[{"type":"a","child":[{"type":"s","child":[]}]}],[["00001112-0000-1000-8000-00805f9b34fb","00001801-0000-1000-8000-00805f9b34fb","0000110e-0000-1000-8000-00805f9b34fb","00001800-0000-1000-8000-00805f9b34fb","00001200-0000-1000-8000-00805f9b34fb","0000110c-0000-1000-8000-00805f9b34fb","0000110a-0000-1000-8000-00805f9b34fb","0000111f-0000-1000-8000-00805f9b34fb","00001805-0000-1000-8000-00805f9b34fb"]]]]],[]]} (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                    [2020-04-23 00:52:01.474] [LOG]    00:52:01 <log> MMM-BluetoothDevices unhandled adapter msg: {"serial":1542,"path":"/org/bluez/hci0","interface":"org.freedesktop.DBus.Properties","member":"PropertiesChanged","signature":"sa{sv}as","sender":":1.8","type":4,"flags":1,"body":["org.bluez.Adapter1",[["Discovering",[[{"type":"b","child":[]}],[true]]]],[]]} (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                    [2020-04-23 00:52:01.993] [LOG]    00:52:01 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/2 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:52:13.667] [LOG]    00:52:13 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:52:13.834] [LOG]    00:52:13 <log> MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                    [2020-04-23 00:52:17.445] [LOG]    00:52:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:52:23.028] [LOG]    00:52:23 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:52:33.871] [ERROR]  00:52:33 <error> MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                    [2020-04-23 00:52:33.875] [ERROR]  00:52:33 <error> MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                    [2020-04-23 00:52:33.905] [LOG]    00:52:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:52:44.875] [LOG]    00:52:44 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:52:55.859] [LOG]    00:52:55 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:53:06.911] [LOG]    00:53:06 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:53:17.884] [LOG]    00:53:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    [2020-04-23 00:53:28.849] [LOG]    00:53:28 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                    • T Offline
                                      @lavolp3 No worries, check I will have a look at this when I find some time, probably this weekend. Seems that the devices couldn’t connect at the first try but failed in de second which is triggered instantly.
                                      @djerik Thanks for sharing
                                      I will try and fix the issues you send to be, thanks for sharing and excuses for the bugs! I might write some tests because the manual tests are stacking up and code coverage is always good.
                                      • lavolp3L Offline
                                        @timodejong95 said in MMM-OralB / Bluetooth equipped toothbrush integration:
                                        I don’t have a problem with that. Devices are connecting well as soon as I activate them. Everything works really well except no battery status shown.
                                        Apparently the waitForService process ends unresolved, hence is not able to get the information from the battery service
                                        [2020-04-23 00:52:33.875] [ERROR]  00:52:33  MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                        • T Offline
                                          @lavolp3 Check I get you. Just to be sure, you did do npm install I changed a package? If not then I will comeback to it when I have tested it myself.
                                          • lavolp3L Offline
                                            Yes I did.
                                            Did it now again (but no new installations) and trying again tonight
                                            • 3 / 4
