    MMM-Gas Still Working?
    18 Posts 6 Posters 6.1k Views 5 Watching
      Mykle1 Project Sponsor Module Developer @sifuhall
      @sifuhall said in MMM-Gas Still Working?:
      Could you try for zipcode 40391 and see if that works for you? Maybe there are just no results?
      I tested your zip code and the typeGas options. Everything seems to work fine. I’m sure cowboysdude will get you sorted
      I see he a;ready left some suggestions. Follow those and see what you get
        sdetweil @cowboysdude
        @cowboysdude but the quotes would be a mm config.js syntax error. so that’s not it
        • strawberry 3.141S Offline
          @sifuhall I just tried it with your config and it didn’t show up either.
          I then noticed that the repository is called MMM-GAS, but the files and config are MMM-Gas. After renaming the directory of the module to MMM-Gas it was working fine.
          If you followed the git clone command in the read me file it already has the correct directory name, but if you know how to clone a repo or copied the git clone command provided by Github itself then you probably have the same issue.
          sifuhallS cowboysdudeC 2 Replies Last reply Reply Quote 2
          • sifuhallS Offline
            sifuhall @strawberry 3.141
            @strawberry-3-141
            That fixed it! Thank you!
            I copied and pasted the clone command from Github and had no idea why it would not work.
            Thanks again!
            • cowboysdudeC Offline
              cowboysdude Module Developer @strawberry 3.141
              @strawberry-3-141 Thank you!!! I have fixed that issue on Github!!!
                cowboysdude Module Developer @sifuhall
                @sifuhall I wouldn’t have found that because I ran it on my dev machine which is windows which doesn’t care about case… linux, raspberry pi does!!
                Glad it’s working!! Sorry about the mix up…
                sifuhallS Mykle1M 2 Replies Last reply Reply Quote 0
                • sifuhallS Offline
                  sifuhall @cowboysdude
                  @cowboysdude
                  Thank you for the help and the great module. I can see how that would happe,
                    Mykle1 Project Sponsor Module Developer @cowboysdude
                    @cowboysdude
                    That’s weird. I downloaded from the repo onto ubuntu and everything was fine. Module folder and module name were fine, MMM-Gas. 2 days ago, that is.
