    MMM-Gas Still Working?
    18 Posts 6 Posters 9.3k Views 5 Watching
    • sifuhallS
      sifuhall @sifuhall
      @sifuhall
      Just an FYI this is the output of my npm start dev
      > magicmirror@2.18.0 start
      > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
      [23.02.2022 17:38.54.232] [LOG]   Starting MagicMirror: v2.18.0
      [23.02.2022 17:38.54.235] [LOG]   Loading config ...
      [23.02.2022 17:38.54.973] [LOG]   Starting node_helper for module [MMM-MyScoreboard]
      [23.02.2022 17:38.55.215] [LOG]   Starting node helper: MMM-json
      [23.02.2022 17:38.55.216] [LOG]   Started node_helper.js for MMM-DailyBibleVerse.
      [23.02.2022 17:38.58.075] [INFO]  [MMM-DynamicWeather] Getting Holiday data
      [23.02.2022 17:38.58.101] [INFO]  [MMM-DynamicWeather] Getting Weather API data
      [23.02.2022 17:38.58.284] [LOG]   Notification: MMM_JSON_REQUEST Payload: {
          url: 'http://192.168.1.50:8079',
          refreshInterval: 300000,
          styleRules: [],
          values: [ [Object], [Object], [Object], [Object], [Object] ]
        identifier: 'module_7_MMM-json'
      [23.02.2022 17:38.58.295] [LOG]   MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
      [23.02.2022 17:38.58.602] [DEBUG] Response {
        [Symbol(Body internals)]: {
          body: PassThrough {
            _readableState: [ReadableState],
            _events: [Object: null prototype],
            _eventsCount: 5,
            _maxListeners: undefined,
            _writableState: [WritableState],
            allowHalfOpen: true,
            [Symbol(kCapture)]: false,
            [Symbol(kCallback)]: null
          stream: PassThrough {
            _eventsCount: 5,
          boundary: null,
          disturbed: false,
          error: null
        [Symbol(Response internals)]: {
          type: 'default',
          url: 'http://192.168.1.50:8079/',
          status: 200,
          statusText: 'OK',
          headers: {
            connection: 'close',
            'content-type': 'text/html; charset=UTF-8',
            date: 'Wed, 23 Feb 2022 22:38:58 GMT',
            server: 'nginx',
            'transfer-encoding': 'chunked'
          counter: 0,
          highWaterMark: 16384
      [23.02.2022 17:38.58.778] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
      [23.02.2022 17:38.59.204] [INFO]  [MMM-DynamicWeather] Received successful Holiday data
      [23.02.2022 17:38.59.254] [LOG]   {"votd":{"text":"“Do not those who plot evil go astray? But those who plan what is good find love and faithfulness.”","content":"Do not those who plot evil go astray? But those who plan what is good find love and faithfulness.","display_ref":"Proverbs 14:22","reference":"Proverbs 14:22","permalink":"https:\/\/www.biblegateway.com\/passage\/?search=Proverbs%2014:22&version=NIV","copyright":" ","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&vid=31&lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Prov.14.22","day":"23","month":"02","year":"2022","version":"New International Version","version_id":"NIV","merchandising":""}}
      • karsten13K
        karsten13 @sifuhall
        @sifuhall
        try items: 10,
        • cowboysdudeC
          cowboysdude Module Developer @sifuhall
          @sifuhall said in MMM-Gas Still Working?:
          mid-grade
          I can come up with possibly 2 problems…
          Either npm install wasn’t run in the MMM-Gas module directory OR
          if you copied the example config from github quotes do not copy correctly.
          So go in and wherever there is a quote ’ or " delete them and from your own keyboard redo them ’ or "…
          Let me know.
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @sifuhall
            Could you try for zipcode 40391 and see if that works for you? Maybe there are just no results?
            I tested your zip code and the typeGas options. Everything seems to work fine. I’m sure cowboysdude will get you sorted
            I see he a;ready left some suggestions. Follow those and see what you get
              sdetweil @cowboysdude
              @cowboysdude but the quotes would be a mm config.js syntax error. so that’s not it
              • strawberry 3.141S
                @sifuhall I just tried it with your config and it didn’t show up either.
                I then noticed that the repository is called MMM-GAS, but the files and config are MMM-Gas. After renaming the directory of the module to MMM-Gas it was working fine.
                If you followed the git clone command in the read me file it already has the correct directory name, but if you know how to clone a repo or copied the git clone command provided by Github itself then you probably have the same issue.
                sifuhallS cowboysdudeC 2 Replies Last reply
                Reply Quote 2
                • sifuhallS
                  sifuhall @strawberry 3.141
                  @strawberry-3-141
                  That fixed it! Thank you!
                  I copied and pasted the clone command from Github and had no idea why it would not work.
                  Thanks again!
                  • cowboysdudeC
                    cowboysdude Module Developer @strawberry 3.141
                    @strawberry-3-141 Thank you!!! I have fixed that issue on Github!!!
                    • cowboysdudeC
                      @sifuhall I wouldn’t have found that because I ran it on my dev machine which is windows which doesn’t care about case… linux, raspberry pi does!!
                      Glad it’s working!! Sorry about the mix up…
                      sifuhallS Mykle1M 2 Replies Last reply
                      • sifuhallS
                        sifuhall @cowboysdude
                        @cowboysdude
                        Thank you for the help and the great module. I can see how that would happe,
                        • Mykle1M
                          @cowboysdude
                          That’s weird. I downloaded from the repo onto ubuntu and everything was fine. Module folder and module name were fine, MMM-Gas. 2 days ago, that is.
