    v2.19.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 4.3k Views 1 Watching
    • MichMichM Offline
      MichMich
      [2.19.0] - 2022-04-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.19.0
      Special thanks to the following contributors: @10bias, @CFenner, @JHWelch, @k1rd3rf, @khassel, @kolbyjack, @krekos, @KristjanESPERANTO, @Nerfzooka, @oraclesean, @oscarb, @philnagel, @rejas, @sdetweil, @shin10, @SiderealArt and @Tom-Hirschberger.
      Added
      • Added a config option under the weather module, absoluteDates, providing an option to format weather forecast date output with either absolute or relative dates.
      • Added test for new weather forecast absoluteDates porperty.
      • The modules get a class hidden added/removed if they get hidden/shown which will also toggle pointer-events.
      • Added new config option showTitleAsUrl to newsfeed module. If set, the diplayed title is a link to the article which is useful when running in a browser and you want to read this article.
      • Added internal cors proxy to get weather providers working without public proxies (fixes #2714). The new url http(s)://address:port/cors?url=https://whatever-to-proxy can be used in other modules too.
      • Added a WeatherProvider for Weatherflow.
      • Added new env var ELECTRON_DISABLE_GPU which disable gpu under electron if set (fixes #2831).
      • Added missing Czech translations.
      Updated
      • Deprecated roboto fonts package roboto-fontface-bower replaced with fontsource.
      • Update electron to v17, helmet to v5 (use defaults of v4) and other dependencies
      • Updates Font Awesome css class to new default style (fixes #2768)
      • Replaced deprecated modules currentweather and weatherforecast with dummy modules only displaying that they have to be replaced.
      • Include all calendar events from the configured date range when broadcasting.
      • Update Danish and German translation.
      • Update node-ical to v0.15 and added luxon as dependency for not breaking the “no-optional” install (see #2718 and #2824).
      Fixed
      • Improved and speedup e2e tests, artificial wait after mm start removed.
      • Improved husky setup not blocking git commit if husky or npm is not installed.
      • Using a consistent spelling of MagicMirror².
      • Fix minor console output issue for loading translations (#2814).
      • Don’t adjust startDate for full day events if endDate is in the past.
      • Fix windspeed conversion error in openweathermap provider. (#2812)
      • Fix conflicting parms turning off showEnd for full day events. (#2629)
      • MichMichM MichMich locked this topic on
