    Magic mirror is not showing up
    37 Posts 4 Posters 15.4k Views 4 Watching
    • C Offline
      CoopDog1712
      when i try to start the magic mirror using pm2 start mm.sh, it says “Starting /home/pi/mm.sh in fork_mode (1 instance)”
      and then it says
      “Done”
      and then table that this looks like this shows up
      id │ name │ mode │ ↺ │ status │ cpu │ memory │
      │ 0 │ mm │ fork │ 0 │ online │ 0% │ 2.4mb
      then nothing happens. I have watched countless videos about the whole prossess and i do everything that they do, but after the enter pm2 start mm.sh the table shows up and then the magic mirror page shows up. i dont know what to do
        sdetweil @CoopDog1712
        @CoopDog1712 ok, best thing is to use my script to set it up…
        see
        last script on the page
        but in the meantime
        pm2 stop all
        pm2 logs --lines=50
        to see what is going on
        does executing mm.sh work by itself?
        pm2 is really picky… if there is a batch (bash) script, then it MUST be named mm.sh just mm won’t work.
        then pm2 delete 0
        pm2 save -f
        then run my fixuppm2.sh script
        C 2 Replies Last reply Reply Quote 0
        • C Offline
          CoopDog1712 @sdetweil
          @sdetweil thank you so much for replying I really appreciate your help.
          On the table that shows up, I see that one of the names is just mm, how would I change it to mm.sh. Also when I run your script all it does is create a new Id on the table, called MagicMirror and it dosent seem to do anything
          • C Offline
            @sdetweil!
            https://share.icloud.com/photos/09aR5ulFMM0L4v-vHL3NDBRNA
              @CoopDog1712 you can’t change and entry, but you can delete it
              pm2 delete 0 or pm2 delete mm
              pm2 logs --lines=50 might tell us what us going on
              pm2 is a command
              pm2 --help will show you all the things you can do
              ps, you can attach pics here… the third icon from the right above the editor here
                @CoopDog1712 i couldnt see much of that image
                • C Offline
                  after typing in pm2 logs --lines=50, all that is coming up is a repeating of these couple lines
                    @CoopDog1712 yes, sometimes, the install messes up
                    pm2 stop all
                    cd ~/MagicMirror
                    npm install electron@17.2.0
                    to test
                    cd ~/MagicMirror
                    npm start
                    if all looks good
                    ctrl-c to stop
                    then
                    pm2 start MagicMirror
                    I should have asked, what pi is this on ? not pi 0 w, right?
                    • C Offline
                      @sdetweil no its a pi 4
                      • C Offline
                        @sdetweil so it works now, and after i enter pm2 start MagicMirror, it loads the software for the magic mirror, the only issue is that their is nothing only a blank screen, no time, weather, nothing. all that comes up is a blank screen. any suggestions?
                          @CoopDog1712 have u added modules?
                          if so see
                          and
                          pm2 logs --lines=50
                          will show you what is happening
                          • C Offline
                            @sdetweil i did what you said and this is what came up.
                            pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm init -y
                            Wrote to /home/pi/MagicMirror/modules/default/clock/package.json:
                            “name”: “clock”,
                            “version”: “1.0.0”,
                            “description”: “The clock module is one of the default modules of the MagicMirror². This module displays the current date and time. The information will be updated realtime.”,
                            “main”: “clock.js”,
                            “scripts”: {
                            “test”: “echo "Error: no test specified" && exit 1”
                            “keywords”: [],
                            “author”: “”,
                            “license”: “ISC”
                            pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm install ???
                            npm ERR! code EINVALIDTAGNAME
                            npm ERR! Invalid tag name “???”: Tags may not have any characters that encodeURIComponent encodes.
                            npm ERR! /home/pi/.npm/_logs/2022-04-24T14_06_36_382Z-debug-0.log
                            pi@raspberrypi:~/MagicMirror/modules/default/clock $ pm2 start MagicMirror
                            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 4 ])
                            [PM2] MagicMirror ✓
                            [PM2] Process successfully started
                              @CoopDog1712 no… not in clock module… we ship that
                              what was the black screen failure message from the console output?
                              you read the messages and get the name of the missing library, and replace the ??? with that name
                              the reason YOU have to read the messages is because there are multiple libraries missing…
                              you only need to fix the ones that impact the modules you installed
                              • C Offline
                                @sdetweil i dont think i saw one. i never installed any modulles, even the ones that should come with it are not showing up
                                  @CoopDog1712 ok, still show the messages where u start mm
                                  either via
                                  npm start
                                  or
                                  pm2
                                  if pm2., then
                                  pm2 logs --lines=50
                                  will show the console output
                                  what pi is this?
                                  • C Offline
                                    @sdetweil pi 4
                                    • C Offline
                                        @CoopDog1712 ah yes, fun times…
                                        do
                                        pm2 stop all
                                        cd ~/MagicMirror
                                        npm start
                                        mm should come up
                                        minimize mm (alt-spacebar, n)
                                        ctrl-c to stop running instance
                                        then
                                        pm2 status
                                        this will show the status or pm2 managed apps.
                                        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                        │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
                                        use the name or the row number
                                        pm2 start xxx
                                        xxx is the name or the row number
                                        for example
                                        pm2 start 0
                                        • C Offline
                                          @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
                                          then i did start pm2 start 4, and it started, but was still a blank screen
                                            @CoopDog1712 says something is still running…
                                            you didn’t do pm2 stop all
                                            after doing test
                                            ps -ef | grep -i magicmirror
                                            should return nothing
