    MMM-CalendarExt3
    679 Posts 82 Posters 2.7m Views 86 Watching
      mike23pizzo @sdetweil
      @sdetweil when I start MM it says Starting MagicMirror: v2.21.0.
      When you mention that it’s only set before the calendars list, do you mean as long as it’s listed in the config on the default calendar it should feed down to MMM-CalendarExt3?
      EDIT: It seems the past events are now showing. I didn’t change anything in the config file, so I’m not quite sure what fixed it. But as of now they are there.
        sdetweil @mike23pizzo
        @mike23pizzo yes, in the common calendar config not with each calendar/url entry
        glad it’s working… past events can be a big pile
        I see just fromm 2015
          DDE12
          My events are displayed in reverse chronological order in mode: “week”. Where is the setting the for this? I can post the config.js settings if necessary.
            MMRIZE @DDE12
            @DDE12
            Only in week mode, does that symptom happen?
            What’s your environment? (Platform, OS, Browser)
              DDE12 @MMRIZE
              @MMRIZE
              Occurs in week and month modes. I am using Windows 10 and Firefox. I just tested it in Edge to see and it is in the correct order. I also looked at it Pale Moon browser (Firefox like fork) and it shows the date and reversed chrono order, but no time.
                MMRIZE @DDE12
                @DDE12 @sfb
                Firefox has different behaviours with Chromium-based browsers(Chrome, Edge, Whale, …) in sorting algorithms.
                The quick fix is to add eventSorter to your config for MMM-CalendarExt3 module.
                // In your MMM-CalendarExt3 module config
                eventSorter: null,
                Related issue : https://forum.magicmirror.builders/post/103041
                This will be fixed on next update.
                  MMRIZE @DDE12
                  @DDE12
                  For the displaying date and not-time issue;
                  I don’t know about the Pale Moon browser detail. It seems it has its own JavaScript Engine but is not compatible with current mainstream JS. It is still being developed prematurely, so many features which other browsers have are not implemented yet.
                  I found it on its homepage
                  It looks like Intl object(which is used to format date and time on this module) is not implemented fully yet.
                    DDE12 @MMRIZE
                    @MMRIZE
                    Thanks! eventSorter fixed it in Firefox and it corrected the order in Pale Moon. Personally, I’m not too concerned about the date thing in Pale Moon. I just thought I would try MM there and see what it looked like.
                    • K Offline
                      katalopapi
                      I’m a noob…
                      I’m trying to create a MM for my wife. I want to display my family calendar in cx3 but I’m having troubles.
                      I’m using mmm-googleCalendar to access my family calendar and you can see it’s working when displayed in the bottom right but for some reason won’t display in cx3:
                      Here’s my config:
                      Any ideas what I’m doing wrong? TIA
                        sdetweil @katalopapi
                        @katalopapi CX3 depends on the calendar module broadcasting the events it read. soCX3 doesn’t read the cal itself.
                        I don’t know if mmm-googlecalendar does the broadcast
                        u can setup the default calendar and not give it a position, but have it broadcast events
                        • 18
                        • 19
                        • 20
                        • 21
                        • 22
                        • 67
                        • 68
                        • 20 / 68
