    Problem with Google generated .ics link
    30 Posts 2 Posters 11.1k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      I am running two calendars, the standard one out of the box and then a second instance but have my personal Google calendar in the url.
      When it tries to load that url I get several errors, starting with this. I’ve done this numerous times in past. Google creates an ics link, you plug it in to URL slot and everything worked but not now.
      [24.04.2022 19:05.23.694] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/group.calendar.google.com/private-yadayada/basic.ics RangeError: Invalid time value
      at Date.toISOString (<anonymous>)
      at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
      at Array.forEach (<anonymous>)
      at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
      at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
      at processTicksAndRejections (node:internal/process/task_queues:96:5)
        sdetweil @ankonaskiff17
        @ankonaskiff17 could u post one of the vevents from the ICS file?
        curl -sL   whatever_url  >xxx.ics
        xxx.ics is a text file
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil said in Problem with Google generated .ics link:
          What were you either expecting or hoping to see?
          Looks like a bunch of my calendar entries in like csv (or similar) format.
          I had earlier dropped link in MS Edge and it opened the Google calendar but in the MS Edge default calendar applet or whatever they call those bare bones apps
            @ankonaskiff17
            pick a
            BEGIN:VEVENT
            END:VEVENT
            change whatever is personal, dont change the date info please
            this is the format the calendar module passes to the parser…
            its needs to be in a specific format
            u don’t want a calendar tool to display it, we need to look at the raw text…
            (I spent 8 months in there solving all kinds of problems., and with the parser too)
              @sdetweil I’m not worried about personal stuff in this one so you got complete.
              BEGIN:VEVENT
              DTSTART:20200512T124500Z
              DTEND:20200512T134500Z
              DTSTAMP:20220424T235526Z
              UID:74o68d9k61hj4b9pckom6b9kccsj2bb1cdgj6bb370sj0dpk6k
              CREATED:20210216T015059Z
              DESCRIPTION:
              LAST-MODIFIED:20210216T015059Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:X-Ray & MRI
              TRANSP:OPAQUE
              END:VEVENT
              ankonaskiff17A S 2 Replies Last reply Reply Quote 0
                ankonaskiff17 @ankonaskiff17
                @ankonaskiff17 I know historically it would post my calendar info as a list, identical to the US Holiday link
                  @ankonaskiff17 ok, we need to see which one is causing the problem… so edit config.js and change loglevel like this
                  logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"], // Add "DEBUG" for even more logging
                  then run MM like this
                  cd ~/MagicMirror
                  npm start >somefile.txt
                  wait for cal to come up
                  ctrl-c to end MM
                  then examine someflle.txt
                  u may need to send me the file
                  same userid at gmail. I don’t share
                    my event looks like this
                    BEGIN:VEVENT
                    DTSTART:20220126T150000Z
                    DTEND:20220126T210000Z
                    DTSTAMP:20220425T000759Z
                    UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com
                    CREATED:20220111T023256Z
                    DESCRIPTION:
                    LAST-MODIFIED:20220111T023256Z
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:drive to ft stockton
                    TRANSP:OPAQUE
                    END:VEVENT
                      @sdetweil Check your email
                        @ankonaskiff17 replied
                          @sdetweil Sent another email. Do you want copy of log files referenced in terminal
                            @ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
                              @ankonaskiff17 i think this dropping is power control…
                              there is a commandline to turn power control for wifi off
                              I have the same problem on a pi 0 2 w (one of 3)
                                @sdetweil Every device in home is fine but laptop.
                                2nd HP I’ve had this happen to.
                                  @ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
                                    @ankonaskiff17 My mistake starting over fresh
                                      @ankonaskiff17 I rebooted pi, MM launched did pm2 stop all,
                                      got back to MM directory and did npm start and that is ugly. Line after line of the word NULL, then a mish mash of garbage tthen saw VEVENT related to holiday calendar but MM crashed in among all that.
                                        @ankonaskiff17 @sdetweil check email for sample
                                          ull,null,null,null,null,null,null,null,null,null,null,null]
                                          [24.04.2022 21:25.05.341] [DEBUG] event.recurrences: undefined
                                          [24.04.2022 21:25.05.359] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/c/basic.ics RangeError: Invalid time value
                                          at Date.toISOString ()
                                          at Array.forEach ()
                                          S ankonaskiff17A 2 Replies Last reply Reply Quote 0
                                            @ankonaskiff17 i replied to email
