Help with config file
Can anyone tell me what I did wrong with my config file? Anywhere you see ### is where I removed personal data.
var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "clock", position: "top_left'" config: { timeFormat: 12, displaySeconds: true, showPeriod: true, showDate: true, displayType: "digital", timezone: "America/New_York", }, { module: "calendar", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "###" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "###", locationID: "###", //ID from http://www.openweathermap.org appid: "###", roundTemp: true, showPeriod: true, showPeriodUpper: true, showHumidity: true, } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "###", locationID: "###", //ID from http://www.openweathermap.org appid: "###", roundTemp: true, showRainAmount: true, colored: trtue, } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "The Atlantic", url: "https://www.theatlantic.com/feed/best-of/", }, { title: "BBC World", url: "feeds.bbci.co.uk/news/world/rss.xml", } ], showSourceTitle: true, showPublishDate: true, showDescription: true, } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@sullivnc
There is a curly brace missing in the config field of the clock module. -
Like this :)
{ module: "clock", position: "top_left'" config: { timeFormat: 12, displaySeconds: true, showPeriod: true, showDate: true, displayType: "digital", timezone: "America/New_York", } }, -
The position line for the clock module is also wrong, it should be like this:
position: "top_left",I recommend that you use a lint tool (e.g. eslint) to do syntax checking. It will find most of the errors.
Thanks guys, appreciate the help.
