    Core installation fails
    6 Posts 3 Posters 4.9k Views 3 Watching
    • M
      MyMirror
      i’m freshly new to rasp and the Project and was happy to find a core package to install.
      But … after starting the auto-install i’ll get an error:
      grunt-yamllint@0.2.0 requires a per of grunt@-0.4.0 but None was installed
      Unable to install dependencies
      Whats wrong? Something in the package or did i have to install something manually?
      Greets
      • cowboysdudeC
        cowboysdude Module Developer
        Howdy…
        Did you follow these instructions?
        https://github.com/MichMich/MagicMirror
        • M
          MyMirror
          i did it once more from the scratch. With a new sd-card formatted and a new jessy download.
          Now it works - nearly :-)
          I follow These steps:
          but i didn’t have a calender on the right.
          And if i have Trouble to update “git”?
          From here
          i’ve tried
          git pull && npm install
          with result:
          fatal: Not a git repository (or any of the parent directories): .git
          So …
          do i have a git repository?
          Where should i go (Directory)?
          Which repository is the right one?
          Thanks for help!
          cowboysdudeC 1 Reply Last reply
          • M
            MyMirror
            okay … wrong dir
            i’ve to go to “MagicMirror”
            Step by step i’ll reach the finish line (hopefully :-))
            • cowboysdudeC
              cowboysdude Module Developer @MyMirror
              @MyMirror said in Core installation fails:
              git pull
              It’s like this …
              git clone https://github.com/MichMich/MagicMirror.git
              Then go to the directory it’s in [MagicMirror]
              then do your ‘npm install’
              You’re right!! You’ll get this :) When I started I had similar problems… now I’m learning how to write modules
              • A
                amanzimdwini
                THIS is the setup that worked GREAT for me:
                https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                Really - even someone like me could not mess it up.
                Reply Quote 1
