    Default Weather module still not displaying
    39 Posts 6 Posters 19.8k Views 6 Watching
    • Jarhead96097J Offline
      Jarhead96097
      After upgrading to 2.20.0, the default Weather module has stopped displaying. I finally had some time and rebuilt my MM, reusing the same config.js. Unfortunately, I’m still receiving the “Uncaught SyntaxError: Unexpected token” error on line 159 of weather.js. Here’s my config.js with personal data xxxx’d out:
      			module: "weather",
      			disabled: false,
      			classes: "daytime_scheduler",
      				initialLoadDelay: 3000,
      				type: "current",
      				apiKey: "XXXX6abf89276a4b3cc00cfbcca7XXXX",
      				apiBase: "http://api.openweathermap.org/data/",
      				weatherEndpoint: "/weather",
      				locationID: 5574093,
      				degreeLabel: true,
      				updateInterval: 1800000,
      				//lat: "XX.XXXX70",    //used for troubleshooting with other providers
      				//lon: "-1XX.XXXX10",
      				appendLocationNameToHeader: true,
      				showLocationAsHeader: true,
      				showWindDirection: true,
      				showHumidity: true,
      Any ideas on what to do are appreciated in advance!
      Jarhead96097
        sdetweil @Jarhead96097
        @Jarhead96097 please never do audit… causes more problems than it fixes
        Jarhead96097J 1 Reply Last reply Reply Quote 2
        • O Offline
          OldSunGuy
          The only thing I noticed was you’re trying to use http and the default is https for the apiBase.
          Weather Options
          Jarhead96097J 1 Reply Last reply Reply Quote 1
            Jarhead96097 @OldSunGuy
            @OldSunGuy thanks… I didn’t make any changes to the script before updating to 2.20.0 , but I changed to https. Unfortunately, it didn’t make a difference. Neither the current nor the forecast weather module instances are showing, and I’m still receiving the “Uncaught SyntaxError: Unexpected token.” error on line 159 of weather.js. And of course, I haven’t changed anything in weather.js.
            Any other ideas? I appreciate your time!
            Jarhead96097
              @Jarhead96097 remove all the options except
              apiKey
              and
              locationID
              default type is current
              default provider is openweathermap
                Jarhead96097 @sdetweil
                @sdetweil thanks… Well, no change. I’ve tried that and also copied the portion of the weather module from the original config.js, which was renamed as config.js.sample during setup. Both attempts still result in the Unexpected Syntax Error: Unexpected token message coming from line 159 of weather.js.
                You’re always very helpful, thanks for your time. Any other ideas?
                Jarhead96097
                  @Jarhead96097
                  ok, I just did this
                  			module: "weather",
                  				locationID: "361058",
                  				apiKey: "xxxxx"
                  try that with your openweathermap apiKey
                    @sdetweil no luck. Still receiving the same error on line 159, and no display on the MM.
                    Jarhead96097
                    S B 2 Replies Last reply Reply Quote 0
                      @Jarhead96097
                      this is on pi, or windows, or ??
                      ok, do this
                      cd ~/MagicMirror
                      rm -rf node_modules
                      npm install
                      #added
                      git checkout modules/default/weather/weather.js
                      git status
                      then try again
                      S Jarhead96097J 2 Replies Last reply Reply Quote 1
                        Blackeye @Jarhead96097
                        @Jarhead96097 Could be the comma after “true” on the last line of config … not necessary, and causes an error when I run a :check
                          @Jarhead96097
                          I added a command above to restore the original weather.js from the git repo
                          Jarhead96097J 1 Reply Last reply Reply Quote 0
                            @sdetweil I added “npm audit fix” as there was 1 high severity vulnerability found. It didn’t solve the vulnerability (didn’t try “npm audit fix --force”), and I’m getting the same error.
                            Jarhead96097
                            S mumblebajM 2 Replies Last reply Reply Quote 0
                              @sdetweil Oh, okay. Let me try that updated string of commands…
                              Jarhead96097
                                • mumblebajM Offline
                                  mumblebaj Module Developer @Jarhead96097
                                  @Jarhead96097 Rule of thumb is to never run npm audit fix.
                                    sdetweil @mumblebaj
                                    @mumblebaj and we have found npm install parms to turn off the warning coming in next release, and already in my scripts.
                                    mumblebajM 1 Reply Last reply Reply Quote 2
                                      mumblebaj Module Developer @sdetweil
                                      @sdetweil That’s great
                                        @sdetweil Good to know…that may be the root cause of all of this. After rebuilding my MM on 2.20.0, I did the npm audit fix. If we can’t get to a resolution in the next few minutes, I’ll chalk this up to a learning experience and do another rebuild.
                                        Jarhead96097
                                        • O Offline
                                          OldSunGuy
                                          May I ask how you are using
                                          Are there two instances of
                                          daytime_scheduler
                                          I use
                                          classes: “currentweather”
                                          type: “current”
                                          and
                                          classes: “weatherforcast”
                                          type: “forecast”
                                          to replace the deprecated modules.
                                            @Jarhead96097 use my install script
                                            see
                                              Jarhead96097 @Jarhead96097
                                              @sdetweil “On branch master,” and up to date with origin/master. I also meant to reply earlier that this is on a RPI 4B. Unfortunately, still getting the same error and the weather module is not displaying information.
                                              I appreciate everyone’s time…but I’m going to cut to the chase and rebuild using your install script.
                                              Thanks again for the time, you’re always very helpful, and I appreciate it.
                                              Jarhead96097
