    MMM-WeatherGraph - new module using OpenWeatherMap
    15 Posts 6 Posters 8.6k Views 7 Watching
    • FlatPepsiF Offline
      FlatPepsi
      https://github.com/FlatPepsi17/MMM-WeatherGraph
      I have a new weather module with current conditions, rain graph for 48 hours, and a 7 day forecast list.
      Sample screenshots showing different configurations:
      Basic setup, showing rain & snow:
      Metric options, and a 24hr precip graph:
      Love data? Turn everything on to see temp, wind speed, humidity, and cloud cover.
      Prefer something minimal? Turn off any feature you want.
      This module started as a fork of ‘MMM-forecast.io’ by dmcinnes (https://github.com/dmcinnes/MMM-forecast-io), adding many new features and moving to a new data source since DarkSky discontinued API access. (Thanks Apple- so nice of you.)
      S FlatPepsiF 3 Replies Last reply Reply Quote 2
        sdetweil @FlatPepsi
        @FlatPepsi very nice
          sdetweil @FlatPepsi
          @FlatPepsi can u have multiple instances loaded w different configs?
          FlatPepsiF 1 Reply Last reply Reply Quote 0
            FlatPepsi @sdetweil
            Good question. I haven’t tried it- but I’d imagine it would work. Biggest thing to watch is hitting the API’s limit for pulling forecast data, so turn that down accordingly.
              sdetweil @FlatPepsi
              @FlatPepsi yeh. API limits are a pain…
              but you have to code for multiple instances
              • N Offline
                nixdg
                Im new and just setting up my first MM and found your module. I get accurate info with the stock module, but get a constant Loading Weather when I have your module in place. Any thoughts as to why it is not loading?
                  JoeFranz
                  Same here, still loading…
                    sdetweil @nixdg
                    @nixdg @JoeFranz ‘Loading…’, is the default message put up while waiting for data…
                    in my opinon, modules SHOULD (but don’t) report errors to the user instead of leaving the Loading… message up
                    so, the data api calls have failed for some reason…
                    this module does all its work in the browser so, lets look in the developer window console for any clues
                    ctrl-shift-i,
                    select the console tab
                    and put some unique part of the module name in the filter field
                    weatherg
                    and report what you see
                      JoeFranz
                      Nothing changed and now it works :-)
                      Maybe it took a while for the API key to work
                        sdetweil @JoeFranz
                        @JoeFranz there are call limits… 100 /day I think…
                          FlatPepsi @FlatPepsi
                          @FlatPepsi So I finally added an option I wanted, but never got around to doing. I originally wanted this module to let me know if I needed to get up early and shovel the driveway… which means I want daily precipitation totals handy.
                          Now it’s available as an option!
                          The latest code can be found on GitHub. Let me know if you find any bugs. Precipitation totals use inches or mm/cm, following the existing Imperial/Metric setting.
                          Enjoy!
                          S FlatPepsiF 2 Replies Last reply Reply Quote 1
                            sdetweil @FlatPepsi
                            @FlatPepsi very cool!
                              Pushed out a fix today…
                              Most weather sources give snow in the liquid equivalent, thus you need to multiply by 10 for snow.
                              Turns out OpenWeather does this math for us, and I was over estimating the snow by a factor of 10. Today I’m expecting 1.6" of snow & ice, module was saying 16" - prompting today’s fix!
                              Fixed.
                              • MarosM Offline
                                Maros
                                Hi, great module. Is it possible to change the white between temperatures to f.e. “/” ?
                                also is it possible to add “C” to temperature ? so it will show °C
                                  bbbeat
                                  I’m getting an error, could not load datan TypeError: forecast is not iterable.
                                  Do you know what might be wrong?
                                  I checked and the API key is valid
