    upgrade to new NPM version?
    11 Posts 4 Posters 4.4k Views 4 Watching
    • kaiK Offline
      kai
      Hi there,
      thank you all very much for looking after the MM and keeping it alive and developing it further.
      The update to version 2.21.0 was successful, no problems, everything is fine! :thumbs_up:
      I only have one question: I got a hint saying that there is a new NPM version. Can I stay on my current version 6.14.12 or should I upgrade to 8.19.2?
      Thank you very much!
      May the code be with you
      -kai
        sdetweil @kai
        @kai don’t worry about that … we do not depend on NPM v8
        kaiK 1 Reply Last reply Reply Quote 0
        • kaiK Offline
          kai @sdetweil
          @sdetweil cool, thanks a lot!
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @kai
            Since 6.14.12 there have been a lot of bug fixes, so an upgrade is recommended. And MM works fine with 8.19.2.
              sdetweil @KristjanESPERANTO
              @KristjanESPERANTO if they are running fine, no reason to upgrade. when a new mm release comes that needs a new node or npm, then my script will upgrade that too
              • E Offline
                eltonnascimento @sdetweil
                @sdetweil how to update npm version?my MM is on the last version, but my raspian already has a better version of npm than my Magic mirror, but my MM doesnt see that.
                  sdetweil @eltonnascimento
                  @eltonnascimento sudo npm i npm@version-numnumber
                  note that I may have to npm install in every module folder that has a package.json and the base
                  I would ignore the message.
                  my upgrade script will be upgraded to install npm 8 on the next release (jan, 1)
                  • E Offline
                    @sdetweil I ran the command sudo npm i npm@8.19 inside the /MagicMirror folder, but it didn’t update the npm version. then I ran the command npm install inside MMM-Tools, without success.
                    Ashampoo_Snap_sexta-feira, 28 de outubro de 2022_08h26m03s_003_.png Ashampoo_Snap_sexta-feira, 28 de outubro de 2022_08h24m40s_002_.png
                    do you have any other tips?
                      @eltonnascimento but it did. npm is 8 now
                      • E Offline
                        @sdetweil but the MM-Tools module, indicates that npm is v6.14.12…as in the first picture above. I already did the npm install inside the MMM-Tools directory as well.
                          @eltonnascimento I don’t know about mmm-tools.
                          you don’t install npm in any folder
                          -g means global
                          ah I forgot the -g
                           sudo npm i -g npm@version_number
