    [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons
    25 Posts 3 Posters 9.8k Views 2 Watching
    • wishmaster270W
      wishmaster270 Module Developer
      Description:
      Need a MagicMirror² module which is able to display information which is send by a other module like MMM-MQTTbridge or MMM-CommandToNotification?
      The information is provided as a simple message or as an JSON-Object?
      You want to re-format the message before displaying it or want to select single values within the JSON-Object?
      You need more than one instance and do want to style the instances different?
      Do you want to style the elements or change displayed icons based on thresholds?
      Do you want some elements to only be visible if a certain profile is active?
      Then this is the module you need!
      BUT i think i created a monster. The configuration can be very tricky!
      Screenshots:
      Download:
      Download
      [card:Tom-Hirschberger/MMM-ValuesByNotification]
      Version 0.1.6
      • bumped version of jsonpath-plus library to 10.3.0
      Version 0.1.5
      • bumped version of jsonpath-plus library to 10.1.0
      Version 0.1.4
      • it is possible to set the reuseCount on group level now
      Version 0.1.3
      • added a postinstall script which creates a copy of the imported JSONPath library cause MagicMirror only imports files with ending js and not cjs to fix JSONPath
      Version 0.1.2
      • bumped jsonpath-plus library to version 10.0.1
      • do not log every received notification anymore
      • be more verbose if debug is enabled and the value format fails
      Version 0.1.1
      • Reverted the jsonpath-plus dependency upgrade (used version is 5.1.0 now) cause version 7.2.0 only worked with the newest MagicMirror version (2.24.0)
      • fixed a bug which caused empty values to be converted to html and causing a exception in this process
      • introduce a debug config flag which causes some more information being printed to console if enabled
      Version 0.1.0
      • Each time a value is reused the values html elements get two classes added. The one configured with the new config option reusedClass (default: “reused”) and the config option prefixed by a “-” and the count of reuses.
      • Updated the jsonpath-plus dependency to version 7.2.0. As this required a change to the import of the module this is a breaking change.
      Version 0.0.10
      • Introducing a feature to define own functions to transform the values (valueTransformers). Added a example to values documentation
      • Changed the way titles, values and units are converted the html elements
      • Added a new option called unitSpace to prefix the unit with a non-breakable space
      Special thanks to @BKeyport for contribution
      Version 0.0.9
      • fixed a bug which caused selected JSON values with value 0 being interpreted as not existing and replaced by naValue
      Version 0.0.8
      • fixed a bug which caused values not being formatted if values before format are not of type String
      • fixed a bug which caused newline replacement called even if no valueFormat was set
      Version 0.0.7
      • added new option valueNaPositions which defines the positions of title, value, unit and icon of the value elements if naValue is used
      • added support to override valuePositions by threshold configurations (will override valueNaPositions, too!)
      Version 0.0.6
      • only the first element of a jsonpath result is used now
      • if html is added as value which contains more than one html element they are wrapped in a span now
      Version 0.0.5
      • added support of Iconify icons
      • all CSS definitions are now prefixed with the modules main class (MMM-ValuesByNotification)
      Version 0.0.4
      • fixed handling of new line characters in notifications; new lines will be replaced now before handling the values (default is a single space, see newlineReplacement option)
      • fixed classes not bubbling up correctly
      • added a flowercare example
      Version 0.0.3
      • if searching the value with “jsonpath” fails the “naValue” will be set now
      • added a new option “formatNaValue” which controls if the naValue should be formatted as the regular are
      Version 0.0.2
      • Only classes which are added by thresholds are now set to higher (wrapper) elements if “letClassesBubbleUp” is set to “true”
      Version 0.0.1
      • Display values received as payload of notifications either as String or JSON Object
      • Select single values with Jsonpath within the JSON objects
      • Re-format the values with javascript functions (see valueFormat option)
      • Group the values in items and groups and add titles and/or icons to the wrappers
      • Re-order the elements in the wrappers based on position definition strings
      • Filter elements based on the current active profile (MMM-ProfileSwitcher)
      • Add classes or change icons based on thresholds reached by the values
      Cr4z33C BKeyportB 2 Replies Last reply Reply Quote 1
      • Cr4z33C
        Cr4z33 @wishmaster270
        @wishmaster270 soooo I gave a deep reading at your readme, but I am not quite sure whether I can already insert my MQTT based power meter with your first release or not? :slightly_smiling_face:
        • wishmaster270W
          wishmaster270 Module Developer @Cr4z33
          @Cr4z33
          the short answer: Yes it can, maaayyyybee?
          Does your powermeter send the data via MQTT already?
          Do you have the MMM-MQTTbridge module configured to connect to your MQTT broker, subscribe for the topic(s) and send the data via notification?
          How does the data look like? Is it plain text or is it a JSON object?
          If it is JSON how is the data structured and which values do you want to display?
          Cr4z33C 1 Reply Last reply Reply Quote 1
          • Cr4z33C
            @wishmaster270 said in [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons:
            Yes
            Nope, but I will set it up as soon as I finish posting this reply! :thumbs_up_light_skin_tone:
            I’ve got Zigbee2MQTT running in a Docker and if I look at its logs it shows lines like
            Zigbee2MQTT:info  2022-10-04 15:45:08: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":645,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
            Zigbee2MQTT:info  2022-10-04 15:45:10: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":610,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
            I want to display the power value.
            • wishmaster270W
              @Cr4z33
              Should be no problem:
              MMM-MQTTbridge/dict/mqttDictionary.js:
              var mqttHook = [
                  mqttTopic: "zigbee2mqtt/BTicino F20T60A",
                  mqttPayload: [
                      payloadValue: "",
                      mqttNotiCmd: ["POWERMETER"],
                      mqttPayload: ""
              var mqttNotiCommands = [
                  commandId: "POWERMETER",
                  notiID: "POWERMETER_VALUES",
              module.exports = { mqttHook,  mqttNotiCommands};
              config.js:
              			module: "MMM-ValuesByNotification",
                                              updateInterval: 60,
                                              reuseCount: 5,
              				groups: [
              						items: [
              								notification: "POWERMETER_VALUES",
              								itemTitle: "Power",
              								values: [
              										valueUnit: "W",
              										jsonpath: "power",
              Will look like:
              You may want to configure the updateInterval and/or reuseCount to your needs.
              • Cr4z33C
                @wishmaster270 thank you it worked at first try!
                Now I can go on with some aesthetic changes like icons, etc. :D
                • wishmaster270W
                  @Cr4z33
                  Just tested a view things.
                  If you like you can use font awesome icon instead of the title:
                                                  updateInterval: 60,
                                                  reuseCount: 5,
                  				groups: [
                  						items: [
                  								//itemTitle: "Power",
                  								values: [
                  										classes: "power",
                  										valueIcon: "fa fa-bolt",
                  										valueUnit: "W",
                  										jsonpath: "power",
                  custom.css:
                  .vbn .valueIcon.power {
                    color: orange;
                  • Cr4z33C
                    @wishmaster270 thanks I applied that instead.
                    Anyway to add some offset to the module to be aligned with the other modules on the left?
                    • wishmaster270W
                      @Cr4z33
                      sorry i do not understand exactly what you mean
                      Cr4z33C 2 Replies Last reply Reply Quote 0
                      • Cr4z33C
                        @wishmaster270 I wanted to move your module way more to the left so to align it with my other modules (Google Assistant, clock and Spotify).
                        However nevermind as I opted to have your module on top instead. ;)
                        • Cr4z33C
                          @wishmaster270 sorry for bothering you again… :grinning_face_with_sweat:
                          What if I want no border?
                          Would I have to edit the module’s CSS or can I just add something to custom.css?
                          • wishmaster270W
                            @Cr4z33
                            No problem.
                            Simply add
                            .vbn .groupWrapper {
                              border-style: none;
                              padding: 0px;
                            to your custom.css
                            Ps.: Try to never ever edit any files in the module directory (except mentioned in the documentation) as you will get problems with updates in the future otherwise!
                            • Cr4z33C
                              @wishmaster270 exactly what I wanted thanks!
                              • wishmaster270W
                                @Cr4z33
                                If you still want to move the content to the left you can try something like the following in your custom.css:
                                  border-style: none;
                                  padding: 0px;
                                  margin-left: 20px;
                                .vbn .groupsWrapper, .vbn .groupWrapper, .vbn .itemsWrapper, .vbn .valueWrapper {
                                  justify-content: left;
                                  align-items: unset;
                                • BKeyportB
                                  BKeyport Module Developer @wishmaster270
                                  @wishmaster270
                                  Hey, Tom - Trying to use this module to decode the json output by my weatherstation - Like https://forum.magicmirror.builders/topic/17396/json-request-module
                                  What I’m getting from Command to notification module is:
                                  WEATHERLINK {"data":{"did":"001D0A71573B","ts":1675287003,"conditions":[{"lsid":434637,"data_structure_type":1,"txid":1,"temp": 47.4,"hum":52.8,"dew_point": 31.0,"wet_bulb": 38.4,"heat_index": 46.4,"wind_chill": 47.4,"thw_index": 46.4,"thsw_index":null,"wind_speed_last":2.00,"wind_dir_last":31,"wind_speed_avg_last_1_min":2.62,"wind_dir_scalar_avg_last_1_min":6,"wind_speed_avg_last_2_min":2.81,"wind_dir_scalar_avg_last_2_min":358,"wind_speed_hi_last_2_min":5.00,"wind_dir_at_hi_speed_last_2_min":340,"wind_speed_avg_last_10_min":1.43,"wind_dir_scalar_avg_last_10_min":36,"wind_speed_hi_last_10_min":5.00,"wind_dir_at_hi_speed_last_10_min":336,"rain_size":1,"rain_rate_last":0,"rain_rate_hi":0,"rainfall_last_15_min":0,"rain_rate_hi_last_15_min":0,"rainfall_last_60_min":0,"rainfall_last_24_hr":0,"rain_storm":0,"rain_storm_start_at":null,"solar_rad":null,"uv_index":null,"rx_state":0,"trans_battery_flag":0,"rainfall_daily":0,"rainfall_monthly":0,"rainfall_year":1750,"rain_storm_last":4,"rain_storm_last_start_at":1674798601,"rain_storm_last_end_at":1675000860},{"lsid":434634,"data_structure_type":4,"temp_in": 79.4,"hum_in":20.5,"dew_point_in": 35.5,"heat_index_in": 77.4},{"lsid":434633,"data_structure_type":3,"bar_sea_level":30.125,"bar_trend":-0.013,"bar_absolute":29.660}]},"error":null}
                                  yes, the weather station dumps a mess. :)
                                  my current config for the values by notification is just the basics, but should be grabbing the “hum” value for testing:
                                  			header: "Module-1",
                                  				groups: [
                                  						items: [
                                  								notification: "WEATHERLINK",
                                  								itemTitle: "Item-1",
                                  								values: [
                                  										valueTitle: "Value-1",
                                  										jsonpath: "hum",
                                  I get initally “NA” as a value, then it flips to “Undefined”
                                  Any clue on what I’m doing wrong, or is the feed from the weather station needing more of a massage to be useful?
                                  thanks!
                                  • wishmaster270W
                                    wishmaster270 Module Developer @BKeyport
                                    @BKeyport Hi,
                                    i formatted your output to understand the JSON structure you are using:
                                        "data": {
                                            "did": "001D0A71573B",
                                            "ts": 1675287003,
                                            "conditions": [
                                                    "lsid": 434637,
                                                    "data_structure_type": 1,
                                                    "txid": 1,
                                                    "temp": 47.4,
                                                    "hum": 52.8,
                                                    "dew_point": 31.0,
                                                    "wet_bulb": 38.4,
                                                    "heat_index": 46.4,
                                                    "wind_chill": 47.4,
                                                    "thw_index": 46.4,
                                                    "thsw_index": null,
                                                    "wind_speed_last": 2.00,
                                                    "wind_dir_last": 31,
                                                    "wind_speed_avg_last_1_min": 2.62,
                                                    "wind_dir_scalar_avg_last_1_min": 6,
                                                    "wind_speed_avg_last_2_min": 2.81,
                                                    "wind_dir_scalar_avg_last_2_min": 358,
                                                    "wind_speed_hi_last_2_min": 5.00,
                                                    "wind_dir_at_hi_speed_last_2_min": 340,
                                                    "wind_speed_avg_last_10_min": 1.43,
                                                    "wind_dir_scalar_avg_last_10_min": 36,
                                                    "wind_speed_hi_last_10_min": 5.00,
                                                    "wind_dir_at_hi_speed_last_10_min": 336,
                                                    "rain_size": 1,
                                                    "rain_rate_last": 0,
                                                    "rain_rate_hi": 0,
                                                    "rainfall_last_15_min": 0,
                                                    "rain_rate_hi_last_15_min": 0,
                                                    "rainfall_last_60_min": 0,
                                                    "rainfall_last_24_hr": 0,
                                                    "rain_storm": 0,
                                                    "rain_storm_start_at": null,
                                                    "solar_rad": null,
                                                    "uv_index": null,
                                                    "rx_state": 0,
                                                    "trans_battery_flag": 0,
                                                    "rainfall_daily": 0,
                                                    "rainfall_monthly": 0,
                                                    "rainfall_year": 1750,
                                                    "rain_storm_last": 4,
                                                    "rain_storm_last_start_at": 1674798601,
                                                    "rain_storm_last_end_at": 1675000860
                                                    "lsid": 434634,
                                                    "data_structure_type": 4,
                                                    "temp_in": 79.4,
                                                    "hum_in": 20.5,
                                                    "lsid": 434633,
                                                    "data_structure_type": 3,
                                                    "bar_sea_level": 30.125,
                                                    "bar_trend": -0.013,
                                                    "bar_absolute": 29.660
                                        "error": null
                                    The hum value is part of the first element with index 0 of the conditions object which is part of the data object.
                                    This results in a more advanced jsonpath…
                                    			header: "Module-1",
                                    				groups: [
                                    						items: [
                                    								values: [
                                    										jsonpath: "data.conditions[0].hum",
                                    This config works out of the box ;-)
                                    Edit:
                                    If the order of the elements of conditions varies you can use
                                    jsonpath: "data.conditions..hum"
                                    This one selects the hum value of any element of conditions.
                                    • BKeyportB
                                      @wishmaster270 Brilliant. Thank you. JSON is still quite the mystery to me sometimes. :)
                                      • BKeyportB
                                        BKeyport Module Developer @BKeyport
                                        One last thing - where in the CSS do I adjust the font size for the module? I want it to use the MM “Large” font, as it’s on a wall display across from my desk. Can’t seem to find it.
                                        • wishmaster270W
                                          @BKeyport
                                          Hi, great that it works now.
                                          There are two different ways of how to change the font-size.
                                          Either by using the classes option and add large to the element you want the font-size to be changed. i.e.:
                                          			header: "Module-1",
                                          				groups: [
                                          						items: [
                                          								values: [
                                          										classes: "large",
                                          										jsonpath: "data.conditions..hum",
                                          The main problem with this solution is that the font-size of the valueTitle and the value itself is changed.
                                          Or you can use custom.css to do the job:
                                          .MMM-ValuesByNotification .vbn .groupTitle,
                                          .MMM-ValuesByNotification .vbn .itemTitle,
                                          .MMM-ValuesByNotification .vbn .value,
                                          .MMM-ValuesByNotification .vbn .valueTitle {
                                            font-size: var(--font-size-large);
                                            line-height: 1;
                                          In this example the font-size of all titles and the value is changed. I use the font-size-large CSS variable of the main.css for this job.
                                          • BKeyportB
                                            Thanks again, man. :)
                                            I might not have to work up my own module to get the notifications. 🤣
                                            BKeyportB 1 Reply Last reply Reply Quote -1
