    How to synchronize pictures from mobile to the MM?
    18 Posts 6 Posters 5.1k Views 6 Watching
      MajorC Project Sponsor
      Hello,
      I use my MM primarily as a digital picture frame with additional information (weather, calendar, etc.).
      Currently I am looking for a good and easy way to synchronize photos taken with the cell phone simply to the MM.
      It would be important to be able to select on the phone as easily as possible, which pictures are brought to the MM. So that even my parents, who are not nerds, can do that.
      Maybe copy the photos on the phone into a specific folder and this synchronizes every 24h with the MM?
      Am open to instructions and software.
      S wishmaster270W 2 Replies Last reply Reply Quote 1
        sdetweil @MajorC
        @MajorC see my uploadpics module
        presents a qr code , the user scans, gets prompt to search for and select pics, and uploads them to the configured folder.
        I use MMM-ImagesPhotos, so I upload for it to display
        https://github.com/sdetweil/uploadPics
        I use another tool to do the phone upload code. it does NOT present thumbnails of the pics, only the filename…
        • wishmaster270W Offline
          wishmaster270 Module Developer @MajorC
          @MajorC
          i run a instance of TeleFrame in botonly mode to send pictures via Telegram to my mirror and save them to a directory.
          Then i use MMM-BackgroundSlideshow to display.
          TeleFrame supports setting a file limit so older files get deleted. But you can not remove pictures via Telegram (only with access to the mirror) if you send them accidently.
          Everybody with access to the bot can send pictures via Telegram app.
            sdetweil @wishmaster270
            @wishmaster270 but this sends all pics as u take them, right? like google photos upload
              wishmaster270 Module Developer @sdetweil
              Correct. It does not modify the pictures in any way.
              You select the pictures you want to send like sending them via WhatsApp or any other messaging app.
              I forgot to mention that i wrote a small shell script which checks the the directory for new files periodically and sends a “BACKGROUNDSLIDESHOW_UPDATE_IMAGE_LIST” notification via the rest api of MMM-RemoteControl if new pictures are present.
                @wishmaster270 said in How to synchronize pictures from mobile to the MM?:
                so the user selects pictures, vs the app just sending without selection
                but u have to install an app on your phone
                  Correct.
                  You use the normal Telegram Messanger App but instead of sending pictures to somebody you send it to a bot (which is a supported feature of Telegram)
                  The Teleframe acts as a Telegram Client, receives the pictures and saves them to a directory on the mirror.
                  As Teleframe creates a images.json file my watchdog only watches this file for changes and sends the notification to the module if needed.
                    I don’t have one of those
                      MajorC Project Sponsor @sdetweil
                      I use telegram with my family, so I will give it a try.
                        @MajorC
                        If you need the watchdog script let me known. Did not push it to any repository till now cause it is only a small bash script.
                          @wishmaster270 later reply, cool
                          I’ve now started using telegram bot with n8n to help
                          my son take inventory in his estate sale business. pretty cool
                          plainbrokeP 1 Reply Last reply Reply Quote 0
                          • plainbrokeP Offline
                            plainbroke @sdetweil
                            So Sam,
                            If I use your program to upload the photos and the module it defaults to, to show pictures anyone in my house could upload pictures to the folder that the photo module is showing from and the pictures will show then. or will it need MM to restart? Do the photos have to be resized?
                              sdetweil @plainbroke
                              @plainbroke depends on the module displaying the images
                              MMM-ImagesPhotos will auto refresh the list
                                @plainbroke photos do not have to be resized w MMM-ImagesPhotos
                                • F Offline
                                  ferby09
                                  You could use FolderSync on Android to daily sync a specific folder to an SMB share that you create on your MagicMirror or wherever you get your photos from.
                                  • C Offline
                                    chrisfr1976 @ferby09
                                    Hi folks,
                                    I’m using rclone. I combined it with dropbox. In dropbox you can automate the image handling from *heic to *jpg. So I make a picture on my iPhone and send it to the dropbox folder. The rest is running completely in the background. That’s it…
                                    But Rclone can handle a lot of more services.
                                    Regards, Chris.
                                    S 1 Reply Last reply Reply Quote -1
                                      sdetweil @chrisfr1976
                                      @chrisfr1976 mmm-ImagesPhotos handles heic images too
                                      C 1 Reply Last reply Reply Quote 1
                                      • C Offline
                                        chrisfr1976 @sdetweil
                                        In addition if you use dropbox on a windows-pc you can fully manage the image folder there. rclone does the rest for you on the pi.
                                        Regards, Chris.
