    How to synchronize pictures from mobile to the MM?
    18 Posts 6 Posters 5.4k Views 6 Watching
      sdetweil @wishmaster270
      @wishmaster270 but this sends all pics as u take them, right? like google photos upload
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @sdetweil
        Correct. It does not modify the pictures in any way.
        You select the pictures you want to send like sending them via WhatsApp or any other messaging app.
        I forgot to mention that i wrote a small shell script which checks the the directory for new files periodically and sends a “BACKGROUNDSLIDESHOW_UPDATE_IMAGE_LIST” notification via the rest api of MMM-RemoteControl if new pictures are present.
          @wishmaster270 said in How to synchronize pictures from mobile to the MM?:
          so the user selects pictures, vs the app just sending without selection
          but u have to install an app on your phone
          • wishmaster270W
            Correct.
            You use the normal Telegram Messanger App but instead of sending pictures to somebody you send it to a bot (which is a supported feature of Telegram)
            The Teleframe acts as a Telegram Client, receives the pictures and saves them to a directory on the mirror.
            As Teleframe creates a images.json file my watchdog only watches this file for changes and sends the notification to the module if needed.
            S 2 Replies Last reply
              I don’t have one of those
              M 1 Reply Last reply
                MajorC Project Sponsor @sdetweil
                I use telegram with my family, so I will give it a try.
                • wishmaster270W
                  wishmaster270 Module Developer @MajorC
                  @MajorC
                  If you need the watchdog script let me known. Did not push it to any repository till now cause it is only a small bash script.
                    @wishmaster270 later reply, cool
                    I’ve now started using telegram bot with n8n to help
                    my son take inventory in his estate sale business. pretty cool
                    plainbrokeP 1 Reply Last reply
                    • plainbrokeP
                      plainbroke @sdetweil
                      So Sam,
                      If I use your program to upload the photos and the module it defaults to, to show pictures anyone in my house could upload pictures to the folder that the photo module is showing from and the pictures will show then. or will it need MM to restart? Do the photos have to be resized?
                        sdetweil @plainbroke
                        @plainbroke depends on the module displaying the images
                        MMM-ImagesPhotos will auto refresh the list
                          @plainbroke photos do not have to be resized w MMM-ImagesPhotos
                          • F
                            ferby09
                            You could use FolderSync on Android to daily sync a specific folder to an SMB share that you create on your MagicMirror or wherever you get your photos from.
                            C 1 Reply Last reply
                              chrisfr1976 @ferby09
                              Hi folks,
                              I’m using rclone. I combined it with dropbox. In dropbox you can automate the image handling from *heic to *jpg. So I make a picture on my iPhone and send it to the dropbox folder. The rest is running completely in the background. That’s it…
                              But Rclone can handle a lot of more services.
                              Regards, Chris.
                              Reply Quote -1
                                sdetweil @chrisfr1976
                                @chrisfr1976 mmm-ImagesPhotos handles heic images too
                                  chrisfr1976 @sdetweil
                                  In addition if you use dropbox on a windows-pc you can fully manage the image folder there. rclone does the rest for you on the pi.
                                  Regards, Chris.
