    Get pictures from synology NAS - "Rediscover This Day"
    9 Posts 5 Posters 6.3k Views 7 Watching
      schmucke
      Hey,
      is anyone here who is needing a solution to show own images from the past years? Like the Facebook remember function? The job to sort the images runs on the synology and works with: mysql, exiv2 and copy. I get the Exif data from each image and write it in a sqldb. with bash i get the files in a local folder (incl. resize for the mirror). The raspberry is copy the images in a local folder. Here dit i use the MMM-ImagesPhoto Plugin.
      my solution ist very simple and usable with the latest synology firmware. If anyone want read this, in wich category can i post it?!
      Not the right resolution, but you can see the what i mean…
      screenshot
      Reply Quote 1
      • T
        Tifendro
        Hi !!!
        that’s the exact function that i want !
        I also have a synology where my pics are stored !
        Can you please contact me with your Project info or write it down there ?
        Thank you very much
        • C
          cyberphox
          Own a Synology and would LOVE to do this!! Contact me for sure…interested!!
            schmucke
            Hello,
            i help me here very simple. on the Magicmirror side, i have a cronjob what get pictures every day per ssh/scp. To use this, i have add the magicmirror device to the knownhosts on the synology side (google for it).
            on Synology side:
            This Script is get the exif data of the images. write it to a CSV and then, get the path and write it to a mysqldb (This Script i run once every year one time per hand … i dont know it works perfectly… I think, that here are better coding people… this is quick and dirty. But it works for me. I cant show the Magicmirror side now, i am not at home - but you can use every Plugin with a upload folder… i can show my “Plugin” in the next days if you want…
            #!/bin/bash
            # This script is get the exif data (if set) from all
            # pictures (jpg/JPG) in a define path (recursiv).
            # It writes the data to am MYSQL Database.
            # It works native with Synology DSM (Tested with 6.0.2-xxxx)
            # To use this script, put in the  root folder of your photos
            # chmod 775 ./listimages.sh make the script executable
            # ./listimages.sh execute the scriptfile
            # Where want you present your files?
            imagepath=/volume1/Intern/Fotos/MagicMirror/
            # Variables for the temp files (will delete at End of the Script
            exportcsv=./export.csv
            importcsv=./import.csv
            # MySql Data
            username=root
            password=PASSWORD
            database=ExifData
            table=Bilder
            shopt -s globstar extglob
            exiv2 -pa -g DateTimeOriginal **/*.@(jpg|JPG) |
            awk -v pwd="$PWD/" -v dq='"' -v OFS=',' '{
                fn = substr($0, 1, match($0, / *Exif\.Photo/)-1)
            	    print dq pwd fn dq,  dq $(NF-1) dq, dq $NF dq
            		}' >$exportcsv
            mysql -u$username -p$password -e "use $database" -e "
            TRUNCATE Bilder;"
            # Write data to mysql
            for f in $exportcsv
            do
            		LOAD DATA LOCAL INFILE '$f'
            		INTO TABLE $table
            		FIELDS TERMINATED BY ','
            		OPTIONALLY ENCLOSED BY '\"'
            		LINES TERMINATED BY '\n'
            		(path,date,time);"
            done
            This script is copying and resizing the images:
            importcsv=/volume1/Intern/Fotos/Bilder/import.csv
            #remove old images
            rm /volume1/Intern/Fotos/Bilder/import.csv
            rm /volume1/Intern/Fotos/MagicMirror/*.*
            #Get Date from tommorow
            DATE=$(date --date='1 day' +%m-%d)
            #DATE=$(date +%m-%d)
            #MYSQL Query by date from tomorrow
            id=$(mysql -uroot -pPASSWORD -s -N -e "SELECT path FROM ExifData.Bilder WHERE date like '%$DATE' INTO OUTFILE '$importcsv' FIELDS TERMINATED BY ',' ENCLOSED BY ''")
            # Copy files with exifdata from tomorow before one,two, three or whatever years
            while read p; do
            cp "$p" $imagepath
            done < $importcsv #(DELETE THE SPACE BETWEEN < AND $!!!!)
            cd $imagepath
            shopt -s nullglob
            i=0
            for f in *.JPG *.jpg *.jpeg; do
              exiv2 -r "$i"_%d.%m.%Y_%H.%M.%S rename ./"$f"
              i=$((i+1))
              done
            	convert -thumbnail 800 ./"$f" ./"${f%}.jpg"
            	rm ./"$f"
            done
            I hope this helps - you can do it! Have fun!
            Reply Quote 1
            • T
              Tifendro
              Awesome ! I will try this soon !! Thank’s again !
              • T
                Tifendro
                what about your photo plugin ?
                yawnsY 1 Reply Last reply
                • yawnsY
                  yawns Moderator @Tifendro
                  @Tifendro
                  https://github.com/roramirez/MMM-ImagesPhotos
                    schmucke
                    Yes @yawns,
                    this is the plugin what i use. i have only customize the css stuff.
                    • G
                      Gabev
