    Online Radio
    52 Posts 4 Posters 26.7k Views 4 Watching
    • T Offline
      tanvir586 @wishmaster270
      @wishmaster270 Hi. Ive just checked it doesn’t go online after radio came back online. the link I gave you before that is 24 hour’s radio. But I used this link https://relay.emasjidlive.uk/kingsheathmasjid
      but it didn’t work. the channel went offline at 4.30pm uk time and came back online at 6.00pm. I pressed stop button and press play and it start working.
      • T Offline
        @wishmaster270 is there any command I can use for auto reconnect?
        • wishmaster270W Offline
          wishmaster270 Module Developer @tanvir586
          @tanvir586 Sorry, needed a moment to figure things out…
          You can try to add “–http-reconnect” and maybe “–http-continuous” to the options.
          Your config should look something like this then:
          		module: "MMM-MplayerRadio",
          		header: "Radio",
          		position: "top_center",
          			//autoplay: 0,
                                  customCommand: "/usr/bin/vlc",
                                  customCommandArgs: ["-I","dummy", "--http-reconnect", "--http-continuous", "###URL###"],
          			stations: [
          					title: "Al Mubarak",
          					url: "https://relay.emasjidlive.uk/almubarakradio",
          					logo: "https://upload.wikimedia.org/wikipedia/commons/a/ac/Antenne-bayern-logo.png",
          T 2 Replies Last reply Reply Quote 0
          • T Offline
            @wishmaster270 thanks mate. I’ll try today.
            • T Offline
              @wishmaster270 It didn’t work. it do work when I press stop and play agian.
              config ;-
              	header: "Radio",
              		autoplay: 0,
              		stations: [
              				url: "https://relay.emasjidlive.uk/kingsheathmasjid",
              wishmaster270W 2 Replies Last reply Reply Quote 0
                @tanvir586 I will try to dig deeper the next days but I can not promise that I will have the time.
                Maybe I can write a simple wrapper for vlc which ends the process when the streams stops or is unreachable and tries to start the process every few seconds.
                Did not find any better solution til now.
                  @tanvir586
                  I release a new version of MMM-MplayerRadio (0.0.10) a few minutes ago which contains a new script called “streamlinkWrapper.bash” script. This script uses the streamlink tool to wrap the stream and restarts it if the connection gets lost.
                  You will find a example configuration in the examples directory for streamlinkWrapper which contains the configuration needed for your case.
                  Make sure to install streamlink:
                  sudo apt -y update && sudo apt -y install streamlink
                  T 2 Replies Last reply Reply Quote 1
                  • T Offline
                    @wishmaster270 Thank you so much mate. Even if it’s doesn’t work for me I’m still happy that you made this effort for me. I’ll install the latest version today and will install streamlink
                    • T Offline
                      @wishmaster270 Just updated. Think I’m doing it right. First I’ve installed the streamlink. And then I went to the MMM-MplayerRadio folder and execute git pull.
                      I was bit confused about the streamlink. Didn’t understand where to install it , on the MMM-MplayerRadio folder or just normal installation. Finally I installed normally. Hope I’m doing it right.
                        @tanvir586
                        Normal installation is the right thing. If you got sound with the new configuration everything is fine.
                        Hope the disconnect will be recognized correctly and your stream restarts now.
                        • T Offline
                          @wishmaster270 I’m not getting any sound.
                          config is right?
                          		header: "Radio",
                          			stations: [
                          					title: "Almubarak",
                          					logo: "https://almubarakradio.com/wp-content/uploads/2021/04/logorectangle-1024x326.png",
                          					customCommand: "/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash",
                          					customCommandArgs: ["10", "30", "###URL###"],
                          I added this line aswell
                          customCommandArgs: [“-I”,“dummy”, “–http-reconnect”, “–http-continuous”, “###URL###”],
                          but didn’t work
                          • T Offline
                            tanvir586 @tanvir586
                            @tanvir586 If I used this config then the sound works but open vlc in separate windows
                            	header: "Radio",
                            		stations: [
                            				title: "Almubarak",
                            customCommand: “/usr/bin/vlc”,
                            customCommand: “/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash”,
                            customCommandArgs: [“10”, “30”, “###URL###”],
                            • T Offline
                              tanvir586
                              If I use this config then vlc open is separate window and it’s looks like this.
                              		header: "Radio",
                              			stations: [
                              					title: "Almubarak",
                              					url: "https://relay.livemasjid.com:8443/activestream",
                              picture ;-
                                @tanvir586 Sorry, i am not at my pc at the moment. You only need the first customCommand line. The one with vlc is wrong.
                                You can try to run the run the command directly on the shell and see what happens.
                                /home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash 10 30 https://relay.emasjidlive.uk/almubarakradio
                                You can end it by pressing CRTL+c
                                • T Offline
                                  @wishmaster270 Hi, it’s says this
                                  tanvir@raspberrypi:~ $ /home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash 10 30 https://relay.emasjidlive.uk/almubarakradio
                                  bash: /home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash: No such file or directory
                                  • T Offline
                                    @tanvir586 and I installed mplayer.
                                      @tanvir586 Are you sure you are running the latest version of the module?
                                      The error says that the wrapper script I added yesterday does not exist.
                                      Can you please check the script folder and check if the file is executable?
                                      • T Offline
                                        @wishmaster270 I’ve updated yesterday. I’ll check again now
                                        • T Offline
                                          tanvir586
                                          Should I reinstall? Or delete the module and fresh install?
                                            @tanvir586 You installed to a different user. Your path will be
                                            /home/tanvir/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash
                                            • 2 / 3
