MMM-InternetMonitor
18 Posts 4 Posters 5.6k Views 4 Watching
    Bungle68
    Hi, I’m having issues with the above module. It just shows up a line with Internet Monitor on the screen (header), but nothing else?
    Any thoughts?
    module: ‘internet-monitor’,
    position: ‘top_left’,
    header: ‘Internet Monitor’,
    type: ‘minimal’,
    maxTime: 20000,
    updateInterval: 50000,
    verbose: false,
    displayStrength: false,
    displaySpeed: false,
    strengthIconSize: 80,
    maxGaugeScale:1000,
    S 1 Reply Last reply Dec 1, 2022, 11:24 PM Reply Quote 1
    • S Online
      sdetweil @Bungle68
      @Bungle68 which are you using? see
      https://forum.magicmirror.builders/topic/625/internet-monitor/104?_=1669937006036
      B 1 Reply Last reply Dec 2, 2022, 12:28 AM Reply Quote 0
        Bungle68 @sdetweil
        @sdetweil thanks again, I now at last have the small meters showing, but now it’s not registering any speed at all 🤔 @bhepler, any suggestions?
        It’s all zero?
        S B 2 Replies Last reply Dec 2, 2022, 12:32 AM Reply Quote 1
        • S Online
          sdetweil @Bungle68
          @Bungle68 np… one thing… when u post config, please use the code block markers…
          paste the text,
          select it all
          hit the button above that looks like </>
          B 1 Reply Last reply Dec 2, 2022, 12:50 AM Reply Quote 0
            Bungle68 @sdetweil
            @sdetweil here, let’s try again
            code_text
            type: ‘’,
            serverId: “53937”,
            maxTime: 20000,
            updateInterval: 30000,
            verbose: false,
            displaySpeed: true,
            maxGaugeScale: 1000,
            wifiSymbol: {
                       fullColour: ‘#3afc25’,
                       almostColour: ‘#ffff0c’,
                       halfColour: ‘#ff1111’
            S 1 Reply Last reply Dec 2, 2022, 2:01 AM Reply Quote 0
            • S Online
              sdetweil @Bungle68
              @Bungle68 just another quirk… when u copy the previously posted text without the code markers
              the " and ’ chars become the word processing style slanted
              and THAT will cause a problem if anyone (including you) try to use that info… forum software …
              B 1 Reply Last reply Dec 2, 2022, 7:56 AM Reply Quote 0
                Bungle68 @sdetweil
                @sdetweil always learning 👍
                  bhepler Module Developer @Bungle68
                  @Bungle68 said in MMM-InternetMonitor:
                  It’s all zero?
                  I tried your configuration on my system and got this:
                  One thing I notice straight away is that your maximum speed is set to 1000 Mb/s. My fiber connection is rated at like 1/10th of that speed. I don’t know what kind of internet connection you have running to your house, but my guess is that you’re not seeing any data because your connection is just a sliver of the available graph.
                  Try this: set the maxGuageScale to 100 in your config.js entry.
                  R 1 Reply Last reply Jan 22, 2023, 8:29 PM Reply Quote 0
                    Richtw @bhepler
                    @bhepler
                    Hi - I am looking to replace my last mirror build with an updated one.
                    this module is throwing an error on my install. I suspect I must have gone astray in the install?
                    I started out with a clean install of raspbian and magic mirror
                    Started it up with the default settings and it seems to work fine
                    This was the first module I added
                    Commands I issued were:
                    • cd MagicMirror/modules
                    • git clone https://github.com/BrianHepler/internet-monitor.git
                    • cd internet-monitor
                      NPM install showed some warnings:
                      added 191 packages, and audited 192 packages in 3m
                      9 packages are looking for funding
                      run npm fund for details
                      3 moderate severity vulnerabilities
                      To address all issues (including breaking changes), run:
                      npm audit fix --force
                      Run npm audit for details.
                    When I NPM start now it throws an error:
                    	[22.01.2023 15:19.07.139] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error 				found: Error: Cannot find module '/home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/			binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node'
                    	Require stack:
                    	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/index.js
                    	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/decompress-tarxz/index.js
                    	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/speedtest-net/index.js
                    	- /home/richard/MagicMirror/modules/internet-monitor/node_helper.js
                    	- /home/richard/MagicMirror/js/app.js
                    	- /home/richard/MagicMirror/js/electron.js
                    	- /home/richard/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                    S B 3 Replies Last reply Jan 22, 2023, 9:16 PM Reply Quote 0
                    • S Online
                      sdetweil @Richtw
                      @Richtw the error is about 20 lines closer to the top
