    MMM-InternetMonitor
    18 Posts 4 Posters 7.8k Views 4 Watching
      sdetweil @Bungle68
      @Bungle68 just another quirk… when u copy the previously posted text without the code markers
      the " and ’ chars become the word processing style slanted
      and THAT will cause a problem if anyone (including you) try to use that info… forum software …
        Bungle68 @sdetweil
        @sdetweil always learning 👍
        • bheplerB Offline
          bhepler Module Developer @Bungle68
          @Bungle68 said in MMM-InternetMonitor:
          @sdetweil thanks again, I now at last have the small meters showing, but now it’s not registering any speed at all 🤔 @bhepler, any suggestions?
          It’s all zero?
          I tried your configuration on my system and got this:
          One thing I notice straight away is that your maximum speed is set to 1000 Mb/s. My fiber connection is rated at like 1/10th of that speed. I don’t know what kind of internet connection you have running to your house, but my guess is that you’re not seeing any data because your connection is just a sliver of the available graph.
          Try this: set the maxGuageScale to 100 in your config.js entry.
            Richtw @bhepler
            @bhepler
            Hi - I am looking to replace my last mirror build with an updated one.
            this module is throwing an error on my install. I suspect I must have gone astray in the install?
            I started out with a clean install of raspbian and magic mirror
            Started it up with the default settings and it seems to work fine
            This was the first module I added
            Commands I issued were:
            • cd MagicMirror/modules
            • git clone https://github.com/BrianHepler/internet-monitor.git
            • cd internet-monitor
              NPM install showed some warnings:
              added 191 packages, and audited 192 packages in 3m
              9 packages are looking for funding
              run npm fund for details
              3 moderate severity vulnerabilities
              To address all issues (including breaking changes), run:
              npm audit fix --force
              Run npm audit for details.
            When I NPM start now it throws an error:
            	[22.01.2023 15:19.07.139] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error 				found: Error: Cannot find module '/home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/			binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node'
            	Require stack:
            	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/index.js
            	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/decompress-tarxz/index.js
            	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/speedtest-net/index.js
            	- /home/richard/MagicMirror/modules/internet-monitor/node_helper.js
            	- /home/richard/MagicMirror/js/app.js
            	- /home/richard/MagicMirror/js/electron.js
            	- /home/richard/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            S bheplerB 3 Replies Last reply Reply Quote 0
              sdetweil @Richtw
              @Richtw the error is about 20 lines closer to the top
                sdetweil @Richtw
                @Richtw said in MMM-InternetMonitor:
                looks like not built for arm and electron 22…
                so, you could try this
                create a file in the module home folder
                cd ~/MagicMirror/modules/internet-monitor
                touch buildit
                then nano buildit, and paste this into the editor
                #!/bin/bash
                if [ ! -f ../../node_modules/.bin/electron-rebuild ]; then
                	cd ../..
                	npm install electron-rebuild >/dev/null 2>&1
                	cd -
                fi
                ctrl-o to save, ctrl-x to exit
                chmod +x buildit
                then ./buildit
                • bheplerB Offline
                  bhepler Module Developer @Richtw
                  @Richtw - Yeah, that error usually means that there is an error in your config.js file.
                  Couple suggestions:
                  1. Try this out in the MagicMirror folder: npm run config:check. It will let you know if there are any errors in your config.js file.
                  2. Post the relevant section of your config.js file in this thread. Be sure to use the markdown features of the forum for readability.
                  [Dammit, I am about this close to just deleting my repository. It’s not my module and I’m sick of fixing it.]
                    Richtw @bhepler
                    @bhepler
                    thanks everyone for all the suggestions. Still stuck:
                    For the suggestion - @Richtw the error is about 20 lines closer to the top - Here’s the top
                    richard@raspberrypi:~/MagicMirror/config $ npm start
                    magicmirror@2.22.0 start
                    [24.01.2023 17:51.15.999] [LOG] Starting MagicMirror: v2.22.0
                    [24.01.2023 17:51.16.006] [LOG] Loading config …
                    [24.01.2023 17:51.16.014] [LOG] Loading module helpers …
                    [24.01.2023 17:51.16.017] [LOG] No helper found for module: alert.
                    [24.01.2023 17:51.16.053] [LOG] Initializing new module helper …
                    [24.01.2023 17:51.16.054] [LOG] Module helper loaded: updatenotification
                    [24.01.2023 17:51.16.056] [LOG] No helper found for module: clock.
                    [24.01.2023 17:51.16.534] [LOG] Initializing new module helper …
                    [24.01.2023 17:51.16.535] [LOG] Module helper loaded: calendar
                    [24.01.2023 17:51.17.618] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node’
                    For the suggestion - npm run config:check. I ran it and it did not find anything
                    Your configuration file doesn’t contain syntax errors :)
                    Here’s my config file
                                            module: 'internet-monitor',
                                            position: 'upper_third',
                                            header: 'Internet Monitor',
                                            config:{
                                                    type: '',
                                                    maxTime: 20000,
                                                    updateInterval: 30000,
                                                    verbose: false,
                                                    displayStrength: true,
                                                    displaySpeed: true,
                                                    strengthIconSize: 80,
                                                    maxGuageScale: 1000,
                    I tried that buildit script but it kicked back with:
                    ./buildit: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
                    Running with sudo gave same result
                      sdetweil @Richtw
                      @Richtw can you show results of
                      ls ~/MagicMirror/node_modules/.bin/electron-rebuild -laF
                        Richtw @sdetweil
                        @sdetweil said in MMM-InternetMonitor:
                        thanks for the reply!
                        richard@raspberrypi:~/MagicMirror $ ls ~/MagicMirror/node_modules/.bin/electron-rebuild -laF
                        lrwxrwxrwx 1 richard richard 34 Jan 24 17:57 /home/richard/MagicMirror/node_modules/.bin/electron-rebuild -> ../electron-rebuild/lib/src/cli.js
