    MMM-InternetMonitor
    18 Posts 4 Posters 10.1k Views 4 Watching
      Bungle68
      Hi, I’m having issues with the above module. It just shows up a line with Internet Monitor on the screen (header), but nothing else?
      Any thoughts?
      module: ‘internet-monitor’,
      position: ‘top_left’,
      header: ‘Internet Monitor’,
      type: ‘minimal’,
      maxTime: 20000,
      updateInterval: 50000,
      verbose: false,
      displayStrength: false,
      displaySpeed: false,
      strengthIconSize: 80,
      maxGaugeScale:1000,
        sdetweil @Bungle68
        @Bungle68 which are you using? see
        https://forum.magicmirror.builders/topic/625/internet-monitor/104?_=1669937006036
        B 1 Reply Last reply
          Bungle68 @sdetweil
          @sdetweil thanks again, I now at last have the small meters showing, but now it’s not registering any speed at all 🤔 @bhepler, any suggestions?
          It’s all zero?
          S bheplerB 2 Replies Last reply
            sdetweil @Bungle68
            @Bungle68 np… one thing… when u post config, please use the code block markers…
            paste the text,
            select it all
            hit the button above that looks like </>
              Bungle68 @sdetweil
              @sdetweil here, let’s try again
              code_text
              type: ‘’,
              serverId: “53937”,
              maxTime: 20000,
              updateInterval: 30000,
              verbose: false,
              displaySpeed: true,
              maxGaugeScale: 1000,
              wifiSymbol: {
                         fullColour: ‘#3afc25’,
                         almostColour: ‘#ffff0c’,
                         halfColour: ‘#ff1111’
                sdetweil @Bungle68
                @Bungle68 just another quirk… when u copy the previously posted text without the code markers
                the " and ’ chars become the word processing style slanted
                and THAT will cause a problem if anyone (including you) try to use that info… forum software …
                  Bungle68 @sdetweil
                  @sdetweil always learning 👍
                  • bheplerB
                    bhepler Module Developer @Bungle68
                    @Bungle68 said in MMM-InternetMonitor:
                    It’s all zero?
                    I tried your configuration on my system and got this:
                    One thing I notice straight away is that your maximum speed is set to 1000 Mb/s. My fiber connection is rated at like 1/10th of that speed. I don’t know what kind of internet connection you have running to your house, but my guess is that you’re not seeing any data because your connection is just a sliver of the available graph.
                    Try this: set the maxGuageScale to 100 in your config.js entry.
                    R 1 Reply Last reply
                      Richtw @bhepler
                      @bhepler
                      Hi - I am looking to replace my last mirror build with an updated one.
                      this module is throwing an error on my install. I suspect I must have gone astray in the install?
                      I started out with a clean install of raspbian and magic mirror
                      Started it up with the default settings and it seems to work fine
                      This was the first module I added
                      Commands I issued were:
                      • cd MagicMirror/modules
                      • git clone https://github.com/BrianHepler/internet-monitor.git
                      • cd internet-monitor
                        NPM install showed some warnings:
                        added 191 packages, and audited 192 packages in 3m
                        9 packages are looking for funding
                        run npm fund for details
                        3 moderate severity vulnerabilities
                        To address all issues (including breaking changes), run:
                        npm audit fix --force
                        Run npm audit for details.
                      When I NPM start now it throws an error:
                      	[22.01.2023 15:19.07.139] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error 				found: Error: Cannot find module '/home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/			binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node'
                      	Require stack:
                      	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/index.js
                      	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/decompress-tarxz/index.js
                      	- /home/richard/MagicMirror/modules/internet-monitor/node_modules/speedtest-net/index.js
                      	- /home/richard/MagicMirror/modules/internet-monitor/node_helper.js
                      	- /home/richard/MagicMirror/js/app.js
                      	- /home/richard/MagicMirror/js/electron.js
                      	- /home/richard/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                      S bheplerB 3 Replies Last reply
                        sdetweil @Richtw
                        @Richtw the error is about 20 lines closer to the top
                          sdetweil @Richtw
                          @Richtw said in MMM-InternetMonitor:
                          looks like not built for arm and electron 22…
                          so, you could try this
                          create a file in the module home folder
                          cd ~/MagicMirror/modules/internet-monitor
                          touch buildit
                          then nano buildit, and paste this into the editor
                          #!/bin/bash
                          if [ ! -f ../../node_modules/.bin/electron-rebuild ]; then
                          	cd ../..
                          	npm install electron-rebuild >/dev/null 2>&1
                          	cd -
                          fi
                          ctrl-o to save, ctrl-x to exit
                          chmod +x buildit
                          then ./buildit
                          • bheplerB
                            bhepler Module Developer @Richtw
                            @Richtw - Yeah, that error usually means that there is an error in your config.js file.
                            Couple suggestions:
                            1. Try this out in the MagicMirror folder: npm run config:check. It will let you know if there are any errors in your config.js file.
                            2. Post the relevant section of your config.js file in this thread. Be sure to use the markdown features of the forum for readability.
                            [Dammit, I am about this close to just deleting my repository. It’s not my module and I’m sick of fixing it.]
                              Richtw @bhepler
                              @bhepler
                              thanks everyone for all the suggestions. Still stuck:
                              For the suggestion - @Richtw the error is about 20 lines closer to the top - Here’s the top
                              richard@raspberrypi:~/MagicMirror/config $ npm start
                              magicmirror@2.22.0 start
                              [24.01.2023 17:51.15.999] [LOG] Starting MagicMirror: v2.22.0
                              [24.01.2023 17:51.16.006] [LOG] Loading config …
                              [24.01.2023 17:51.16.014] [LOG] Loading module helpers …
                              [24.01.2023 17:51.16.017] [LOG] No helper found for module: alert.
                              [24.01.2023 17:51.16.053] [LOG] Initializing new module helper …
                              [24.01.2023 17:51.16.054] [LOG] Module helper loaded: updatenotification
                              [24.01.2023 17:51.16.056] [LOG] No helper found for module: clock.
                              [24.01.2023 17:51.16.534] [LOG] Initializing new module helper …
                              [24.01.2023 17:51.16.535] [LOG] Module helper loaded: calendar
                              [24.01.2023 17:51.17.618] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node’
                              For the suggestion - npm run config:check. I ran it and it did not find anything
                              Your configuration file doesn’t contain syntax errors :)
                              Here’s my config file
                                                      module: 'internet-monitor',
                                                      position: 'upper_third',
                                                      header: 'Internet Monitor',
                                                      config:{
                                                              type: '',
                                                              maxTime: 20000,
                                                              verbose: false,
                                                              displayStrength: true,
                                                              displaySpeed: true,
                                                              maxGuageScale: 1000,
                              I tried that buildit script but it kicked back with:
                              ./buildit: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
                              Running with sudo gave same result
                                sdetweil @Richtw
                                @Richtw can you show results of
                                ls ~/MagicMirror/node_modules/.bin/electron-rebuild -laF
                                  Richtw @sdetweil
                                  @sdetweil said in MMM-InternetMonitor:
                                  thanks for the reply!
                                  richard@raspberrypi:~/MagicMirror $ ls ~/MagicMirror/node_modules/.bin/electron-rebuild -laF
                                  lrwxrwxrwx 1 richard richard 34 Jan 24 17:57 /home/richard/MagicMirror/node_modules/.bin/electron-rebuild -> ../electron-rebuild/lib/src/cli.js
                                    sdetweil @Richtw
                                    @Richtw weird.
                                    edit the buildit script we wrote and add
                                    -b
                                    at end of the last line, w a space before it. see if we can find where it is have permissions error
                                      Richtw @sdetweil
                                      @sdetweil Here’s the script I’m running
                                      !/bin/bash
                                              cd ../..
                                              cd -
                                      fi
                                      ../../node_modules/.bin/electron-rebuild -b
                                      Here’s the result
                                      richard@raspberrypi:~/MagicMirror/modules/internet-monitor $ sudo ./buildit
                                      ./buildit: line 8: ../../node_modules/.bin/electron-rebuild: Permission denied
                                        sdetweil @Richtw
                                        @Richtw sorry. I do not understand the problem jetey, and cannot reproduce it on my own
