    v2.22.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 6.6k Views 1 Watching
    • MichMichM
      MichMich
      [2.22.0] - 2023-01-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.22.0
      Thanks to: @angeldeejay, @buxxi, @dariom, @dWoolridge, @KristjanESPERANTO, @MagMar94, @naveensrinivasan, @retroflex, @SkySails and @Tom.
      Special thanks to @khassel, @rejas and @sdetweil for taking over most (if not all) of the work on this release as project collaborators. This version would not be there without their effort. Thank you!
      Added
      • Added test for remoteFile option in compliments module
      • Added hourlyWeather functionality to Weather.gov weather provider
      • Removed weatherEndpoint definition from weathergov.js (not used)
      • Added css class names “today” and “tomorrow” for default calendar
      • Added Collaboration.md
      • Added new github action for dependency review (#2862)
      • Added a WeatherProvider for Open-Meteo
      • Added Yr as a weather provider
      • Added config options “ignoreXOriginHeader” and “ignoreContentSecurityPolicy”
      Removed
      • Removed usage of internal fetch function of node until it is more stable
      Updated
      • Cleaned up test directory (#2937) and jest config (#2959)
      • Wait for all modules to start before declaring the system ready (#2487)
      • Updated e2e tests (moved done() in helper functions) and use es6 syntax in all tests
      • Updated da translation
      • Rework weather module
        • Make sure smhi provider api only gets a maximum of 6 digits coordinates (#2955)
        • Use fetch instead of XMLHttpRequest in weatherprovider (#2935)
        • Reworked how weatherproviders handle units (#2849)
        • Use unix() method for parsing times, fix suntimes on the way (#2950)
        • Refactor conversion functions into utils class (#2958)
      • The cors-method in server.js now supports sending and recieving HTTP headers
      • Replace … by …
      • Cleanup compliments module
      • Updated dependencies including electron to v22 (#2903)
      Fixed
      • Correctly show apparent temperature in SMHI weather provider
      • Ensure updatenotification module isn’t shown when local is ahead of remote
      • Handle node_helper errors during startup (#2944)
      • Possibility to change FontAwesome class in calendar, so icons like fab fa-facebook-square works.
      • Fix cors problems with newsfeed articles (as far as possible), allow disabling cors per feed with option useCorsProxy: false (#2840)
      • Tests not waiting for the application to start and stop before starting the next test
      • Fix electron tests failing sometimes in github workflow
      • Fixed gap in clock module when displayed on the left side with displayType=digital
      • Fixed playwright issue by upgrading to v1.29.1 (#2969)
      Reply Quote 2
      • MichMichM MichMich locked this topic on
