    Weather based on another provider..
    18 Posts 3 Posters 18.8k Views 3 Watching
    • cowboysdudeC
      cowboysdude Module Developer
      I’m using the stock weather module but it doesn’t work for me… I’m from Elmira, NY US and it shows either the wrong info or nothing.
      I go to the weather provider and it doesn’t even find where I am… not sure why but…
      Does anyone out there have another weather module?
      Thanks!! and Great work!!!
      • mochmanM
        mochman Module Developer
        @cowboysdude Take at look at this post. I added a locationID which gives you the ability to put the exact city in you want weather for. It helps get rid of the ambiguity of having multiple cities with the same name.
        • cowboysdudeC
          Thank you!! I did use it but it’s still returning that it’s 5:32am and it’s actually 12:03 AM right now… so not sure what that’s all about… The temp is right but the time isn’t…
          OH SHOOT never mind LOL that’s the time of the sunrise… opps…
          I still am getting incorrect weather forecast info… BUT the current weather is working great! :)
          • RedNaxR
            RedNax Module Developer
            If this WeatherUnderground location works for you you could use MMM-WunderGround:
            Your config section will look like this:
            			module : 'MMM-WunderGround',
            			position : 'top_right',
            			config : {
            				apikey : 'xxxxxxxxxxxxx', // private; don't share!
            				pws: 'NY/Elmira',
            				lang : 'EN',
            				hourly : '1',
            				fctext : '1',
            				fcdaycount : "5",
            				fcdaystart : "0",
            				hourlyinterval : "3",
            				hourlycount : "2",
            				alerttime : 10000,
            				alerttruncatestring : ""
            cowboysdudeC 1 Reply Last reply
            • cowboysdudeC
              I would also need the module for this and that I don’t have… I have found one but it’s not working so I’ll have to figure it out…
              Thank you!
              mochmanM 1 Reply Last reply
              • mochmanM
                mochman Module Developer @cowboysdude
                @cowboysdude Since the default weather forecast and current weather pull from the same place, you can make the same changes as you did on the currentweather module to the forecastweather module and config.js.
                Replace your current weatherforecast.js with the one here.
                Your currentweather.js should look like the one here.
                Don’t forget to edit your config.js to put the locationID in both.
                • mochmanM
                  Or just get the new MagicMirror 2.0.2 that was released today. It has those changes incorporated.
                  Reply Quote 1
                  • cowboysdudeC
                    cowboysdude Module Developer @mochman
                    @mochman said in Weather based on another provider..:
                    That’s awesome! Thank you but I just got weather underground working and I like it :)
                    @cowboysdude said in Weather based on another provider..:
                    Thank you!
                    Found it… it’s working great!! Great job and Thank you!
                    • mochmanM
                      Yeah it does, that’s the one I use too.
                      Reply Quote 1
                      • cowboysdudeC
                        @mochman but I did do my git pull to update as well!! Thank you!!!
                        • cowboysdudeC
                          cowboysdude Module Developer @RedNax
                          @RedNax said in Weather based on another provider..:
                          I would like to know one more thing… how you get the text forecast on there too
                          RedNaxR 1 Reply Last reply
                          • RedNaxR
                            RedNax Module Developer @cowboysdude
                            @cowboysdude If/when the chosen location provides any they should be displayed as per the pic…
                            What’s your config?
                            • cowboysdudeC
                              @RedNax this is what’s in the config.js [of course I didn’t list my key here]
                                          appid: 'xxxxxxxxxxxx' //wunderground.com API key.
                              I’m thinking this is what you were asking for…
                              Thank you!
                              Note from Moderator: Please use Markdown on code snippets for easier reading.
                              • RedNaxR
                                @cowboysdude That config isn’t for the MMM-WunderGround module… You’re using another module that’s using Weather Underground for weather info. The forecast text functionality needs to be implemented in the module itself. Or you could of course switch to using MMM-WunderGround Which is what the above screenshot is off…
                                cowboysdudeC 3 Replies Last reply
                                • cowboysdudeC
                                  @RedNax Thank you that explains it!!! As soon as I get the frame around it and get it set back up to work on I will be switching because I just like it!
                                  HUGE Thanks
                                  • cowboysdudeC
                                    This post is deleted!
                                    • cowboysdudeC
                                      @RedNax Thank you for the module. I did finally get a chance to install it and it works perfectly!!!
                                      Huge Thanks!! Great job!
                                      • RedNaxR
                                        @cowboysdude :D Glad it’s working, enjoy!
                                        Reply Quote 1
