    Mirror showing not all modules on all devices
    14 Posts 3 Posters 9.2k Views 3 Watching
      sangroma
      hello!
      i am running magic mirror in a docker container (karsten13/magicmirror:v2.21.0) on my nas.
      i am opening the site in my local network from different devices (mobile, notebook, pi with mirror os)
      the strange thing: when opening the site on my pi the default weather modules are not shown. on all other devices these two modules are shown as intended.
      so, no error logs etc. because the modules are working.
      i´ve already tested, that the correct version gets called and nothing gets cached, by adding some other modules for testing purpose to see, if they show up - yes, other modules show up.
      does someone has the same issue or any idea how to solve it?
      	module: "weather",
      	disabled: false,
      		type: "current",
      		locationID: "XXX",
      		apiKey: "XXX"
      	module: "weather",
      	disabled: false,
      	header: "Weather Forecast",
      		type: "forecast",
      		locationID: "XXX",
      		apiKey: "XXX"
        sdetweil @sangroma
        @sangroma yes. that is one of the new es6 idioms. ?., the chaining operator
        on
        https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Operators/Optional_chaining
        chrome needs version 80, u have only v 72
          sdetweil @sangroma
          @sangroma on the pi. can u open the developers window, ctrl-shift-i on the keyboard, select the console tab and enter wea in the filter field
            sangroma
            @sdetweil thank you!
            very strange.
            after
            Load script: modules/default/weather/weather.js
            i get the following error
            Uncaught SyntaxError: Unexpected token .
              sangroma
              Hmmm… on load up after the weather.js the foowing error occure only on the raspi. On all other clients i can call the script without errors
              Load script: modules/default/weather/weatger.js
                sdetweil @sangroma
                @sangroma what version of node do you have installed,
                node -v
                but electron should have the right node version
                what browser are you using?
                the error is that the nodejs version is downlevel, not supporting the es6 idioms we are using
                  sangroma
                  currently running v16.19.0 of node
                  browser is chromium latest version 72.0.3626.121
                  Just installed latest version of firefox. Same issue
                    sdetweil @sangroma
                    @sangroma on the error line, what is the line number next to the name. weather.js:xxx
                    what os version are u running?
                    lsb_release -a
                    uname -a
                      sangroma @sdetweil
                      weather.js:159
                      device where the magic mirror docker container is running on
                      Linux nas 6.0.0-0.deb11.6-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.0.12-1~bpo11+1 (2022-12-19) x86_64 GNU/Linux
                      device on which i am trying to call the mirror via chromium
                      Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
                        sdetweil @sangroma
                        @sangroma what version of MagicMirror are you running
                        line 159 is empty in the latest release
                          sangroma @sdetweil
                          magicmirror:v2.21.0
                          i dont know why, but in your file it is line 165
                            sdetweil @sangroma
                            on
                              sangroma
                              @sdetweil Oh wow. Many thanks!!
                              Will do this.
                              Topic can be closed
                              • KristjanESPERANTOK Offline
                                KristjanESPERANTO Module Developer @sangroma
                                @sangroma Out of curiosity: How come you used a browser version from 4 years ago?
                                  sangroma @KristjanESPERANTO
                                  @KristjanESPERANTO as far as i remember i installed some kind of raspbian light version because i dont need much on the device. just wanted to show the internal webpage of the docker.
                                  as it got deprecated i couldnt update to a higher version. need to set up a complete fresh OS :D
