    Throwing down the gauntlet
    85 Posts 11 Posters 98.1k Views 11 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @jbeck615
      @jbeck615 you shouldn make the changes in the module itself all config changes should go in the config file
      J 2 Replies Last reply Reply Quote 0
        jbeck615 @strawberry 3.141
        @strawberry-3.141 to be honest i dont know if i pasted enough as it kept cutting me off due to character count but just let me know. no rush. also the picture here, the current weather at the center, is what ideally id love to have at top right. however when i change the position, the top info above the current weather and those icons pop up. thanks regardless for taking a look! 0_1488321534851_2017-02-28-162722_1184x624_scrot.jpg
          @strawberry-3.141
          .region.top.right .MMM-WunderGround table.small td:nth-child(6) {
            display:none;
          .MMM-WunderGround .weathericon {
            font-size: 45%;
            line-height: 5px;
            display: inline-block;
            -ms-transform: translate(0, -3px); /* IE 9 */
            -webkit-transform: translate(0, -3px); /* Safari */
          .MMM-WunderGround .day {
            padding-left: 0;
          #  padding-right: 10px;
          .MMM-WunderGround .vcen {
             vertical-align: top;
          .MMM-WunderGround .weather-icon {
            padding-left: 0px;
            text-align: center;
            width:50px;
          .MMM-WunderGround .max-temp {
            padding-left: 0px;
            padding-right: 0;
          .MMM-WunderGround .min-temp {
          #  padding-left: 10px;
          #  padding-right: 0;
          .MMM-WunderGround .forecastText {
          #  padding-right: 0;
          #  word-wrap: break-word;
          #  text-align: right;
          #  rowspan: 0;
          .MMM-WunderGround .tableheader {
            font-size: 75%;
            text-align: center;
          .MMM-WunderGround .hour {
            font-size: 75%;
            text-align: center;
          .MMM-WunderGround .pop {
            font-size: 86%;
          .MMM-WunderGround .mm {
            font-size: 75%;
          .MMM-WunderGround .green {
            color: #83FFB3;
          .MMM-WunderGround .yellow {
            color: yellow;
          .MMM-WunderGround .red {
            color: #FF4C4C;
          .MMM-WunderGround .center {
          	text-align: center;
          .MMM-WunderGround .left {
          	text-align: left;
          .MMM-WunderGround .lpad {
          	padding-left: 10px;
          .MMM-WunderGround .currentWeatherIcon {
            font-size: 75%;
            line-height: 45px;
            width: 40%;
            height: 40%;
          .MMM-WunderGround .forecastWeatherIcon {
            font-size: 75%;
            line-height: 65px;
            width: 50%;
          .MMM-WunderGround .moonPhaseIcon {
            height: 34px;
            vertical-align: middle;
          .MMM-WunderGround .hrDivider {
                  font-size: 10px;
          .MMM-WunderGround .sub {
              vertical-align: sub;
              font-size: smaller;
          .MMM-WunderGround .smaller {
              font-size: 60%;
            color: #FF1A1A;
            color: #0080ff;
            color: #6f6;
          .region.top.center .MMM-WunderGround table.small {
            display:none;
          .region.top.right .MMM-WunderGround table:not(.small) {
            display:none;
            display:none;
            jbeck615 @Mykle1
            @Mykle1 ive never touched any of the monthly calendar files until i added your lines above to the end of my mcal.css file and was curious if you had any thoughts as to why your numbers are aligned to the left (when facing monitor) of the abbreviated days and mine are aligned to the right? just curious
              @strawberry-3.141 the main config file and never touch the config files of each modules folder?
                Mykle1 Project Sponsor Module Developer @jbeck615
                @jbeck615 said in Throwing down the gauntlet:
                Those should have been added to your custom.css file within your css folder
                Are you talking about WunderGround still? If so, then mine are aligned to the right as well.
                  There are no config files in each module folder. Anything inside the actual module folder is part of the module and should not be altered. You set up each modules configuration in the config.js file inside your config folder. After that, any customizing of each module should be done in the custom.css file in your css folder.
                  This is the WunderGround entry in my config.js file. The setup of the module.
                      			module: 'MMM-WunderGround', // Just for current weather
                      			position: 'top_center',
                          		apikey: 'YOUR API KEY', // private; don't share!
                          		pws: 'pws:KNYNEWYO103', // Richmondtown Weather Station - Very Cool
                  			currentweather: 1,
                          		coloricon: true,
                  			animationSpeed: 5000,
                      			roundTmpDecs: 0,
                      			UseCardinals: 1,
                  			windunits: "mph", // bft or mph
                      			module: 'MMM-WunderGround', // Just for forecast
                      			position: 'top_right',
                          		apikey: 'YOUR API KEY AGAIN', // private; don't share!
                  			currentweather: 0,
                          		coloricon: true,
                          		hourly: '1',
                          		fctext: '1',
                          		fcdaycount: "10",
                          		fcdaystart: "1",
                          		hourlyinterval: "2",
                          		hourlycount: "1",
                          		alerttime: 10000,
                          		alerttruncatestring: "english:",
                      			roundTmpDecs: 0,
                      			UseCardinals: 1,
                      			layout: "vertical",
                  			windunits: "mph",
                      			sysstat: "0"
                  And this is the WunderGround entry in my custom.css file. To customize things like color, icons, position, size, etc…
                  .region.top.right .MMM-WunderGround table th {
                    display: none; /* removes icons above max-temp, min-temp and % chance of rain */
                    color: #f66;
                    color: #0ff;
                    color: #f93;
                    color: #6f6;
                  .region.top.center .MMM-WunderGround table.small,   /* selector for ONLY current weather Thanks to Strawberry-3.141 */
                  .region.top.right .MMM-WunderGround table:not(.small),   /* selector for ONLY weather forecast */
                    display: none;    /* this line and line above selector for NO rain amount column */
                  I hope this clears things up for you
                  J 3 Replies Last reply Reply Quote 0
                    jbeck615 @Mykle1
                    @Mykle1 sorry i meant to say the js files not the config. i swear im not as dumb as im sounding here! however your clarification did make sense so thank you!
                      jbeck615 @Mykle1
                      @Mykle1 but just to make sure, changes only go in the config.js file in the config folder, dont touch the js files in each of hte modules, and if needed, modify the css files in each module correct? ive just been a bull in a china shop even if most of it is working well. thanks!
                      Mykle1M jproehlJ 2 Replies Last reply Reply Quote 0
                        Each module has a ReadMe that describes the config.js options. You’re not really changing the config.js file. You’re choosing options that the author has provided
                        Correct. Those are part of the module itself
                        You modify the custom.css file FOR each module, not IN the module folder
                        • 6
                        • 7
                        • 8
                        • 9
                        • 7 / 9
