    Throwing down the gauntlet
    85 Posts 11 Posters 104.6k Views 11 Watching
      Mykle1 Project Sponsor Module Developer @cyberphox
      @cyberphox said in Throwing down the gauntlet:
      @Mykle1 ok so turns out all this time I was using an older WunderGround module. Once I did a git pull and updated - bam - there were the realistic icons!
      Yup, that’ll do it. You won’t forget that ever again, will ya? ;-)
      Now I have to play with widths! how did you manage to fit your calendar, date/weather, and weather forecast all along the top! LOL
      in custom.css
      body {
        margin: 20px; /* This made the entire screen have a 20px border. Thanks to Strawberry-3.141  */
        height: calc(100% - 40px);
        width: calc(100% - 40px);
      That gives you a margin of only 20pixels around the entire screen. You can go even closer but I didn’t want anything too close to the edge. That’s enough to gain you some more real estate. Also, I have my monitor set to its highest resolution. You might want to try that.
      Then I simply put calendar in top_left, date and weather both top_middle and weather forecast top_right.
      C 1 Reply Last reply Reply Quote 1
      • C Offline
        cyberphox @Mykle1
        @Mykle1 Tried adding the CSS and didn’t really seem like anything changed. Checked my monitor settings in Display settings and it said it detected my monitor at 1015x1856
        Maybe I’m not getting a full 1200x1920 resolution?
        Never mind…running tvservice -s shows 1920x1080 resolution…must be something little i am missing again!
        • C Offline
          cyberphox
          This post is deleted!
            Advokaten
            Thanks for posting this! I just have a problem with systemstats-module. If I have a space between “System” and “Load”, the two words will go into two lines. If I write in “System_Load”, however, I get it to stay on one line. It’s like there’s a < br > hidden somewhere lol. Any ideas? Thanks again.
            • KimzerK Offline
              Kimzer
              Can someone please tell me how i can change the color of the numbers next to the sun? The 17.3 degrees bit.
              alt text
              And here, can someone please tell me how i can change the color of the song title, there are two of them in white so both preferably.
              alt text
              • 6
              • 7
              • 8
              • 9
              • 9 / 9
