    Throwing down the gauntlet
    85 Posts 11 Posters 102.1k Views 11 Watching
      jbeck615 @Mykle1
      @Mykle1 yep on the same page now! ill stop messing with the js files in each modules folder. thanks
        Mykle1 Project Sponsor Module Developer @jbeck615
        @jbeck615 said in Throwing down the gauntlet:
        You’re welcome. I did it too, at first
        • jproehlJ Offline
          jproehl @jbeck615
          @jbeck615 The custom.css file is in the css directory in /pi/MagicMirror not within each module directory.
            jbeck615 @jproehl
            @jproehl yep i am aligned after getting that clarification earlier. HUGE thanks
              jbeck615 @Mykle1
              @Mykle1 quick question, at the bottom of the css coding above, what does “selector” mean? thanks again!
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @jbeck615
                @jbeck615 it’s kind of a query to which elements you want a css rule to be applied
                • C Offline
                  cyberphox
                  Almost accomplished this look today. Got some duplicate weather showing up I’m sure I can fix. The main problem I’m having is: No Realistic icons for weather at all. :(
                    Mykle1 Project Sponsor Module Developer @cyberphox
                    @cyberphox said in Throwing down the gauntlet:
                    Are you using WunderGround weather? If so, make sure you have coloricon: true, in your config. Like this.
                    module: 'MMM-WunderGround', // Just for current weather
                        			position: 'top_center',
                            		apikey: 'YOUR API KEY', // private; don't share!
                            		pws: 'pws:KNYNEWYO103', // Richmondtown Weather Station - Very Cool
                    			currentweather: 1,
                            		coloricon: true,
                    			animationSpeed: 5000,
                        			roundTmpDecs: 0,
                        			UseCardinals: 1,
                    			windunits: "mph", // bft or mph
                    • C Offline
                      cyberphox @Mykle1
                      @Mykle1 Definitely using WunderGround…got the colors changed and have coloricon: true…gonna go double check it again! lol
                      • C Offline
                        cyberphox
                        @Mykle1 ok so turns out all this time I was using an older WunderGround module. Once I did a git pull and updated - bam - there were the realistic icons!
                        Now I have to play with widths! how did you manage to fit your calendar, date/weather, and weather forecast all along the top! LOL
                        • 6
                        • 7
                        • 8
                        • 9
                        • 8 / 9
