    My configuration. Js
    7 Posts 4 Posters 3.2k Views 4 Watching
    • V Offline
      videogame95
      I used to be able to change the" localhost “to” 0.0.0.0"
      Its I cannot use this any more ?
      I add remote control to turn on off modules.
      What can I put in the “Localhost” in stead of “0.0.0.0”
      I also would change the brackets to this [] so i can have open post on all IP address.
      Any help please
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @videogame95
        @videogame95 why can’t you use “0.0.0.0”?
        I do it all the time
        • BKeyportB Offline
          BKeyport Module Developer @videogame95
          @videogame95 Both should be fully functional - unless you use specific modules, in which case you’d have to set the IP address to the address of the mirror. (192.168.0.x, typical)
            sdetweil @BKeyport
            @BKeyport which modules require specific address… I haven’t seen one yet.
            I know a few that want not “locahost”, but “0.0.0.0” works…
            there is a bug on windows recently with “0.0.0.0”… I posted an issue, and a proposed fix… just no PR yet
            • BKeyportB Offline
              @sdetweil I know one of the camera apps does it.
              • T Offline
                TDMPro2K
                  sdetweil @TDMPro2K
                  @TDMPro2K that is the same as localhost.which means only apps INSIDE the same machine can connect
