Modules to display Stock (Capital Stock)
I want to display few stocks on my MM2, but there are three plugings, and neither of them are usefull.
Here are the 3 modules
Problem: Everytime I add this module, I get the message to check the config.js file.
I tpyed the exact same thing as the readme (also updated the position tag and removed the comments ) but no sucess.Problem: The name of the folder doesn’t match the name of the module in the .js file. Can that be the problem? If so, how to fix it? If no, then why does my MagicMirror load as a blank black screen whenever this module is added?
MagicMirror works properly when the above modules are removed from the config.js.
Problem: This works perfectly fine, except it is displayed as a ticker. I want to to be displayed a normal list (like calendar events). Also this module usess the google finance API (unlike the above two which use the yahoo finance API 8)), which doesn’t support other things like comodities, Currency, etc.
Last thing, how do I uninstall a module? Simply delete the folder in the modules directory after removing he code from the config file?Yes that’s the way to do it.
Because modules with similar names can also be causing problems. I think.
first module
{ module: 'MMM-Stock', position: 'top_right', config: { companies: ['MSFT', 'GOOG', 'ORCL', 'FB'], currency: 'gbp' } }
second module: you have to rename the folder to stocks, as you mentioned the directory and the js file and inside the js file the name has to be the same.
third: create an issue on github and ask if he creates a list as config option
I’ve already tried this. Did it work for you?
@qqqqqqqq yes its working for me, but its not documented in the readme that you have to install
npm install request
in the module directory
@strawberry-3.141 said in Modules to display Stock (Capital Stock):
npm install request
in the module directoryDo i have to run that command? From the modules folder?
@qqqqqqqq
cd ~/MagicMirror/modules/MMM-Stock
then the command aboveThe second module does also not tell about installing the request dependency
The first module works, maybe I was doing something wrong.
Does it take forever to load for you too?
@qqqqqqqq
What do I make of this?
pi@raspberrypi:~/MagicMirror/modules $ npm install request /home/pi/MagicMirror/modules `-- request@2.79.0 +-- aws-sign2@0.6.0 +-- aws4@1.6.0 +-- caseless@0.11.0 +-- combined-stream@1.0.5 | `-- delayed-stream@1.0.0 +-- extend@3.0.0 +-- forever-agent@0.6.1 +-- form-data@2.1.2 | `-- asynckit@0.4.0 +-- har-validator@2.0.6 | +-- chalk@1.1.3 | | +-- ansi-styles@2.2.1 | | +-- escape-string-regexp@1.0.5 | | +-- has-ansi@2.0.0 | | | `-- ansi-regex@2.1.1 | | +-- strip-ansi@3.0.1 | | `-- supports-color@2.0.0 | +-- commander@2.9.0 | | `-- graceful-readlink@1.0.1 | +-- is-my-json-valid@2.15.0 | | +-- generate-function@2.0.0 | | +-- generate-object-property@1.2.0 | | | `-- is-property@1.0.2 | | +-- jsonpointer@4.0.1 | | `-- xtend@4.0.1 | `-- pinkie-promise@2.0.1 | `-- pinkie@2.0.4 +-- hawk@3.1.3 | +-- boom@2.10.1 | +-- cryptiles@2.0.5 | +-- hoek@2.16.3 | `-- sntp@1.0.9 +-- http-signature@1.1.1 | +-- assert-plus@0.2.0 | +-- jsprim@1.3.1 | | +-- extsprintf@1.0.2 | | +-- json-schema@0.2.3 | | `-- verror@1.3.6 | `-- sshpk@1.10.2 | +-- asn1@0.2.3 | +-- assert-plus@1.0.0 | +-- bcrypt-pbkdf@1.0.1 | +-- dashdash@1.14.1 | | `-- assert-plus@1.0.0 | +-- ecc-jsbn@0.1.1 | +-- getpass@0.1.6 | | `-- assert-plus@1.0.0 | +-- jodid25519@1.0.2 | +-- jsbn@0.1.1 | `-- tweetnacl@0.14.5 +-- is-typedarray@1.0.0 +-- isstream@0.1.2 +-- json-stringify-safe@5.0.1 +-- mime-types@2.1.14 | `-- mime-db@1.26.0 +-- oauth-sign@0.8.2 +-- qs@6.3.1 +-- stringstream@0.0.5 +-- tough-cookie@2.3.2 | `-- punycode@1.4.1 +-- tunnel-agent@0.4.3 `-- uuid@3.0.1 npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json' npm WARN modules No description npm WARN modules No repository field. npm WARN modules No README data npm WARN modules No license field.
@qqqqqqqq you can ignore these warnings
3rd module with google finance works for me just fine, all you need it to find the correct ticker. For currency try “CURRENCY:EURUSD”, for commodities unfortunately you will need to find some substitute. You can try “NYSEARCA: USO” or “NYSEARCA: BNO” in case of crude oil.
