    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 25.9k Views 7 Watching
    • slametpsS Offline
      slametps
      Description:
      A MM-module to display ayah/verse of Quran randomly from https://alquran.cloud.
      Download:
      [card:slametps/MMM-RandomQuranAyah]
      Screenshot
      Initial Version
      regards,
      Slamet PS
      • L Offline
        lolobyte
        Nice,it’s similar to Bible Verse module.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @lolobyte
          @lolobyte said in MMM-RandomQuranAyah:
          yap, i got the idea from that module.
          regards,
          Slamet PS
          • slametpsS Offline
            slametps @slametps
            @MichMich If you may, can add this module to the 3rd party MM-modules list. Thx in advance.
            regards,
            Slamet PS
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @slametps
              @slametps you can add that yourself https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules/_edit
              • slametpsS Offline
                slametps @strawberry 3.141
                @strawberry-3.141 Thx. Done.
                regards,
                Slamet PS
                • Z Offline
                  zam
                  Jazakallah , if you can please try to implement a Module for ADAN it will be very usefull :)
                  slametpsS 2 Replies Last reply Reply Quote 0
                  • slametpsS Offline
                    slametps @zam
                    @zam I’m still working on a new module MMM-PrayerTime including playing Adzan. Hope it will release in this weekend.
                    regards,
                    Slamet PS
                    • slametpsS Offline
                      slametps @zam
                      @zam said in MMM-RandomQuranAyah:
                      @zam It is available now, MMM-PrayerTime for displaying praying time with adhan recital.
                      regards,
                      Slamet PS
                      Z G 2 Replies Last reply Reply Quote 1
                      • Z Offline
                        zam @slametps
                        @slametps Wonderfull Let me try first , Sukran Jaseelan :)
                        • slametpsS Offline
                          slametps @zam
                          @zam you’re welcome.
                          regards,
                          Slamet PS
                          Z 1 Reply Last reply Reply Quote 0
                          • Z Offline
                            zzaidi148 @slametps
                            @slametps I tried setting up this module put it doesnt allow my magic mirror to work. I downloaded the module, put the config in my config.js and got a failed config. I put it in jshint and found nothing. Below is my config. Please help. Thank You.
                            		module: 'MMM-RandomQuranAyah',
                            		position: 'top_bar',
                            			apiVersion: '1.0' /
                            			showArabic: true,
                            			showTranslation: true,
                            			surahArabicName:false,
                            			translationLang:'id.indonesian',
                            			updateInterval: 3600 * 1000,
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar",
                            			module: "clock",
                            • slametpsS Offline
                              slametps @zzaidi148
                              @zzaidi148 said in MMM-RandomQuranAyah:
                              			apiVersion: '1.0' /
                              			showArabic: true,
                              			module: "alert",
                              			module: "clock",
                              You should remove update_notification module (or change the location) because it override the same location.
                              regards,
                              Slamet PS
                              • Z Offline
                                zzaidi148 @slametps
                                @slametps Tried that but still didn’t load up magic mirror
                                • slametpsS Offline
                                  slametps @zzaidi148
                                  Can you post the pm2 or MM log?
                                  regards,
                                  Slamet PS
                                  • Z Offline
                                    zzaidi148 @slametps
                                    @slametps I’m a noob at this but this is the log on my terminal:
                                    > magicmirror@2.1.3 start /home/pi/MagicMirror
                                    > sh run-start.sh
                                    Starting MagicMirror: v2.1.3
                                    Loading config ...
                                    WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                    Loading module helpers ...
                                    No helper found for module: helloworld.
                                    All module helpers loaded.
                                    Server started ...
                                    Launching application.
                                    • slametpsS Offline
                                      slametps @zzaidi148
                                      > sh run-start.sh
                                      Loading config ...
                                      Server started ...
                                      What you got on the screen? Pls post the screen capture here.
                                      regards,
                                      Slamet PS
                                      • Z Offline
                                        zzaidi148 @slametps
                                        @slametps it just said to recheck your config
                                        • slametpsS Offline
                                          slametps @zzaidi148
                                          Can you post your whole config? It seems your config is the problem.
                                          regards,
                                          Slamet PS
                                          • slametpsS Offline
                                            slametps @slametps
                                            @slametps said in MMM-RandomQuranAyah:
                                            There is character / after config ApiVersion. Pls remove it.
                                            regards,
                                            Slamet PS
