    Default calendar is just loading! (Newbie)
    23 Posts 2 Posters 5.2k Views 2 Watching
      Max 0
      I`ve tried to personalize the default calendar module, but since I changed the code it is just loading and showing the header. I´ve already re-programmed the code of the standard calendar, but that changes absolutly nothing. I´ve also tried it with the MMM-MyCalendar Module but even that doesn´t help.
      I have quadruple checked the code in the config file of both modules but couldn´t find an error. Also in the developers menu there isn´t an error shown. Does someone can help me? :upside-down_face: If you need more information just ask!
        Max 0
        I tried to delete and reinstall the whole programm. But now it won´t even start anymore and the last message in the terminal is “MESA-LOADER: failed to retrieve device information”
          sdetweil @Max 0
          @Max-0 the calendar ics parser runs in the node_helper… its messages are output in the npm start window… or if using pm2 to autostart ,
          pm2 logs --lines=100
          you can also add “DEBUG” to the
          in config.js
          because there is so much output, I would do
          pm2 stop all
          cd ~/MagicMirror
          npm start >somefile.txt 2>&1
          then after MM starts and no calendar appears… wait 15 secconds
          ctrl-m on the MM window to minimize and press ctrl-c to stop mm.
          the the contents of somefile.txt will give me the info to debug
          send to this same userid at gmail
          don’t post here or in mm issue as there is private data shown in the logs
            Max 0 @sdetweil
            This post is deleted!
              Max 0
              @sdetweil I think I sent an email?
                sdetweil @Max 0
                @Max-0 I do not see any email
                  Max 0
                  What is the exact gmail?
                    sdetweil @Max 0
                    @Max-0 what is my username here
                    use that at gmail
                    .com
                    sorry I won’t type it out these pages are scanned
                    for seat engines and no chatgpt type ai engines
                      Max 0 @sdetweil
                      @sdetweil I just did that?
                      Is that correct? yes.
                        sdetweil @Max 0
                        @Max-0 but you did not set the debug in config.js first
                        M S 2 Replies Last reply Reply Quote 0
                          Max 0 @sdetweil
                          @sdetweil If you mean to add “DEBUG” in the config list, i did that but i can do it again and send you another mail
                          • 1 / 3
