    MMM-DHT22
    27 Posts 9 Posters 11.4k Views 9 Watching
    • J
      Jonae
      DHT22 Sensor MagicMirror Module!
      🌤️ This module utilizes the DHT22 sensor to fetch current temperature and humidity readings from your surroundings. Whether you’re interested in keeping tabs on your living space, monitoring your indoor garden, or simply satisfying your curiosity about the weather, this module has got you covered.
      Key Features:
      Real-time Data: Get instant access to the latest temperature and humidity levels right on your MagicMirror.
      Customizable: Tailor the module’s appearance to suit your mirror’s aesthetics and layout.
      Easy Integration: Our step-by-step setup guide ensures a hassle-free installation process.
      Reliable Performance: We built this module out of the need for a functional and stable solution, so you can count on its consistent performance.
      🛠️ Installation and Usage:
      Installing the DHT22 Sensor MagicMirror Module is a breeze. Simply follow the installation guide provided in the GitHub post to seamlessly integrate the module into your MagicMirror setup. Once configured, you’ll have the temperature and humidity readings beautifully displayed on your mirror.
      Screenshots:
      alt text
      alt text
      alt text
      🔗 GitHub Repository
      Because i didn’t find any working module using DHT22 sensor, i decided to build this one. I hope it helps someone.
      ankonaskiff17A BKeyportB 2 Replies Last reply Reply Quote 2
      • ankonaskiff17A
        ankonaskiff17 @Jonae
        @Jonae Have you by chance done or looked at any sensors that use I2C?
        • BKeyportB
          BKeyport Module Developer @Jonae
          @Jonae Nicely done.
          I’ve used MMM-CommandToNotifcation/MMM-ValuesByNotification for mine, with MMM-Temperature prior to that. Nice to have a specific to device module, though. :)
          • J
            Jonae @ankonaskiff17
            @ankonaskiff17 said in MMM-DHT22:
            No
            • J
              Jonae @BKeyport
              @BKeyport said in MMM-DHT22:
              @Jonae Nicely done.
              Thanks for apreciations.
              • J
                Jonae @Jonae
                @Jonae
                Version info:
                Version info:
                v1.0.0 - Initial release
                v1.0.1 - Added option to modify the color of the temperature and humidity icons
                              - Added option to modify the header size
                v1.0.2 - Fix the error readings from sensor
                              - Added option to calibrate the sensor readings
                              - Added option to change units: C or F
                GitHub Repository
                • J
                  Jonae @Jonae
                  Version info:
                  v1.0.3 - added default layout style (‘horizontal’ or ‘vertical’)
                  GitHub Repository
                  • J
                    JohnGalt
                    Thanks for your work - it looks good and has the offset feature I need! Like @BKeyport I formerly used MMM-LocalTemperature, but it won’t run on my new MagicMirror build.
                    For context, I currently do have MMM-DHT-Sensor running on this instance. It runs just fine, but I would prefer the look and feel of yours, as well as needing the offset feature. I have also tried changing from GPIO 4 to GPIO 21 - same results [MMM-DHT-Sensor works on either, MMM-DHT22 works on neither].
                    My issue with MMM-DHT22 is understanding whether one can get it to run on a Raspberry Pi 4? I have been unable to do so, and it appears to be issues with the Adafruit_Python_DHT libraries. My research appears to show your module relies on that Adafruit library, and the Adafruit library doesn’t support Raspberry Pi 4.
                    Am I missing something? If so, what? If not, is there a workaround?
                    • BKeyportB
                      BKeyport Module Developer @JohnGalt
                      @JohnGalt I had no trouble with the Adafruit libraries on Pi4. It should be working just fine - Take a look around https://forums.adafruit.com/ - there might be fixes or something available.
                      • J
                        JohnGalt @BKeyport
                        @BKeyport thanks for the response. It looks like my issue is actually with the Linux 12 / bookworm version of Raspbian I installed when rebuilding my MagicMirror, as opposed to the R-Pi 4 hardware.
                        In reading the Adafruit forums here: https://forums.adafruit.com/viewtopic.php?p=938344&hilit=Adafruit_Python_DHT#p938344 I find the official Adafruit response to someone with the same issues is that “DHT22 really sucks to use on linux” and … “you will be a lot happier just using the DHT20 and friends”, with a reference to an Adafruit web article at https://learn.adafruit.com/modern-replacements-for-dht11-dht22-sensors/overview.
                        In short, the advice is to just buy all new sensors for your Raspberry Pi installs. The OP pointed out that while he acknowledges the newer sensors may indeed be better, that " I spent a good amount of money buying and building, and for all of that to go away with an update really stinks! :( ".
                        I agree with him since I have probably five (5) DHT 11/22 sensors working on R-Pis, and while it looks like he found a way to upgrade all pip libraries and get it working again, it also appears to only be a matter of time until another update or upgrade of something breaks the system.
                        Again thanks for pointing me in the right direction.
                        • BKeyportB
                          @JohnGalt I’m betting LadyAda and co are working on a fix all the same. They’re big on keeping old hardware working.
                          • J
                            JohnGalt @BKeyport
                            @BKeyport - That has been my general impression of Adafruit, and for the sake of general continuity, I do hope that is the case. All that said, the situation with the sensor libraries has been a mess for years - with my personal favorite gripe being libraries being deprecated without clear messaging on the website hosting the old, together with new libraries with very similar names but different functionality. For the life of me I cannot understand why simply incrementing the version numbering wouldn’t have accomplished what was needed [accompanied of course, by clear messaging…].
                            Meanwhile I have ordered and received some DHT20 sensors, and will soon begin standing some of those up. This has entailed first building a development instance to work on, as I find the MagicMirror system to be fragile, and I want to minimize downtime on the production instance. As of yesterday I do have the dev instance running and am trying to iron out a couple of wrinkles, like tracking down why and how the default calendar module on the new dev instance doesn’t display recurring appointments the same as on the existing [production] instance. Seeing as I literally copied and pasted the configuration code from the old to the new, I would think it would perform the same.
                            Anyway - thanks again for the input and the guidance, as always.
                            • M
                              Michi0904
                              This post is deleted!
                              • J
                                Jimmy1502
                                Hello, im quite new to the MagicMirror and I only have basic Programming Knowledge. I tried using ur Module and i strictly followed ur guide, but it doesnt work. The module itself is loading even th icons, but there are no numbers visible. I tried to check the library but it doesnt work.
                                Is it a Problem on my side or a Problem with the adafruit library?
                                Thx for your help.
                                • bugsounetB bugsounet referenced this topic on
                                • L
                                  lif
                                  I have installed the module but get the following when I try to run your test ‘python3 AdafruitDHT.py 22 26’
                                  I know the DHT-22 works on GPIO pin 26
                                  ~/Adafruit_Python_DHT/examples $ sudo python3 AdafruitDHT.py 22 26
                                  Traceback (most recent call last):
                                  File “/home/pi/Adafruit_Python_DHT/examples/AdafruitDHT.py”, line 41, in
                                  humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
                                  File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 94, in read_retry
                                  humidity, temperature = read(sensor, pin, platform)
                                  File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 80, in read
                                  platform = get_platform()
                                  File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 63, in get_platform
                                  raise RuntimeError(‘Unknown platform.’)
                                  RuntimeError: Unknown platform.
                                  Any thoughts?
                                  • BKeyportB
                                    BKeyport Module Developer @lif
                                    @lif It’s requiring tools no longer available, so dead module. Use something else.
                                    https://github.com/Tom-Hirschberger/MMM-Temperature is what I used when I had a module hooked up to it.
                                    L 1 Reply Last reply Reply Quote 1
                                    • L
                                      lif @BKeyport
                                      Thanks, I’ve given it a try but get an error in the last stage of the installation
                                      ~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
                                        File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/./dht22", line 6, in <module>
                                          import board
                                        File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/board.py", line 51, in <module>
                                          from adafruit_blinka.board.raspberrypi.raspi_40pin import *
                                        File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/board/raspberrypi/raspi_40pin.py", line 6, in <module>
                                          from adafruit_blinka.microcontroller.bcm283x import pin
                                        File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/bcm283x/pin.py", line 7, in <module>
                                          from adafruit_blinka.microcontroller.generic_linux.rpi_gpio_pin import Pin
                                        File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/rpi_gpio_pin.py", line 6, in <module>
                                          from RPi import GPIO
                                      ModuleNotFoundError: No module named 'RPi'
                                      BKeyportB L 2 Replies Last reply Reply Quote 0
                                      • BKeyportB
                                        @lif I’m not sure on that, @wishmaster270 (Tom) would know more.
                                        • L
                                          lif @lif
                                          Thanks, not the end of the world if I can’t use it.
                                          • wishmaster270W
                                            wishmaster270 Module Developer @lif
                                            @lif Hi. Great you want to try one of my modules.
                                            Can you try installing a additional python system package with
                                            sudo apt install python3-rpi-lgpio
                                            I tried the scripts on my newly installed system with Bookworm and everything worked as expected.
                                            Maybe the missing package had been installed with something else I installed on my system.
