    MMM-DHT22
    27 Posts 9 Posters 10.1k Views 9 Watching
    • L Offline
      lif @wishmaster270
      @wishmaster270 said in MMM-DHT22:
      @lif Hi. Great you want to try one of my modules.
      Can you try installing a additional python system package with
      sudo apt install python3-rpi-lgpio
      I tried the scripts on my newly installed system with Bookworm and everything worked as expected.
      Maybe the missing package had been installed with something else I installed on my system.
      Thanks, that was already installed
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      python3-rpi-lgpio is already the newest version (0.6-0~rpt1).
      0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
      This is on Bookworm
      • wishmaster270W Offline
        wishmaster270 Module Developer @lif
        @lif
        That’s strange…Can you try to start with a new, fresh virtual python environment and install the needed libs again?
        Remove old virtual environment:
        rm -rf /home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv
        Install the needed system libs:
        sudo apt -y update && sudo apt -y install python3-venv libgpiod2
        Re-Create the virtual environment:
        cd ~/MagicMirror/modules/MMM-Temperature/scripts
        ./venvWrapper.py --verbose --venv-name py-venv --create
        Re-Install the libs:
        ./venvWrapper.py --venv-name py-venv --install-libs adafruit-circuitpython-dht
        Run the test again:
        ./venvWrapper.py --venv-name py-venv --run ./dht22
        If it fails again. Can you please provide the output of
        source py-venv/bin/activate
        pip freeze
        deactivate
        The output should look something like:
        Adafruit-Blinka==8.66.1
        Adafruit-Blinka-Raspberry-Pi5-Neopixel==1.0.0rc2
        adafruit-circuitpython-busdevice==5.2.13
        adafruit-circuitpython-connectionmanager==3.1.5
        adafruit-circuitpython-dht==4.0.9
        adafruit-circuitpython-requests==4.1.13
        adafruit-circuitpython-typing==1.12.2
        Adafruit-PlatformDetect==3.83.2
        Adafruit-PureIO==1.1.11
        binho-host-adapter==0.1.6
        lgpio==0.2.2.0
        pyftdi==0.57.1
        pyserial==3.5
        pyusb==1.3.1
        rpi-ws281x==5.0.0
        RPi.GPIO==0.7.1
        sysv-ipc==1.1.0
        typing_extensions==4.15.0
          sdetweil @wishmaster270
          @wishmaster270 AND you must enable the virtual env in the script if pm2 starts MagicMirror
            wishmaster270 Module Developer @sdetweil
            @sdetweil Hi sam. My wrapper script will use the python binary in the virtual environment folder. This way the environment will be activated automatically.
              @wishmaster270 cool, you have the venv in the module folder
              • L Offline
                lif
                Same failure on install.
                from RPi import GPIO
                ModuleNotFoundError: No module named 'RPi'
                The output of pip freeze is ```
                MagicMirror/modules/MMM-Temperature/scripts $ source py-venv/bin/activate
                (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ pip freeze
                Adafruit-Blinka==8.66.2
                Adafruit-PlatformDetect==3.84.0
                pyftdi==0.57.1
                pyserial==3.5
                pyusb==1.3.1
                sysv-ipc==1.1.0
                (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ deactivate
                The only difference from yours is mine is missing the second line.
                Hope this helps
                • L Offline
                  lif
                  I’ve gone through your procedure again and this time it works.
                  The only difference is that I run a python3 script to control screen blanking using a PIR before starting Magic Mirror, this time I didn’t start that script.
                  With the PIR script and MagicMirror running I get:
                  pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
                  {"temperature_c": 23.5, "humidity": 53.7, "temperature_f": 74.30000000000001, "error": false}
                  {"temperature_c": 0.0, "humidity": 0.0, "temperature_f": 32.0, "error": true}
                  {"temperature_c": 23.6, "humidity": 53.5, "temperature_f": 74.48, "error": false}
                  {"temperature_c": 23.7, "humidity": 53.3, "temperature_f": 74.66, "error": false}
                  {"temperature_c": 23.8, "humidity": 53.2, "temperature_f": 74.84, "error": false}
                  I can live with that.
                  Thanks for all your help
