    MMM-DHT22
    27 Posts 9 Posters 10.8k Views 9 Watching
    • BKeyportB Offline
      BKeyport Module Developer @JohnGalt
      @JohnGalt I’m betting LadyAda and co are working on a fix all the same. They’re big on keeping old hardware working.
        JohnGalt @BKeyport
        @BKeyport - That has been my general impression of Adafruit, and for the sake of general continuity, I do hope that is the case. All that said, the situation with the sensor libraries has been a mess for years - with my personal favorite gripe being libraries being deprecated without clear messaging on the website hosting the old, together with new libraries with very similar names but different functionality. For the life of me I cannot understand why simply incrementing the version numbering wouldn’t have accomplished what was needed [accompanied of course, by clear messaging…].
        Meanwhile I have ordered and received some DHT20 sensors, and will soon begin standing some of those up. This has entailed first building a development instance to work on, as I find the MagicMirror system to be fragile, and I want to minimize downtime on the production instance. As of yesterday I do have the dev instance running and am trying to iron out a couple of wrinkles, like tracking down why and how the default calendar module on the new dev instance doesn’t display recurring appointments the same as on the existing [production] instance. Seeing as I literally copied and pasted the configuration code from the old to the new, I would think it would perform the same.
        Anyway - thanks again for the input and the guidance, as always.
          Michi0904
            Jimmy1502
            Hello, im quite new to the MagicMirror and I only have basic Programming Knowledge. I tried using ur Module and i strictly followed ur guide, but it doesnt work. The module itself is loading even th icons, but there are no numbers visible. I tried to check the library but it doesnt work.
            Is it a Problem on my side or a Problem with the adafruit library?
            Thx for your help.
            • bugsounetB bugsounet referenced this topic on
            • L Offline
              lif
              I have installed the module but get the following when I try to run your test ‘python3 AdafruitDHT.py 22 26’
              I know the DHT-22 works on GPIO pin 26
              ~/Adafruit_Python_DHT/examples $ sudo python3 AdafruitDHT.py 22 26
              File “/home/pi/Adafruit_Python_DHT/examples/AdafruitDHT.py”, line 41, in
              humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
              File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 94, in read_retry
              humidity, temperature = read(sensor, pin, platform)
              File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 80, in read
              platform = get_platform()
              File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 63, in get_platform
              raise RuntimeError(‘Unknown platform.’)
              RuntimeError: Unknown platform.
              Any thoughts?
              • BKeyportB Offline
                BKeyport Module Developer @lif
                @lif It’s requiring tools no longer available, so dead module. Use something else.
                https://github.com/Tom-Hirschberger/MMM-Temperature is what I used when I had a module hooked up to it.
                • L Offline
                  lif @BKeyport
                  @BKeyport said in MMM-DHT22:
                  Thanks, I’ve given it a try but get an error in the last stage of the installation
                  ~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
                    File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/./dht22", line 6, in <module>
                      import board
                    File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/board.py", line 51, in <module>
                      from adafruit_blinka.board.raspberrypi.raspi_40pin import *
                    File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/board/raspberrypi/raspi_40pin.py", line 6, in <module>
                      from adafruit_blinka.microcontroller.bcm283x import pin
                    File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/bcm283x/pin.py", line 7, in <module>
                      from adafruit_blinka.microcontroller.generic_linux.rpi_gpio_pin import Pin
                    File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/rpi_gpio_pin.py", line 6, in <module>
                      from RPi import GPIO
                  ModuleNotFoundError: No module named 'RPi'
                  BKeyportB L 2 Replies Last reply Reply Quote 0
                  • BKeyportB Offline
                    @lif I’m not sure on that, @wishmaster270 (Tom) would know more.
                    • L Offline
                      lif @lif
                      Thanks, not the end of the world if I can’t use it.
                      • wishmaster270W Offline
                        wishmaster270 Module Developer @lif
                        @lif Hi. Great you want to try one of my modules.
                        Can you try installing a additional python system package with
                        sudo apt install python3-rpi-lgpio
                        I tried the scripts on my newly installed system with Bookworm and everything worked as expected.
                        Maybe the missing package had been installed with something else I installed on my system.
                        • L Offline
                          lif @wishmaster270
                          @wishmaster270 said in MMM-DHT22:
                          Thanks, that was already installed
                          Reading package lists... Done
                          Building dependency tree... Done
                          python3-rpi-lgpio is already the newest version (0.6-0~rpt1).
                          0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                          This is on Bookworm
                            @lif
                            That’s strange…Can you try to start with a new, fresh virtual python environment and install the needed libs again?
                            Remove old virtual environment:
                            rm -rf /home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv
                            Install the needed system libs:
                            sudo apt -y update && sudo apt -y install python3-venv libgpiod2
                            Re-Create the virtual environment:
                            cd ~/MagicMirror/modules/MMM-Temperature/scripts
                            ./venvWrapper.py --verbose --venv-name py-venv --create
                            Re-Install the libs:
                            ./venvWrapper.py --venv-name py-venv --install-libs adafruit-circuitpython-dht
                            Run the test again:
                            If it fails again. Can you please provide the output of
                            source py-venv/bin/activate
                            pip freeze
                            deactivate
                            The output should look something like:
                            Adafruit-Blinka==8.66.1
                            Adafruit-Blinka-Raspberry-Pi5-Neopixel==1.0.0rc2
                            adafruit-circuitpython-busdevice==5.2.13
                            adafruit-circuitpython-connectionmanager==3.1.5
                            adafruit-circuitpython-dht==4.0.9
                            adafruit-circuitpython-requests==4.1.13
                            adafruit-circuitpython-typing==1.12.2
                            Adafruit-PlatformDetect==3.83.2
                            Adafruit-PureIO==1.1.11
                            binho-host-adapter==0.1.6
                            lgpio==0.2.2.0
                            pyftdi==0.57.1
                            pyserial==3.5
                            pyusb==1.3.1
                            rpi-ws281x==5.0.0
                            RPi.GPIO==0.7.1
                            sysv-ipc==1.1.0
                            typing_extensions==4.15.0
                              sdetweil @wishmaster270
                              @wishmaster270 AND you must enable the virtual env in the script if pm2 starts MagicMirror
                                wishmaster270 Module Developer @sdetweil
                                @sdetweil Hi sam. My wrapper script will use the python binary in the virtual environment folder. This way the environment will be activated automatically.
                                  @wishmaster270 cool, you have the venv in the module folder
                                  • L Offline
                                    lif
                                    Same failure on install.
                                    The output of pip freeze is ```
                                    MagicMirror/modules/MMM-Temperature/scripts $ source py-venv/bin/activate
                                    (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ pip freeze
                                    Adafruit-Blinka==8.66.2
                                    Adafruit-PlatformDetect==3.84.0
                                    pyftdi==0.57.1
                                    pyserial==3.5
                                    pyusb==1.3.1
                                    sysv-ipc==1.1.0
                                    (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ deactivate
                                    The only difference from yours is mine is missing the second line.
                                    Hope this helps
                                    • L Offline
                                      lif
                                      I’ve gone through your procedure again and this time it works.
                                      The only difference is that I run a python3 script to control screen blanking using a PIR before starting Magic Mirror, this time I didn’t start that script.
                                      With the PIR script and MagicMirror running I get:
                                      pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
                                      {"temperature_c": 23.5, "humidity": 53.7, "temperature_f": 74.30000000000001, "error": false}
                                      {"temperature_c": 0.0, "humidity": 0.0, "temperature_f": 32.0, "error": true}
                                      {"temperature_c": 23.6, "humidity": 53.5, "temperature_f": 74.48, "error": false}
                                      {"temperature_c": 23.7, "humidity": 53.3, "temperature_f": 74.66, "error": false}
                                      {"temperature_c": 23.8, "humidity": 53.2, "temperature_f": 74.84, "error": false}
                                      I can live with that.
                                      Thanks for all your help
