    MMM-DHT22
    27 Posts 9 Posters 12.1k Views 9 Watching
    • L
      lif
      I have installed the module but get the following when I try to run your test ‘python3 AdafruitDHT.py 22 26’
      I know the DHT-22 works on GPIO pin 26
      ~/Adafruit_Python_DHT/examples $ sudo python3 AdafruitDHT.py 22 26
      File “/home/pi/Adafruit_Python_DHT/examples/AdafruitDHT.py”, line 41, in
      humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
      File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 94, in read_retry
      humidity, temperature = read(sensor, pin, platform)
      File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 80, in read
      platform = get_platform()
      File “/usr/local/lib/python3.11/dist-packages/Adafruit_DHT-1.4.0-py3.11-linux-aarch64.egg/Adafruit_DHT/common.py”, line 63, in get_platform
      raise RuntimeError(‘Unknown platform.’)
      RuntimeError: Unknown platform.
      Any thoughts?
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @lif
        @lif It’s requiring tools no longer available, so dead module. Use something else.
        https://github.com/Tom-Hirschberger/MMM-Temperature is what I used when I had a module hooked up to it.
        L 1 Reply Last reply
        • L
          lif @BKeyport
          @BKeyport said in MMM-DHT22:
          Thanks, I’ve given it a try but get an error in the last stage of the installation
          ~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
            File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/./dht22", line 6, in <module>
              import board
            File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/board.py", line 51, in <module>
              from adafruit_blinka.board.raspberrypi.raspi_40pin import *
            File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/board/raspberrypi/raspi_40pin.py", line 6, in <module>
              from adafruit_blinka.microcontroller.bcm283x import pin
            File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/bcm283x/pin.py", line 7, in <module>
              from adafruit_blinka.microcontroller.generic_linux.rpi_gpio_pin import Pin
            File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/rpi_gpio_pin.py", line 6, in <module>
              from RPi import GPIO
          ModuleNotFoundError: No module named 'RPi'
          BKeyportB L 2 Replies Last reply
          • BKeyportB
            @lif I’m not sure on that, @wishmaster270 (Tom) would know more.
            • L
              lif @lif
              Thanks, not the end of the world if I can’t use it.
              wishmaster270W 1 Reply Last reply
              • wishmaster270W
                wishmaster270 Module Developer @lif
                @lif Hi. Great you want to try one of my modules.
                Can you try installing a additional python system package with
                sudo apt install python3-rpi-lgpio
                I tried the scripts on my newly installed system with Bookworm and everything worked as expected.
                Maybe the missing package had been installed with something else I installed on my system.
                • L
                  lif @wishmaster270
                  @wishmaster270 said in MMM-DHT22:
                  Thanks, that was already installed
                  Reading package lists... Done
                  Building dependency tree... Done
                  python3-rpi-lgpio is already the newest version (0.6-0~rpt1).
                  0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                  This is on Bookworm
                  • wishmaster270W
                    @lif
                    That’s strange…Can you try to start with a new, fresh virtual python environment and install the needed libs again?
                    Remove old virtual environment:
                    rm -rf /home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv
                    Install the needed system libs:
                    sudo apt -y update && sudo apt -y install python3-venv libgpiod2
                    Re-Create the virtual environment:
                    cd ~/MagicMirror/modules/MMM-Temperature/scripts
                    ./venvWrapper.py --verbose --venv-name py-venv --create
                    Re-Install the libs:
                    ./venvWrapper.py --venv-name py-venv --install-libs adafruit-circuitpython-dht
                    Run the test again:
                    If it fails again. Can you please provide the output of
                    source py-venv/bin/activate
                    pip freeze
                    deactivate
                    The output should look something like:
                    Adafruit-Blinka==8.66.1
                    Adafruit-Blinka-Raspberry-Pi5-Neopixel==1.0.0rc2
                    adafruit-circuitpython-busdevice==5.2.13
                    adafruit-circuitpython-connectionmanager==3.1.5
                    adafruit-circuitpython-dht==4.0.9
                    adafruit-circuitpython-requests==4.1.13
                    adafruit-circuitpython-typing==1.12.2
                    Adafruit-PlatformDetect==3.83.2
                    Adafruit-PureIO==1.1.11
                    binho-host-adapter==0.1.6
                    lgpio==0.2.2.0
                    pyftdi==0.57.1
                    pyserial==3.5
                    pyusb==1.3.1
                    rpi-ws281x==5.0.0
                    RPi.GPIO==0.7.1
                    sysv-ipc==1.1.0
                    typing_extensions==4.15.0
                      sdetweil @wishmaster270
                      @wishmaster270 AND you must enable the virtual env in the script if pm2 starts MagicMirror
                      • wishmaster270W
                        wishmaster270 Module Developer @sdetweil
                        @sdetweil Hi sam. My wrapper script will use the python binary in the virtual environment folder. This way the environment will be activated automatically.
                          @wishmaster270 cool, you have the venv in the module folder
                          • L
                            lif
                            Same failure on install.
                            The output of pip freeze is ```
                            MagicMirror/modules/MMM-Temperature/scripts $ source py-venv/bin/activate
                            (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ pip freeze
                            Adafruit-Blinka==8.66.2
                            Adafruit-PlatformDetect==3.84.0
                            pyftdi==0.57.1
                            pyserial==3.5
                            pyusb==1.3.1
                            sysv-ipc==1.1.0
                            (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ deactivate
                            The only difference from yours is mine is missing the second line.
                            Hope this helps
                            • L
                              lif
                              I’ve gone through your procedure again and this time it works.
                              The only difference is that I run a python3 script to control screen blanking using a PIR before starting Magic Mirror, this time I didn’t start that script.
                              With the PIR script and MagicMirror running I get:
                              pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
                              {"temperature_c": 23.5, "humidity": 53.7, "temperature_f": 74.30000000000001, "error": false}
                              {"temperature_c": 0.0, "humidity": 0.0, "temperature_f": 32.0, "error": true}
                              {"temperature_c": 23.6, "humidity": 53.5, "temperature_f": 74.48, "error": false}
                              {"temperature_c": 23.7, "humidity": 53.3, "temperature_f": 74.66, "error": false}
                              {"temperature_c": 23.8, "humidity": 53.2, "temperature_f": 74.84, "error": false}
                              I can live with that.
                              Thanks for all your help
