    MMM-DHT22
    27 Posts 9 Posters 12.1k Views 9 Watching
    • BKeyportB
      BKeyport Module Developer @lif
      @lif It’s requiring tools no longer available, so dead module. Use something else.
      https://github.com/Tom-Hirschberger/MMM-Temperature is what I used when I had a module hooked up to it.
      L 1 Reply Last reply
      • L
        lif @BKeyport
        @BKeyport said in MMM-DHT22:
        Thanks, I’ve given it a try but get an error in the last stage of the installation
        ~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
          File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/./dht22", line 6, in <module>
            import board
          File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/board.py", line 51, in <module>
            from adafruit_blinka.board.raspberrypi.raspi_40pin import *
          File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/board/raspberrypi/raspi_40pin.py", line 6, in <module>
            from adafruit_blinka.microcontroller.bcm283x import pin
          File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/bcm283x/pin.py", line 7, in <module>
            from adafruit_blinka.microcontroller.generic_linux.rpi_gpio_pin import Pin
          File "/home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/rpi_gpio_pin.py", line 6, in <module>
            from RPi import GPIO
        ModuleNotFoundError: No module named 'RPi'
        BKeyportB L 2 Replies Last reply
        • BKeyportB
          @lif I’m not sure on that, @wishmaster270 (Tom) would know more.
          • L
            lif @lif
            Thanks, not the end of the world if I can’t use it.
            wishmaster270W 1 Reply Last reply
            • wishmaster270W
              wishmaster270 Module Developer @lif
              @lif Hi. Great you want to try one of my modules.
              Can you try installing a additional python system package with
              sudo apt install python3-rpi-lgpio
              I tried the scripts on my newly installed system with Bookworm and everything worked as expected.
              Maybe the missing package had been installed with something else I installed on my system.
              • L
                lif @wishmaster270
                @wishmaster270 said in MMM-DHT22:
                Thanks, that was already installed
                Reading package lists... Done
                Building dependency tree... Done
                python3-rpi-lgpio is already the newest version (0.6-0~rpt1).
                0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                This is on Bookworm
                • wishmaster270W
                  @lif
                  That’s strange…Can you try to start with a new, fresh virtual python environment and install the needed libs again?
                  Remove old virtual environment:
                  rm -rf /home/pi/MagicMirror/modules/MMM-Temperature/scripts/py-venv
                  Install the needed system libs:
                  sudo apt -y update && sudo apt -y install python3-venv libgpiod2
                  Re-Create the virtual environment:
                  cd ~/MagicMirror/modules/MMM-Temperature/scripts
                  ./venvWrapper.py --verbose --venv-name py-venv --create
                  Re-Install the libs:
                  ./venvWrapper.py --venv-name py-venv --install-libs adafruit-circuitpython-dht
                  Run the test again:
                  If it fails again. Can you please provide the output of
                  source py-venv/bin/activate
                  pip freeze
                  deactivate
                  The output should look something like:
                  Adafruit-Blinka==8.66.1
                  Adafruit-Blinka-Raspberry-Pi5-Neopixel==1.0.0rc2
                  adafruit-circuitpython-busdevice==5.2.13
                  adafruit-circuitpython-connectionmanager==3.1.5
                  adafruit-circuitpython-dht==4.0.9
                  adafruit-circuitpython-requests==4.1.13
                  adafruit-circuitpython-typing==1.12.2
                  Adafruit-PlatformDetect==3.83.2
                  Adafruit-PureIO==1.1.11
                  binho-host-adapter==0.1.6
                  lgpio==0.2.2.0
                  pyftdi==0.57.1
                  pyserial==3.5
                  pyusb==1.3.1
                  rpi-ws281x==5.0.0
                  RPi.GPIO==0.7.1
                  sysv-ipc==1.1.0
                  typing_extensions==4.15.0
                    sdetweil @wishmaster270
                    @wishmaster270 AND you must enable the virtual env in the script if pm2 starts MagicMirror
                    • wishmaster270W
                      wishmaster270 Module Developer @sdetweil
                      @sdetweil Hi sam. My wrapper script will use the python binary in the virtual environment folder. This way the environment will be activated automatically.
                        @wishmaster270 cool, you have the venv in the module folder
                        • L
                          lif
                          Same failure on install.
                          The output of pip freeze is ```
                          MagicMirror/modules/MMM-Temperature/scripts $ source py-venv/bin/activate
                          (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ pip freeze
                          Adafruit-Blinka==8.66.2
                          Adafruit-PlatformDetect==3.84.0
                          pyftdi==0.57.1
                          pyserial==3.5
                          pyusb==1.3.1
                          sysv-ipc==1.1.0
                          (py-venv) pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ deactivate
                          The only difference from yours is mine is missing the second line.
                          Hope this helps
                          • L
                            lif
                            I’ve gone through your procedure again and this time it works.
                            The only difference is that I run a python3 script to control screen blanking using a PIR before starting Magic Mirror, this time I didn’t start that script.
                            With the PIR script and MagicMirror running I get:
                            pi@mm:~/MagicMirror/modules/MMM-Temperature/scripts $ ./venvWrapper.py --venv-name py-venv --run ./dht22
                            {"temperature_c": 23.5, "humidity": 53.7, "temperature_f": 74.30000000000001, "error": false}
                            {"temperature_c": 0.0, "humidity": 0.0, "temperature_f": 32.0, "error": true}
                            {"temperature_c": 23.6, "humidity": 53.5, "temperature_f": 74.48, "error": false}
                            {"temperature_c": 23.7, "humidity": 53.3, "temperature_f": 74.66, "error": false}
                            {"temperature_c": 23.8, "humidity": 53.2, "temperature_f": 74.84, "error": false}
                            I can live with that.
                            Thanks for all your help
