    Error starting after upgrade
    41 Posts 5 Posters 16.4k Views 5 Watching
    • C Offline
      chris_d
      Having applied the latest update I am having an issue starting.
      Output as below.
      Any pointers as to what might be going wrong?
      > magicmirror@2.25.0 start /home/pi/MagicMirror
      [04.10.2023 17:23.09.921] [LOG]   Starting MagicMirror: v2.25.0
      [04.10.2023 17:23.09.938] [LOG]   Loading config ...
      [04.10.2023 17:23.09.944] [DEBUG] config template file not exists, no envsubst
      [04.10.2023 17:23.09.954] [LOG]   Loading module helpers ...
      [04.10.2023 17:23.09.956] [LOG]   No helper found for module: alert.
      [04.10.2023 17:23.09.989] [LOG]   Initializing new module helper ...
      [04.10.2023 17:23.09.991] [LOG]   Module helper loaded: updatenotification
      [04.10.2023 17:23.09.992] [LOG]   No helper found for module: clock.
      [04.10.2023 17:23.10.576] [LOG]   Initializing new module helper ...
      [04.10.2023 17:23.10.577] [LOG]   Module helper loaded: MMM-Todoist
      [04.10.2023 17:23.10.844] [LOG]   Initializing new module helper ...
      [04.10.2023 17:23.10.844] [LOG]   Module helper loaded: calendar
      [04.10.2023 17:23.10.846] [LOG]   No helper found for module: MMM-Test.
      [04.10.2023 17:23.10.847] [LOG]   No helper found for module: MMM-DogAge.
      [04.10.2023 17:23.10.848] [LOG]   No helper found for module: MMM-CalendarExt3.
      [04.10.2023 17:23.10.906] [ERROR] (node:1324) UnhandledPromiseRejectionWarning: Error: Cannot find module 'html-to-text'
      Require stack:
      - /home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js
      - /home/pi/MagicMirror/modules/default/newsfeed/node_helper.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
          at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:927:27)
          at f._load (node:electron/js2c/asar_bundle:2:13330)
          at Module.require (node:internal/modules/cjs/loader:1148:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js:11:24)
          at Module._compile (node:internal/modules/cjs/loader:1269:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1324:10)
          at Module.load (node:internal/modules/cjs/loader:1124:32)
          at Module._load (node:internal/modules/cjs/loader:965:12)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:10:25)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [04.10.2023 17:23.10.907] [ERROR] (node:1324) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      [1357:1004/172312.042226:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
        sdetweil @wwats
        @wwats try this from the n info
        Remove the installed Node.js (does not affect the cached versions). This can be useful to revert to the system version of node (if in a different location)
        sudo n prune
        sudo n uninstall
        W 1 Reply Last reply Reply Quote 1
          sdetweil @chris_d
          @chris_d looks like the npm install did not execute
          how did u upgrade? manual or my script?
          do
          node -v
          • C Offline
            chris_d @sdetweil
            v10.24.0
            I used manual upgrade running: git pull && npm run install-mm
              sdetweil @chris_d
              @chris_d you must upgrade node to at least node 18…
              use my upgrade script, it will do all the work
              because u already have 2.25, use force instead of apply on the actual upgrade step
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply <-------- change this to force
                aiprompts
                I am facing the same problem.
                  sdetweil @aiprompts
                  @aiprompts see the post above yours
                  • W Offline
                    wwats
                    I also have problems updating to Node 20. I ran the script above, apparently successfully. But version 16.13.1 is still installed
                    -> Do I have to start the installation additionally? in which directory?
                    Thank you very much
                      sdetweil @wwats
                      @wwats can you do
                      n
                      or
                      nvm
                      and see if either respond?
                      • W Offline
                        wwats @sdetweil
                        n = Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
                        -> but i can’t select a version, the screen ist black
                        -> nvm doesn’t work (-bash: nvm: Kommando nicht gefunden.)
                          sdetweil @wwats
                          @wwats there are no versions shown?
                          I see this on my dev machine
                          • W Offline
                            wwats @sdetweil
                            No, unfortunately not. i see:
                              sdetweil @wwats
                              @wwats ok, do
                              d
                              to delete it
                              then node -v
                              • W Offline
                                wwats @sdetweil
                                @sdetweil ok i did. I still have version 16.13.1 :-(
                                Am I perhaps in the wrong directory?
                                I have to run the script in the lowest directory directly at pi@raspberrypi:~ $, right?
                                  sdetweil @wwats
                                  sudo n prune
                                  sudo n uninstall
                                  • W Offline
                                    wwats @sdetweil
                                    @sdetweil ok this was sucessfull… and what do I have to do now? reinstall? How?
                                    Thank you very much and sorry, I’m not an IT specialist…
                                      sdetweil @wwats
                                      @wwats and what does
                                      node -v
                                      show now?
                                      • W Offline
                                        wwats @sdetweil
                                        pi@raspberrypi:~ $ node -v
                                        -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                                          sdetweil @wwats
                                          @wwats can u do
                                          ls -laF /usr/local/bin/node
                                          • W Offline
                                            wwats @sdetweil
                                            @sdetweil no… :
                                            pi@raspberrypi:~ $ ls -laF /usr/local/bin/node
                                            ls: Zugriff auf ‘/usr/local/bin/node’ nicht möglich: Datei oder Verzeichnis nicht gefunden
                                              sdetweil @wwats
                                              @wwats ok, try this
                                              which node
                                              on my desktop returns
                                              /usr/local/bin/node
                                              and there is a file there…
                                              • 1 / 3
