    MMM-Astrology
    23 Posts 5 Posters 12.5k Views 5 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer
      @Mykle1 I’m no css guru but try this in your custom css to push it over:
      .MMM-Astrology .content {
        margin-left: 13%;
        position: absolute;
      .MMM-Astrology .header {
      	margin-left: 30%;
      You may have to play with the % numbers…
        Mykle1 Project Sponsor Module Developer @cowboysdude
        @cowboysdude said in MMM-Astrology:
        I was going to try your css suggestion this morning but before I even entered that into the custom.css file the module isn’t loading. All I get is the “Forecasting…” and nothing else. I didn’t change anything and it was working yesterday. I reloaded MM quite a few times but it never completes loading the module. I’ll try again later
          Let me look into it :)
            @cowboysdude No worries. I thought you might want to know.
            I’m on my way out to dinner
            Peace
              cowboysdude Module Developer @Mykle1
              @Mykle1 I made a couple of changes so do a git pull when you get back :) Now I’m off to dinner myself!
              Mykle1M 2 Replies Last reply Reply Quote 0
                This post is deleted!
                • C Offline
                  cyberphox
                  I’ll be installing this as soon as i get back from vacation…and i think its time to start building a bigger mirror!!!
                    I made a couple of changes so do a git pull when you get back Now I’m off to dinner myself!
                    Short day at work today. I’ll pull the new version and fire her up in a few. I’ll get back to you
                      I told you I’d get back to you. :-)
                      I successfully justified your module to the right using your css suggestion. However, the header css would not move the header permanently, meaning, as the module loads it appears as if it’s oriented correctly, but then it snaps back over to the left when the module does load. Now, I don’t know if you noticed from any of my pictures, but I don’t use headers at all, none. I would be more than pleased to be able to remove the header altogether. I noticed there is no header: in the config.js so how would I go about removing that.
                      Also, the logo? for Taurus seems to not load. There is a little symbol there. It’s not very clear at all in the picture. Broken link?
                      Otherwise, here it is.
                        Interesting…
                        Do a git pull and add this to your custom.css
                          margin-left: 11%;
                          .MMM-Astrology .title {
                        	margin-left: 11%;
                        Adjust your % accordingly :)
                        • 3 / 3
